1 - 6 of 6 Posts
Started the caR this morning and got a headlight out message. Swapped out the bulb, but still no sparkly sunshine, so figure it's got to be the ballast. The thing is, headlights were working fine last night, and I've never had any error message regarding the headlights. Is this normal behavior for a ballast going bad?
Yup it's dead. If it's corroded, sometimes you can revive it buy putting it in 90% alcohol. If not cheap eBay replacement and seal up the corners over the gasket it comes with and connector areas with black rtv.
Sent from my ZTE A2017U using Tapatalk
Did you wash the car recently? Sometimes when the lights start to leak a wash can be fatal. ^^^ with respect to the 90%+ isopropyl alcohol.
Sent from nunya
Not sure how it got in there, but the headlight was full of water, which of course drained down into the ballast. :(
1 - 6 of 6 Posts
