Hi Guys,
I found some cheap spacers for under $20 that are 12mm each, but I cant seem to find any 12mm extended lug bolts... I was wondering if I get the 15mm will they be too long to safely use with 12mm spacers? Im hoping there is enough room inside the wheel hub assembly to accommodate the extra 3mm to be able to hold the wheel in place, if not, do you think that a 10mm extended lug would be enough to hold safely? Cant seem to find any answers to the question of if the extended lugs need to be exactly the same offset as the spacer. Im hoping that since 5mm spacers dont always need to have the extended lugs, if I stay within a 5mm difference I will be okay, but wanted to hear from everyone else, and if you think I should go for a little longer on the bolts, or a little shorter.
Thanks everyone and keep driving.
