1 - 12 of 12 Posts
I have had no problems with my R other than the radiator cracking and the dealer replacing it under warranty. <p>I am at 50K and wonder when i should expect my next huge maintenance service. spark plugs etc.......<p>I will def need to get new pads and rotors since my rotors have not been replaced yet but i am sure they are starting to warp. <p>Any clue anyone ?<p>how many miles should a s60R 06 model be services for oil change 5K or 3,500?
Re: When should i get Super Service Done 50K (dieselfitzs60R)
Welcome to SS. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <p>First recommendation, please change your user profile (drop the Sports Edition):<p><I>2006 s60-R Sports Edition</I><p>Second recommendation: refer to your owner's manual for service items, nothing special at 50K though you should consider all fluid changes if you haven't done any yet. plugs are 60K IIRC<p>Third recommendation: search the MANY discussions on oil intervals and proper type/weight; what have you done for the past 50K?
Again, welcome. I work in Sterling and live down in Springfield / Burke. There are many on here who live in NOVA. <p>Yes, plugs are 60k. <p>Oil is up to you. You can play it safe or you can gamble. As Magoon said, many threads on oil. <p>How have you been servicing it up to this point? Factory schedule? Nothing other than oil changes and issues?
Welcome.<p>I changed my plugs at 50 and what a difference it made. Maybe it's in my head, but the car feels a lot faster. Maybe there was something wrong with one of them before. They were worn a bit, but I didn't expect this.
Re: When should i get Super Service Done 50K (LAWLESS)
I work at a dealer so I'll tell you right now everything that will be done:<p><b>52.500 Service:</b> Labour 1.2 hours<p>Change oil and filter<br>Rotate tires<br>Check adn top off fluids<br>Reset service light<br>Set tire pressure<br>Check Brakes - pads and rotors<br>Check wipers<br>Check suspension components<br>Check axle shafts<br>Check exhaust system<br>Check battery condition<br>Check handbrake and adjust <p><br><b>60.000 Service: </b> Labour 4.1 hours<p>Change oil and filter<br>Rotate tires<br>Check adn top off fluids<br>Reset service light<br>Set tire pressure<br>Check Brakes - pads and rotors<br>Check wipers<br>Check suspension components<br>Check axle shafts<br>Check exhaust system<br>Check battery condition<br>Check handbrake and adjust<br>Replace cabin filter<br>Replace air filter<br>Replace spark plugs<br>Flush brake fluid<br>Replace coolant<br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dieselfitzs60R</b> »</i></TD></TR><TR><TD CLASS="quote">I have had no problems with my R other than the radiator cracking and the dealer replacing it under warranty. <p>I am at 50K and wonder when i should expect my next huge maintenance service. spark plugs etc.......<p>I will def need to get new pads and rotors since my rotors have not been replaced yet but i am sure they are starting to warp. <p>Any clue anyone ?<p>how many miles should a s60R 06 model be services for oil change 5K or 3,500? </TD></TR></TABLE><br>Take it to Viking Automotive in Chantilly across from Costco on Lee Rd.<br>They will save you big time and only use Volvo parts, no aftermarket junk. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>They only work on Volvo, BMW and VW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dieselfitzs60R</b> »</i></TD></TR><TR><TD CLASS="quote">I will def need to get new pads and rotors since my rotors have not been replaced yet but <B>i am sure they are starting to warp.</B></TD></TR></TABLE><br>From <A HREF="http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml" TARGET="_blank">http://www.stoptech.com/tech_i...shtml</A>:<p>"With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, <B>in more than 40 years of professional racing,</B> including the Shelby/Ford GT 40s – one of the most intense brake development program in history - <B>I have never seen a warped brake disc.</B>"
Re: When should i get Super Service Done 50K (dradernh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dradernh</b> »</i></TD></TR><TR><TD CLASS="quote"><br>From <A HREF="http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml" TARGET="_blank">http://www.stoptech.com/tech_i...shtml</A>:<p>"With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, <B>in more than 40 years of professional racing,</B> including the Shelby/Ford GT 40s – one of the most intense brake development program in history - <B>I have never seen a warped brake disc.</B>"</TD></TR></TABLE><p><br>Dradernh from southern new hampshire. Sounds like Nashua maybe? or manchester? <p>Anywho. back to the quote, apparently a race car has really good quality brake rotors, and dont have people who set there left foot on the brake pedal and keep it there for an hour. Also, if brake rotors never warped, manufacturers wouldnt have maximum rotor runout measurements to backup warranty rotor replacements.
Glad to see another person taking up the cause to debunk the "warped rotor" myth. <p>The problem is that far too many people have heard this from their automotive "experts" of choice. It is right up there with "batteries discharge if you set them on concrete", "being in the cold, will result in you catching a cold", or that kids can get a "sugar high".<p>I have 125K miles on my rotors, they are within thickness spec., and they are not "warped".
Re: When should i get Super Service Done 50K (Turb04S60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Turb04S60</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>Dradernh from southern new hampshire. Sounds like Nashua maybe? or manchester? <p>Anywho. back to the quote, apparently a race car has really good quality brake rotors, and dont have people who set there left foot on the brake pedal and keep it there for an hour. Also, if brake rotors never warped, manufacturers wouldnt have maximum rotor runout measurements to backup warranty rotor replacements.</TD></TR></TABLE><p>No argument that the rotor disc surface can become uneven. It is a result of pad deposit on the disc. Put your dial indicator on the perimeter of the disc, where there is no pad deposit. Assuming proper mounting, I suspect you will see little "warping", just normal run-out tolerance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Turb04S60</b> »</i></TD></TR><TR><TD CLASS="quote">Dradernh from southern new hampshire. Sounds like Nashua maybe? or manchester?</TD></TR></TABLE><br>Close, but no cigar - although I am roughly equidistant from the two. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Turb04S60</b> »</i></TD></TR><TR><TD CLASS="quote">Anywho. back to the quote, apparently a race car has really good quality brake rotors, and dont have people who set there left foot on the brake pedal and keep it there for an hour. Also, if brake rotors never warped, manufacturers wouldnt have maximum rotor runout measurements to backup warranty rotor replacements.</TD></TR></TABLE><br>I don't think it's a race car vs. a-car-driven-by-an-idjut issue. Have you ever seen a warped rotor?
I suppose a PhD in Physical Engineering must be wrong.<br><A HREF="http://newcarbuyingguide.com/index.php/news/main/5318/event=view" TARGET="_blank">http://newcarbuyingguide.com/i...=view</A><br>
1 - 12 of 12 Posts
