Who wants a Volvo P1 specific, WMM safe, HID Retrofit?
60548 Views 362 Replies 43 Participants Last post by  Bernie (NoVA)
7
SwedeSpeed P1 (C30, S40, V50, C70) HID Retrofit Index
  1. SKBOWE Plug-and-Play harness for P1 HID conversion (you are here)
  2. Background info, general questions, and share your HID setup <- Non-SKBOWE HID install issues/discussion/WMM kills
  3. KBOWE How-To (Original 2009 Version) build your own PWM filter <- if you want to build your own
  4. Original 2009 investigation and technical discussion on S40 HID issues <- Technical/Engineering discussion on the CEM, PWM, WMM, and alternate designs
  5. ForceFed's E46 D2S Bi-Xenon Projector Retrofit guide
  6. Rewire OEM Bi-Xenon headlights to work on the halogen harness
  7. DRL Disable Alone not enough for safe Aftermarket HID retrofits
  8. LizardOfBodom's EU/RHD Bosch ("E46") Bi-Xenon replica retrofitting writeup + angle eyes + running lights
This thread is for discussion of the SKBOWE PWM filter, a plug-and-play error harness that I developed to help the P1 community with HID retrofits. If you have a question that's not related to the SKBOWE, please see if it fits in one of the other HID threads (above) before posting here or starting a new one.
Lets face it, the OEM halogen headlights in our cars suck. We should all know by now the issues with HID retrofits, and that the DIY solution is not trivial since it takes some soldering and hacks up the CEM harness. I have been PMed dozens of times over the years asking for a better way...
So... I found something really sweet ;) If you are interested in a commercial, plug-and-play (no cut wires!) solution that was designed specifically for Volvo P1 cars (S40, V50, C30, C70) check out:
https://www.skbowe.com/ - Shipping Now! Limited Quantity Remaining
Orders as of October 2017 (82 total): boulderc30, V50toS40, thefisch33, rhags138, persianelf, nhiggins, S40R-by-design, walky_talky20, taskmule, viggen, Puddlepirate56, chrisasdf, Noswal, beachnut, stevien1, evy0311, MJC70, MCRDSM-S40, hq_, et al... *
  • Prototype: #001A (test) #002 (mine), #003 (display unit/open box)
  • Batch 1: #004-#028 CLOSED & SHIPPED (JUL 2017)
  • Batch 2: #029-#050 CLOSED & SHIPPED (DEC 2017)
  • Batch 3: #051-#075 CLOSED & SHIPPED (FEB 2018)
  • Batch 4: #075-#100 - Shipping Now (OCT 2018)
* Don't see your username here? PM me with your SN#
Click here to see SKBOWE Installs!!
rhags138 (007) - Install
mgm7890 (024) - Install + writeup
:thumbup: SirScarFace - Install
:thumbup: Saab - Install
SKBOWEs have shipped all over...
</img>
Useful Snip
For those of you looking for projectors, I put together a reference sheet to help you identify compatible Bosch AL 3-inch "E46" projectors in auctions or at salvage yards:
See the full resolution PDF here: https://www.theeshadow.com/files/volvo/e46/guide/al_projector_guide_v1_web.pdf
You want to look for "Gen 2" projectors, they have the best optics and the wiring is simple. Gen 1 requires a solenoid controller for bi-xenon functionality. All projectors with black plastic rings will fit D2S, the ones with octagon-shaped bulb holders might need a simple modification (bending a small tab) to allow them to take D2S bulbs.
If junkyard hunting and eBay stalking aren't your thing, Nick has been nice enough to hold a few for us:
matched sets of gen 2 projectors... PM if you're interested.
Here are some projector beam patterns:
<a href="https://www.skbowe.com/a/2017/08/01/al-projector-e46-identification-chart-selection-guide-pdf/" target="_blank"><img width="683" height="1024" src="https://www.skbowe.com/a/wp-content/uploads/2017/08/al_projectors_hid_cutoffs_sixup_montauge-683x1024.jpg" class="attachment-large size-large" alt="" srcset="https://www.skbowe.com/a/wp-content/uploads/2017/08/al_projectors_hid_cutoffs_sixup_montauge-683x1024.jpg 683w, https://www.skbowe.com/a/wp-content/uploads/2017/08/al_projectors_hid_cutoffs_sixup_montauge-200x300.jpg 200w, https://www.skbowe.com/a/wp-content/uploads/2017/08/al_projectors_hid_cutoffs_sixup_montauge-768x1152.jpg 768w, https://www.skbowe.com/a/wp-content/uploads/2017/08/al_projectors_hid_cutoffs_sixup_montauge-1200x1800.jpg 1200w" sizes="(max-width: 709px) 85vw, (max-width: 909px) 67vw, (max-width: 984px) 61vw, (max-width: 1362px) 45vw, 600px"></a>
SKBOWE install is plug-and-play:
</img>
</img>
Survey Stats as of May 2017: 87 responses, 82 on board.
VENDOR INFORMATION
We need a reliable manufacturer / distributor for high volume manufacturing of a specialized error canceling circuit designed specifically for the Volvo P1 series. A complete validated production ready design is available. If you are a vendor and are interested in taking on this project, please contact me!
201 - 220 of 363 Posts
Yeah, everything works fine on the pass side, minus the occasional BOW now. Only the cheap kensun works on the drivers side. I didn't start getting the BOW until I tried to install the other morimoto ballast. Even with the first ballast install, I had to plug/unplug the power input from the ballast several times before it stopped going out after 30sec. I probably just have to fiddle around with it more........after I get the mechanic's diagnosis.
Sent from my VS995 using Tapatalk
Whoa non of that sounds like working fine... Did you send me an email that I missed?
Going out after 30 seconds is usually DRL thing - your LSM is in Position II right? Either that or bad connections somewhere. The ground is for WMM protection, shouldn't cause or affect any of those symptoms.
No, you didn't miss an email. It is in Pos II. It resolved after I fiddled with the ballast a while(5 min) I figured it was just the ballast "learning" the system. Didn't think anything of it until it started happening again after I tried to install the other ballast(I had the kensun on the drivers side and morimoto on the pass side. The kensun still flickered but the morimoto was fine. That was good for 2+ weeks until I tried to install the 2nd morimoto ballast.
Ok, well, if you do get to playing with it, check the HV (single pin) connectors too - they are notoriously finicky. I've found tightly setting a 4" zip tie around the barrel where the latch is to hold it closed (you'll see what I mean, only fits in one place) helps fro some reason. Also check / re-seat the Morimoto ignitor connectors, and make sure nothing is pulling too tightly at a weird angle with them. Oh and look for fraying insulation inside the headlight housing, make sure there isn't anything funky going on at the H11 connector.
Hmm, should I be wary of Morimoto stuff? I was planning on getting AMP XB35 ballasts/igniters with 90' AMP>D2S pigtails, and a set of ZKW-R lenses. I also have a new (very good used) set of headlight assemblies, which not only have much better looking lenses inside & out, but no internal wire fraying. Both my original assemblies were really awful. Even though I've fixed them all up neatly with cloth harness tape the new lights give me the ability to retrograde easily if needed.
2
The Morimoto ballasts themselves seem decent, but their D2S ignitors are cheaply made. Nick had a great idea WRT install that allows the ignitors to be quickly swapped out, and looks much much better when installed
By epoxying the male 4-pin to the cover, and making up a 4-wire harness to the female, it looks totally stock when installed. I also picked up a spare set of housings, and will write up this method with nice pictures when I can get around to it.
I think the main thing Morimoto has going for it is their support - TRS is decent WRT warranty claims.
EDIT: Also, with any ballast, but especially the Morimotos, it's critical to mount them so water can't collect in the connectors. Straight down is preferable, if sideways there should be a slight downwards slant. Same with the SKBOWE, the wires should come out of the bottom!
P.S. This sort of discussion is why I wanted to stay out of the ballast recommendation game - none of this has anything to do with the SKBOWE.
Well, spun bearing....so I guess I will be posting a set up on the classifieds.
Don't let the DRL disable hold up your 35W install - just keep LSM in II until you get to it. Every SKBOWE runs a 50W Morimoto kit for 10 minutes on simulated DRL during testing (if it can run that, it can run anything) so nothing will explode ** if it gets switched by accident. It's just not great for any of the stuff long term (especially on a hot day after driving hard, etc), if it was always on DRL it's something like taking the expected life from 20,000 hours to 5,000 hours.
BTW do you know the other dude in Philly?
Edit:
** Depending on you kits wattage and design, running a KBOWE + HID with the LSM in position II might trigger a hidden (silent) short circuit DTC (aka VIDA code) for a headlight circuit out of range low. If this happens, that side will be disabled until you remove the key and restart the car. There will be no warning displayed, and switching from 0 to II while the car is on (or the key is in) will not re-start the ballast. Restarting the car in position 0 will probably result in another error, making it seem like a fuse is blown or something is hooked up wrong. If this happens, take the key out, turn the LSM to II, and restart the car.
...But rather than explain all of that and have to deal with confused people, the "official" guidance is disable DRL.
Hi,
Can you extrapolate a bit on the position II possible error? What kinds of ballast are susceptible to this error? Here in Canada we can't really disable DRL, so I just want to leave it in the II position
Hi,
There is no problem leaving LSM in position II.
The only problem comes with LSM in position 0, DRL disable helps if you forget about this. I will soon post info on how to modify LSM connector to make 0=II, as alternate way to ensure no problem if it's set to 0 by mistake.
I was referring to the "hidden error" you mentioned, and the light turning off and having to turn off the car to be able to turn it on again. If it happens only with certain HID ballast (brand? wattage?), I just want to avoid buying these and but ones that do not cause any error
Again, the hidden error happens only when LSM is in Pos0. It affects all brands of ballasts, it is caused by the CEM not the ballast. Even 35w ballast draw 40-45W, at 50% duty of Pos0 that is peaks of 80-95W, which trips the short circuit protection. The way to prevent it is to avoid or disable Pos0.
In PosII the lowest duty is 85%, so like I said, leave it in II and you will have no problems.
PS Batch2 orders placed before this weekend will probably ship out same day :)
New How-To posted on skbowe.com: the DRL Disarm - so called to differentiate it from the software DRL disable. Basically by removing pin 6 (black/green) from the LSM connector - or cutting the wire - the CEM thinks that Position 0 is actually Position II, and all the DRL issues go away!
(click pics for full writeup)
Cost: $0
Time: 5 minutes
Seeing at night: Priceless!
Cost: $0
Time: 5 minutes
Can you hear this sound?....
... thats the "AAawwwww" sound of all dealerships that from today are loosing portion of their extortion money for people NOT ordering DRL disable software anymore :)
u sir deserve a beer! :) :beer:
Yep, and kudos to Shadow as always for figuring this out. This doesn't disable DRL though, just the low-duty voltage on position 0. Your lights will still be on, and since I want to be to be a cool dude I want to do the true disable w/ the software download. Just need to ask my dealer what they want for it. If it's just a few dollars more than a 3-day subscription and the $30 software I will let them do it. Not worth messing my hacked Vida install up to load 2015 web version.
Ok I understand, I think there's a mistake in your original post, it should read pos 0 can create an hidden error, not position II (which makes sense).
I'll probably order a set this weekend then, thanks!
Fixed, thanks:
** Depending on you kits wattage and design, running a KBOWE + HID with the LSM in Position 0 might trigger a hidden (silent) short circuit DTC (aka VIDA code) for a headlight circuit out of range low. If this happens, that side will be disabled until you remove the key and restart the car. There will be no warning displayed, and switching from 0 to II while the car is on (or the key is in) will not re-start the ballast. Restarting the car in position 0 will probably result in another error, making it seem like a fuse is blown or something is hooked up wrong. If this happens, take the key out, turn the LSM to II, and restart the car.
...But rather than explain all of that and have to deal with confused people, the "official" guidance is disable DRL. Alternately, you can disable Position 0: https://www.skbowe.com/a/2017/09/27/how-to-drl-disarm-aka-lsm-position-0-disable/
EDIT: Fixed the above to read correctly (thanks Fwinns)
I have been running my SKBOWE with Morimoto XB35 for three weeks now and I am very impressed with the light output. It's night and day compared to the halogens. I originally used the 50W ballast, but this overpowered the headlight and I was being flashed by other drivers. The 35W kit is the perfect setup, in terms of not being overly bright and still giving a good light output. I have not been flashed with this setup, which is important. I have kept my setup stock so I am using the existing projector, but I do see the appeal of going down the E46 route. If you are looking to keep it simple, by using the existing projector with 35W ballast is the perfect combination. I have been waiting for a safe solution to run HID in my C30. A big shout out to Jacob for designing the SKBOWE. He has designed a high quality product and is very knowledgeable when you are seeking help. If you have been waiting to upgrade your halogen P1 Volvo with HID, you need SKBOWE!
FYI, SKBOWE Batch 2 is shipping now - there are 15 units left.
And as a heads-up: If it does happen (not sure yet) Batch 3 will need to be priced at least at $120-125ish.
:thumbup: :beer:
BTW, SKBOWE #037 shipped yesterday!
:thumbup: :beer:
Any sets left for H7? What would delivery to Ireland be? Looking to change to HID. Thanks.
Hi Stevie_n1,
There are 15 sets left.
Each set does not include the HID kit (H7/H11/D2S) - you buy this separately.
Intenational shipping changers are calculated automatically during checkout. It will show you when you press the "buy it now" button
These and many other questions are answered on https://www.skbowe.com/a/ ...
