1 - 18 of 18 Posts
Will this work? Appearently my '01 CAT is on its 9th life and its not look'n so good. <p>I am figuring, that I could transplant the DP from my '06 R to the '01 XC and then slap on a mo'betta DP on the R. <p>pssst, don't tell tell Mrs...
Re: Will a stock R DP fit on my '01 V70 XC? (850arrrsaylikepirate)
Should fit I believe the p2awd dp are all the same might ask lucky at ipd or george at viva as they would know for sure.
Re: Will a stock R DP fit on my '01 V70 XC? (volvosince16)
Thanks, I shall ask.
Ah i dont think it well fit. The turbo is a different size. The R's turbo is larger then the turbo you have. The Inlet side is bigger so im thinking the exhaust side has to be bigger also. I may be wrong but im 90% sure in wont work.
Re: (Luciano)
I also just checked part numbers there not the same part # so there got to be something different about it. <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
I would say they will work <br>outlet flange on the turbos is the same.
Re: (Luciano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Luciano</b> »</i></TD></TR><TR><TD CLASS="quote">I also just checked part numbers there not the same part # so there got to be something different about it. <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> </TD></TR></TABLE><p>never go buy part numbers you would be suprised how many part numbers there are for the exact same parts. <p>1 screw can have up to 20 different part numbers <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
Are you sure of that.... <p>dash screws ... look it up <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>would be suprsied where that screw is and how many part numbers it has.<p>and you might be around the parts ..... I am everywhere on the parts <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>
Shoot just look at axle seals from 93-00 <p>How many different part numbers are for axle seals when all axles are the same for FWD cars.
Re: (Chilled Man)
What do you mean by axle seals? Are you talking about where the Axle shaft goes in to the trans? If so there are alot of different types. The same part number may fit many different Volvo modles. But for instance Volvo's bolts alot of them may look a like but some are different grade steel or different coatings. There is more too it then just looks <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">. Also volvo well also change the part #'s when they use a differnet manufacturer so they change the number part looks the same but is not made by the same people. But back to that downpipe question if your looking for one I have one off an 05 S60R 12,000 miles on it like new and i'll give you a real good deal. Let me know <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
but just as you said they change part# when they change manuactures. <p>So the same part that fits in that same spot can have a few different part numbers. <p>
Discussion Starter · #14 ·
Re: (Luciano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Luciano</b> »</i></TD></TR><TR><TD CLASS="quote">if your looking for one I have one off an 05 S60R 12,000 miles on it like new and i'll give you a real good deal. Let me know <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> </TD></TR></TABLE><p>Thanks for the offer. I may just grab yours and save some buckage. <p>However a sweet TME/Phuz/IPD DP maybe just what my R needs...<p>Thanks for all the help.
Re: (850arrrsaylikepirate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>850arrrsaylikepirate</b> »</i></TD></TR><TR><TD CLASS="quote"><p>However a sweet TME/Phuz/IPD DP maybe just what my R needs...<p>Thanks for all the help.</TD></TR></TABLE><p>Go for the PhuzDP...it compliments the TME so lovely...you will not regret it.
Discussion Starter · #16 ·
Re: (QnsMostWanted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>QnsMostWanted</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Go for the PhuzDP...it compliments the TME so lovely...you will not regret it. </TD></TR></TABLE><p>I will think about, I may just keep my R DP and grab Luciano's... I wonder how the check book is look'n...
The bolt up is nearly the same but the pipes are slightly different in their length. you can make it work but it isn't technically a straight swap.<br>
Discussion Starter · #18 ·
Re: (Ipd-Lucky)
Thanks Lucky.
1 - 18 of 18 Posts
