1 - 2 of 2 Posts
I just noticed that my driver side (LHD) door window switch lights aren't illuminated at the switch but the passenger side ones are. Just when I figured it was a bad switch I notice that the drivers side rear door switch along with both front and rear passenger side door switch lights are out also. Everything else on the drivers door switch are OK. Windows, rear window lock and mirror functions are all fine.
I poked around the wiring diagrams and there is nothing in common between the positions as far as I can tell. Has anybody else had this problem?
I use to get that all the time on my old S40. Turned out it was the connections on the wiring harness for the doors. Pop the connector apart, make sure all is clean inside and put some dialectic grease in and put it back together. Might help.
1 - 2 of 2 Posts
