Rough stab at install guide is up: https://www.skbowe.com/a/2017/07/13/skbowe-install-guide-retrofit-initial-draft/
My original Pre-KBOWE was still working, but I figured I should be the first guinea pig. Super easy to install, 15 minutes max (not including HID install). Took longer to take out the original KBOWE...
I will include two stainless M8x1.25 nuts, four 8-inch zip-ties, and a piece of 80-grit sand paper with each order so all you technically need is a 1/2" or 13mm wrench. You can totally do a better job, and if anyone wants to take better pictures I'll gladly use them for the "official" install guide
