Re: Wheel questions (geo1)
Any size will be ok. 17" rims require low profile tires which will give you an outstanding performance at high speeds and turns but, on the other hand will harden the ride. Also, the tires (2xx/45) will suffer with bad roads, and is common that bubbles will appear on the side of it due to hard bumps. 16" seem to be good alternative between both. Related with the witdh, it goes from 6,5" to 7,5". Depending on the original configuration of your car it might be needed to add limiters, both front ( to avoid rubbing at full turn ) and back ( to avoid rubbing with spring/shock ). These limiters are sold as a kit.
Finally, once you select the rim diameter and width, you have decide for the tire size in order not to change the final path lenght. Eg: 205/55 16" against 225/45 17", the first will have 2.83" more of diameter for why will do 31 revs per mile less than 225/45.
Remember that a tire of eg. 205 will fit from 5.5 to 7.5" wheel.
