Will parts from a 2003 FWD s60 work on a 2004 S60R? Like the hood, dash, bumper cover, drivers airbag, passenger airbag, radiator core support, headlights?
THANKS!!! This is so helpful!!!!s60 parts that will work on an S60R:
hood - direct swap
dash - the whole dash or the gauge cluster cover? Regardless, the regular s60 dash will fit in an R. as well as the gauge cluster cover.
bumper cover - yes it will, it will bolt up
drivers airbag - as long as its a 3 spoke steering wheel
passenger airbag - yes it will, but may need to be programmed
rad core support - yes it will swap over, no difference, as long as s60 swaps over to an s60
headlights - will bolt up, but you may get several failure messages in the DIM.
An Update to the original OP's Question...
77x has acquired a 2003 S60 that is in very good shape for a small price.
It is a base model with a 2.4 engine that is toast.
So now the big question...? What year V70 wagon is the same a S60 R front?
Rather than dismantle the base S60 it seems better to get a car that has all the parts we need to fix both cars.
So we would be looking for a V70 with a 2.4 engine. Correct?
Thanks, will do!Depends on what the engine VIN code is and which engine number the 2003 S60 carries. Send me a PM and I'll see what I can find out when I get to work. VIN code 61 is much easier to find since it was the federal emissions engine, 64 is a nightmare to find.
