1 - 20 of 43 Posts
Hi all,
forgive me if this has been asked repeatedly, but I could not find an answer in the search.
I'm wanting to upgrade my 2005 S40 T5 FWD to 320mm front brakes but I still have the stock
16" wheels. Will there be fitment issues with the new brakes and my 16" wheels?
Thank You,
Jason
I am going to say no b/c my 17' rims barely clear the 320 mm set up. I also read somewhere on here that the upgrade kit from viva is a little bit bigger even then the stock setup of 320mm. I dont know this as gospel but my car def. could not have 16in rims on it.
I have 16" wheels and my stock 320mm brakes fit w/ no issues.
My 06' AWD V50 came with stock 16" Clava wheels and 320mm brakes.
OP, not sure which 16" wheels you've got, but OEM Clavas will work. Cheers!
It may work, though I have strong reservation it will, but I doubt it would be great for the venting aspect of your rotors anyway, just a thought...
Here is the pic... Hope this helps.
<a href="http://imgur.com/7BUe3"><img src="http://i.imgur.com/7BUe3.jpg" alt="" title="Hosted by imgur.com" /></a>
You're good. Clavas work, TIGHT fit, you'll be surprised it actually fits but once you get them in you'll love the difference. Switch out the fluid and move to stainless lines; well worth it.
Sorry to revive this thread back... I just bought 320mm rotors and new calipers for my 2007 t5 AWD... but clavas look like one inch with (stock one not 320) so, errr looks like that DSot's rotor isnt 320 but prolly 302?
Thanks
Discussion Starter · #15 ·
I have all my brake parts but haven't put them on yet, I also bought new wheels to go with everything. As soon as I get the brakes put on I'll be taking some pictures
I can vouch for the 320mm fronts fitting with 16" Clavas, but I don't know if any other factory 16"s fit bro.
I agree with Isaac
There are Brake Caliper Templates - one can get on line to compare , and make one out of Car-broad to Test Fit .
Rotor has more then 1" per side and the Caliper has 3/4 inch on the Clavas Wheels .
Any Interference - would come from the Back side of the Spokes on the Mags You just Purchased . ( Send Up a Photo )
Pretty much would tell looking at them .
I haven't posted here much, but usually lurk around and read up on things. I do have a question though, is there an easy way to upgrade from the 300mm to the 320mm rotors? I would imagine different calipers or at least mounts would be needed, but I'm not sure. If this has been answered elsewhere, sorry for hijacking the thread and please point me to the correct thread.
Thanks,
J
1 - 20 of 43 Posts
