Can I fit a set of Volans from and 850R onto an S60?<br>If they do not bolt up directly what size spacer may be needed?<br>Has anyone done this? If so, do you have pictures?<br>Thanks!
The Volans will fit the S60.<br>The only issue I see is that you will be limited in tire size options, as the Volans are 7" wide, whereas standard 17" S60 wheels are either 7.5" or 8" wide. If you need spacers for any reason, we sell a full line of 5mm, 10mm and 15mm Wheel Spacer Kits.
Re: (George @ ViVA)
Thanks for letting me know. I am toying around with the idea of bolting these on my wife's S60 since she has the standard 15" Lysithea wheels and neither of us can stand the look of them. <br>On another note, what tire size could I put on the Volans to keep everything working properly?
