I have been driving around since I put the car back together back in 2014 without a formal wheel alignment check. I merely replaced the same number/size of shims as I took out. And that is an approximate replacement because I measured the old rusty things and tried to get new replacements in approximately the correct sizes. Plus, who knows whether I interpreted my scribble notes that I took when I dis assembled stuff approximately 2 years before I reinserted the new shims.
The car tracks straight on the highway and seems to steer just fine and does not wander; but, I thought I should probably check the alignment. Maybe my camber is excessive and I am going to be shredding my tires. Also, since I installed the EPS the car is sensitive to steering inputs on the highway and I thought that experimenting with a little more caster might increase the self aligning tendency and reduce sensitivity to steering inputs. With the Covid 19 shutdown looking like its going to last for a significant period of time, I thought why not experiment with the alignment myself. Its not like I am going to be going anywhere soon or have a lot of other things to do. To that end, has anybody tried any of the do it your self alignment tools and have any words of wisdom on what is good and what is crap?
