1 - 6 of 6 Posts
Replaced a thermostat housing, refilled and bled the coolant, and did an oil change. Started car up after and it ran like a champ for about 5 minutes, before shaking and sputtering, having a flashing CEL, white smoke from the exhaust, and "Slow down or Shift up" warning. What could be the issue? (In previous thread, I said how there's oil behind the engine, above the pan and below the exhaust).
Discussion Starter · #2 ·
Read some codes and got P0300 (random misfires). Car drives like **** at low RPMs (white smoke, flashing lightd and sputtering), but drives normally otherwise.
My vote - your oil supply to your turbo is leaking. Only oil supply that's below the headers, and above to the pan.
Then you got me dude, only seams on the backside of the engine are oil pan - block halves- head-valvecover.
1 - 6 of 6 Posts
