1 - 20 of 28 Posts
I have a new key that is cut and needs to be programmed. My question is can anyone in CONNECTICUT program the transponder in R key besides the dealer. They want $130
I work in MASS so if there is somewhere close to Springfield that works too
Thanks
Col
I believe only Volvo can...???
2007 S60 T5M, 2014 S60 T5 AWD Platinum
Anyone with an active subscription in VIDA can do it. Subscriptions are so expensive that pretty much only dealerships and a handful of Volvo specialty shops have one.
EDIT: It seems they have come down in price since I last checked. As far as I can tell, anyone who is not a dealer can only purchase the subscription in 3 day increments @ $82.33.
you need to have DiCE to make new key programmed. + some magic from my side :)
I have done many keys with VIDA dice. But not worth it for just doing one key. If you have a few software loads then it is worth it. Otherwise the dealer is your best deal.
I believe vida dice can not progarm new keys. Maybe you can use key pro m8. It is an professional key progarmmer, can program a lot of car models, like volvo:) know more at there
Nice sales pitch
I didn't loose my key it just was really broken
So anyone willing to come to CT to PROGRAM IT THEN?
I will pay! Less than the dealer of course ;)
colin2211, As I said you need to have DiCE. Or just find somebody who have it nearby and can help you.
I said DiCE. I did not say VIDA !!!
If you aren't using VIDA to drive the DiCE unit, what software are you using? The DiCE unit will be useless to the OP without knowing what software to use with it. If you're using proprietary aftermarket software, then please share the details. It could save people some money.
I use my own software to do programming of Volvo modules.
I've also written special optimized for DiCE software for sharing the device over the internet.
If broken, just repair it. Cut the transponder out of broken key, put it in a new key, cut new key blank, done. Save you the programming costs. Glück
Do you do keys and fobs? I'm surprised no one else besides Matt is asking about this.
I do. As for nobody is asking that is because everyone is sure that only the dealer can do that ☺
Well, do tell. I am willing to learn how with Dice unit standing by. Can you get other things to work like radios, seat modules, DRL delete, etc? No software for Volvotech needed? Very interested.
I give my small prog for sharing DiCE. The rest I do remotely with my software.
I can do reload of many modules.
I cannot say that everything is supported but a lot.
F.e.
2000-2004 MY
AUM, BCM, CCM, DEM, DIM, ECM, ETM, ICM, UEM, TCM, DDM/PDM, PSM, REM, SRS, SAS, CEM and car configuration.
As for CEM and car configuration there are restrictions for remote programming as is but doable with some special manipulations (without solder)
The software was developed as an instrument to help me to repair volvo cars. mostly for electronic repairs.
1 - 20 of 28 Posts
