I looked through the link for oil change in the sticky notes at the top of the forum but there is no mention of the size of the wrench used. can anyone help me out here?
I agree! All these fancy oil filter wrenches, that add to all the costs of tools etc. The oil gasket o-ring does most of the sealing, and those who haven't noticed, the oil filter cartridge has a lot of thread, so it takes about 20 turns to put all the way in, and this adds to the preventative leak measure. I try to use my hand to remove it, and unless you can't grip it with your hand (oil or whatever reason), I use my rubber strap tool.If you need a wrench to remove your oil filter cover then you are way too tight.
Correct torque for the oil filter cover should be such that you (unless you are a complete wimp) can remove it by hand, using steady pressure. Make sure your gasket/ o-ring is wetted with oil before the install so it doesn't bind, stick, or kink.
I've been doing oil filters this way since the '60's. never had a leak.
