I have a 98 V70 and picked up a 99 Feritta Catted DP.
The Problem: The bung fittings are on the right and left of the DP, and the stock SAS pipe and fitting want to enter the top of the pipe.
I am not a welder so I am looking to find some ready made, or easily modified parts (compression fittings-90 degree, bendable pipe,etc).
I saw a great set up at the thread below.
http://i6.photobucket.com/albums/y218/BlackT5_/DSC00529.jpg
Buy the correct converter
If I had found an available AWD, Angle Flanged catted DP with a bung in the center (instead of both left and right sides) for the SAS,
I would have gotten That One.
Is it not more of a challenge to find one that accommodates the AWD set up?
Delete the SAS. Even if you leave the overall hardware in place (minus that pipe to the DP), you can add a diode beneath or in the ECU that will disable the SAS, and NOT set a CEL. The EMS will believe the SAS is functional.
SAS Delete
Excellent thread,
Thank You
