1 - 6 of 6 Posts
I know that the PEM and various other fuel-pump and fuel pressure issues are discussed in many threads, but since this is a bit of a different question, I thought I'd start a new thread. Also, since my car is a C70, which has more limited forum participation, I'm posting it in both the C70 and S40/V50 forums..
I know that some time ago, there was a recall and/or extended warranty put in place on the PEM. (Basically it was a recall in states that have a lot of road salt usage, and just an extended warranty in warmer states.)
Prior to this, the PEM was located under the car. In front of the right-rear wheel on some models, and (I think) by the fuel tank on other models. The PEM was therefore prone to early failure and problems due to corrosion, dirt, fouled connectors, etc. The fix (either via recall or extended warranty) was to replace the PEM, AND to re-locate the new PEM inside the car (usually underneath the rear seat).
My basic question is - did Volvo also change the PEM location on new production, for all models? I would assume so. But I haven't seen any info as to when the re-location of the PEM happened in production. In particular, when it happened for C70's, and the related models (C30, S40, V50, etc.)
My C70 is a 2007. If my PEM is still under the car, would it be in front of the RR wheel, as with (apparently) similar-year S40's?
I only see it listed under '04-06 S40 and V50. No other models or years.
NHTSA Campaign Number:
08V033000
Component:
FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP
Manufacturer Involved:
VOLVO CARS OF N.A. LLC.
Manufacturer Campaign Number:
190
Manufacturing Start Date:
Mon, 11/18/2002
Manufacturing End Date:
Mon, 08/22/2005
Corrective Summary:
DEALERS WILL REPLACE THE PEM AND INSTALL IT IN A NEW LOCATION TO PREVENT CORROSION. THE RECALL BEGAN ON FEBRUARY 20, 2008.
Yes, it would be right in front of the RR wheel. You will not find there on your car however as it was moved in production very early in 2006.
Mine still has the wiring harness there but the actual module is under the driver side passenger seat
Sent from my HTC M9 using Tapatalk
Thanks for the replies, all. Glad to hear that the PEM was already relocated to under the seat, by the time my car was built.
(Just did the fuel pressure sensor replacement this past weekend, which hopefully will solve my P0193 (and other) codes, related to fuel pressure, fuel pump, etc. So far so good, but I am holding off on declaring success until there has been a week of no-codes driving...)
1 - 6 of 6 Posts
