I have a 2015.5 Volvo S60 with Sadia Wheels. 55MM Offset. 5 x 108 Bolt Pattern. 63.4MM Center Bore 17x8 Wheel Size.
I have been sharing these Wheels with my Michelin Pilot Sport As/3+ And Nokian Hakkas. I want to pick up a cheap set of Steelies being sold locally for Winter Tire.
Steelies - https://www.amazon.com/d/Car-Wheels/Escape-Steel-Wheel-17x7-5-5-108/B01C4O9Z3M
17 x 7.5 / 63.5 MM Center Bore / 5 x 108 Bolt Pattern. 40MM Offset.
Will I have any issues with the offset running 235/45/17's On the 17x7.5s?
Discussion Starter · #2 ·
Bump
Tire Rack shows only two 17 x 7.5 wheels, both have +42.
They do show 16 x 7.5 and 3 with +40. 225/55-16 rec tire size.
Unless you're lowered you should be OK.
