1 - 10 of 10 Posts
i have the 07 s40 (2.4i).
oems: 205/55/16 on 16x6.5 with 52.5 mm offset
new wheels: 205/50/17 on 17x7.5 with 38mm offset
is it all good...or a no go? any issues?
Re: wheel size and offset question... (pcrage_2)
Quote, originally posted by pcrage_2 »
hmm... this would be a close one, because of that offset. 40 mm offset seems to be the lowest I've seen , but concidering you're running a conservative 205 50 17 (as opposed to a 225 45 or 235 45)
I bet this would work , good luck http://********************/smile/emthup.gif
Re: wheel size and offset question... (mattdoc)
i did run them through the wheel calculator...it states the new set-up would stick out 14mm more than the stock setup.
is that too much???
No thats not much at all, should be fine. I bought some 38mm wheels as well and have no reason to expect any rubbing. Main cure for that is just getting a smaller width tire
Re: wheel size and offset question... (ForceFed Motorsports)
so is there anyone out there currently rolling the 38mm offset?
if so, what width tire are they mounted to?
1 - 10 of 10 Posts
