Would it be better to post install pics and notes in this thread to keep it all relative, or create another?
Here are some projector beam patterns:matched sets of gen 2 projectors... PM if you're interested.
This is the SKBOWE thread... So yes, if you have pics of an HID install that uses SKBOWEs please post at least one here (or as many as you want). I also expect any issues/problems/support stuff related to the SKBOWE to live here.Would it be better to post install pics and notes in this thread to keep it all relative, or create another?
Nick was giving me flack for using OEM spec tape and loom. That pic shows why I did it - the SKBOWE wires blend in perfectly with the OEM harnesses... It's only the silly Morimoto braid that sticks out like a sore thumb. :thumbup:</img>![]()
Yes, I know all about the crummy wiring. I spent some time today starting to get my lights ready, and the wiring on the the driver's housing was pretty much shot. Almost thought about throwing in the towel and trolling eBay for a used one. But ... I spent at least an hour doing this and it lives to see another day:The stock headlight wiring is very fragile, so be careful when manipulating it.
Thanks for the suggestion! I'd like to find a new grommet to have both wires go through; instead of having one hang out. Since the HID setup would probably not pass inspection, I still need to be able to swap projectors and keep the original H11 connector present. If I didn't, I'd get another grommet and then place both sets of wires permanently in it.My only suggestion: when you go do to the high beam, add some RTV around the grommet, especially where the power wire comes out and where the ignitor wire goes through. Just pull the grommet out, run a bead of RTV around the outside and put it back in. From the inside, add some extra round the two wires and wiggle them in and out. That will keep it everything in place and keep the inside nice and dry.
I like how it blends in easily. The braided Morimoto cable is *too unique* to the original wiring. I'm sure that's what they were going for, but for *blending* in- not so much. The SKBOWE is very sturdy in construction, and the wires are easy to bend and can be stuffed in several holes around the headlight to allow a flush fit.Nick was giving me flack for using OEM spec tape and loom. That pic shows why I did it - the SKBOWE wires blend in perfectly with the OEM harnesses... It's only the silly Morimoto braid that sticks out like a sore thumb. :thumbup:
If I can maybe add my 2 eurocents - I spent fair amount of evenings fiddling with those retro projectors on my test bench as I had some issues originally aswell (corona, rainbow effect and hotspot misalligned). As you noticed adjusting the screws of shutter can help nivelate some issues, but you may also have a go with bulb saddle itself. In my case (H7 burners) using pliers on base of the bulb to twist the metal a bit allowed me to center the hotspot perfectly and nivelate most of "escaping light" artifacts. As you cant do the same with DS bulbs, you can use the "juice carton" fix, where you just cut a small piece from thick and heat resistant material (juice cartonISSUES:
My left side projector has a horrible corona effect going on. I am referring to that concentrated outer ring area of the projector light. I have tried swapping lens, and the result is the same. I am thinking it is due to a poorly manufactured replica projector. I'm hoping to further troubleshoot the issue and solve the beam defect.
That's a great idea!! Thanks for the suggestion. I did notice the hotspots weren't aligned and it really bugged me. The bulb does not sit flush. I'm guessing this is due to the poor QA of the replica. I'll try the "juice box" method, or use some aluminum tape and see what happens!As you cant do the same with DS bulbs, you can use the "juice carton" fix, where you just cut a small piece from thick and heat resistant material (juice carton) and use it around the bulb base to extend the distance between bulb and its saddle, if needed. Also allows you to center the hotspot if you place more material on one side and less on another (imagine placing some on 3o'clock position and notice how hotspot and artifacts move).
The light is amazing, obviously haha the stock halogens suck on these cars. I've done the H9 conversion, re sanded the lens, and even cleaned the stock projector glass, and nothing really helped. The HID conversion is very beneficial to all parties on the road; if done properly, and aimed correctly.How is the light now, even with current issues. Happy when driving at night?
Yep, 100%! I can tell you that even with brand new replicas, polished plexi shield and very good H7 halogen bulbs (so almost "brand new headlamp" setup) light output is terrible, comparing to free-form reflectors of my previous gen S40. Tested on myself.The light is amazing, obviously haha the stock halogens suck on these cars. I've done the H9 conversion, re sanded the lens, and even cleaned the stock projector glass, and nothing really helped. The HID conversion is very beneficial to all parties on the road; if done properly, and aimed correctly.
It is pretty easy to remove the male pins from the H11->9005 connector using a paper clip. Once the housing is off, you should be able to fit it through the center of the existing grommet. I agree that there is no good place for a passthrough, but eventually the wires conform to the 90 degree bend and there shouldn't be any issues.keep the original H11 connector present. If I didn't, I'd get another grommet and then place both sets of wires permanently in it.
I played around with my replica this AM and couldn't replicate the halo even moving the bulb way out and sideways in any direction, must be a "feature" of the TRS replicas not present in the "My.Headlight" (ebay/alibaba) branded ones.Does anyone know what that corona effect could be coming from? It's annoying to drive around at night with the left side all lit up around the edge!
Aluminum furnace ("duct") tape for sure. Not sure what juice box is in UK but I would keep waxed cardboard away from headlight componentsaluminum tape
+1The HID conversion is very beneficial to all parties on the road; if done properly, and aimed correctly.
hehe, just to clarify - original "design" of this mod was done using actual juice box (the one that has aluminium insert and thick cardboard outside) hence the name, but obviously something more to-the-purpose will be betterAluminum furnace ("duct") tape for sure. Not sure what juice box is in UK but I would keep waxed cardboard away from headlight components![]()
I thought of this, but they are closeout items. Do you think they'd care at that point? I guess maybe if I contact them, they may at least be aware of the issue and have a possible solution! Thanks for the idea!BTW - if you cant fix the issue, maybe its worth writing to TRS and asking for replacement projector?
Oh no!? What happened?!!?Well, the Morimotos came last night......but my retrofit just got more complicated
Just be careful with this. Depending on binders autoignition point of cardboard is between 220-240C, which is lower than the operating temperature of the HID quartz envelope (~300C). A spacer is shielded from direct exposure by the reflector, but I think under the right circumstances you could at least expect decomposition resulting in nasty smoke inside of the housing.the one that has aluminium insert and thick cardboard outside
Bummer... fingers crossed on an easy fix. At least you could see it right?Heavy rain+hard turn+guardrail-good suspension/too much weight transfer= new bumper cover and pass headlight assembly. Mechanically it seems fine. Hopefully its just cosmetic.
TRS seem to be reputable enough so its no harm to give it a shot. If you send them a pic from good one and compare to bad one, and explain you tried the bulb swap and you are confident its the actual projector issue, I would expect them to exchange them without a word. Plus you should have statutory right to return/exchange the item if bought online, atleast thats what we have in EU .I thought of this, but they are closeout items. Do you think they'd care at that point? I guess maybe if I contact them, they may at least be aware of the issue and have a possible solution! Thanks for the idea!
