no dial caliper?
Here's a pic of the other side with digital micrometer. Readouts not totally accurate since I was doing it one handed to take the pic. It's in the ballpark tho. Either way, it's clearly around 129 +/- a bit as opposed to the ~149 the book calls for. Looks the same as every other T12 head I've looked at online.That's weird. Could you take pictures of both sides of the cylinder head?
Yes sir! 130 degrees after finishing stage 2 at 60Nm. Always following the tightening pattern on the bolts (from center and outwards).Yo, Facusan. What do the torque stage 3 instructions mean? Says "130 & #176." First to say, 20 Nm and 60 Nm respectively.
Does that mean we go to 60 Nm on stage 2, then just go another 130 degrees on each? Not sure what the #176 means.
typo error for the degree symbol maybe?Not sure what the #176 means.
Right O! Man. Volvo sure does have a lot of typos in their tech info. Head heights, oil, torque specs...Yes sir! 130 degrees after finishing stage 2 at 60Nm. Always following the tightening pattern on the bolts (from center and outwards).
THANK YOU! You probably just saved me some serious time with this one. Getting anxious to finish the job now that I'm on the other side of this. Thank GOD for all of you guys here and partnering up with a GOOD machine shop through it all.BTW, don't forget to put the aluminum pipe from the turbo to the intake manifold before installing the VVT hubs. You won't be able to install it with the hubs in place.
Thanks! That's what I was thinking, but wanted to make sure since the "Volvo" one worked so well. Applied that sealant perfectly. It's almost go time! Just rounding up parts now and waiting for my shop to finish with the valve job. Can't wait to get this puppy back on the road. C30's still running like a champ, btw.I used a cheap foam roller meant for paint touchups from Home depot/Lowe's.
