1 - 19 of 19 Posts
· Registered
Search isnt working well, so can you tell me where to get a set of 4 wheel spacers for my R. I used Svenske last time and got 5mm spacers. I think this time I may go with 10mm spacers. This will be for stock Peg's. I just want to push to wheels out some for a more agressive look. Especially the rear. So what sizes have you guys been using and who are you purchasing from.
Thanks.
· Registered
Re: Wheel spacers for the R (MASH)
Quote, originally posted by MASH »
George at vivaperformance.com ROCKS. Fair prices and quality customer care.
Thanks, I checked out their site. Now to just decide if I go 5mm front 10mm rear or 10mm all the way, any suggestions.
What mm have you guys been doing and noticng a nicer stance front/rear??
· Registered
Re: Wheel spacers for the R (Mike"R")
Quote, originally posted by Mike"R" »
Any spacer YOU want, your car, your decision.
Everybody will chime in with their own opinions but you're the one who'll be driving it.
(I have 5mm, I think they're fine. Some will say 10mm)
10mm spacers are MUCH more expensive. For one, you need longer lugs, you don't with 5mm
· Registered
Re: Wheel spacers for the R (JRL)
Thanks, and yeah, I know, everyone has an opinion. Well I think Ill stay with the 5mm all the way around. At least i wont need longer lugs.
· Registered
Re: (Mike"R")
5mm up fron 15mm in the back. If you have the pegs on your car, those #'s will put the tires right out to the fender lip on the car. IMO it looks the best. Car looks much tougher with a wider stance.
· Registered
If you do with aftermarket wheels with more offset (I have the Evolve H5's on mine) do not do the 10mm spacers in the back! They will rub. I had to take them off and put 5mm's on the back which work fine.
· Registered
Greetings BLF, wondering if you can help? I'm running 17" Pegs on my '04 V70 R. Just noticed that my second set of tires are worn on the inside edge / sidewall of all tires which have been rotated. This ware must come from ocasional full lock turns that cause the only rubbing that I am aware of... (tire hitting on the steering block?). I thought there was a post on this forum about this... Will spacers fix this problem?
Thanks
· Registered
Re: (BARMotorsports)
Quote, originally posted by BARMotorsports »
Sorry, previous post is ment for blf
I'm certainly no expert but, I would think it would solve the problem ---- 10's for sure ....5's ????? it may still rub, all the cars are different as has been stated many times before
I like the look of the 10/15 and lowered - and no rub at all
1 - 19 of 19 Posts
