1 - 9 of 9 Posts
I'm considering a local 2000 V70XC, and I understand that besides the ETM (which has been replaced, but I know only the xedmoex truly fixes it properly), the transmissions are known to be a problem. When I take it for a test drive, are there any specific telltale behaviors I should be looking for?<p>Any other standard failure points to check out?<p>Thanks!
Re: What to look for in 2000xc? (yuri1419)
I don't know that the transmissions are especially problematic but you really should have the car gone over by a mechanic who knows Volvos. Also try to get service records so you have a feel as to whether the car has been regularly maintained. Aside from the normal items I would be most concerned about the viscous coupling AWD system. Now between 9 and 12 years old, these cars don't cost a lot to purchase but can be a little pricey to bring back to stage "0" condition if they have been let go.<br>
These were part of my transmission concern: <A HREF="http://volvoforums.com/forum/archive/index.php/t-23117.html" TARGET="_blank">http://volvoforums.com/forum/a....html</A><br>and <A HREF="http://forums.swedespeed.com/zerothread?id=121575" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=121575</A><br>I have a good independent Volvo specialist to look at it, but is there something he can specifically do to know if the AWD is heading towards a big repair?
The entire AWD system can be tested for proper function. I doubt most mechanics know how to do this, but a Volvo dealer should as should a very good indy mechanic.<p>It's worth testing the function of each part so you know exactly how much you'll have to spend to get things working right.<p>This will be helpful: <A HREF="http://www.v70r.com/forums/index.php?autocom=ibwiki&cmd=article&id=41" TARGET="_blank">http://www.v70r.com/forums/ind...id=41</A>
correct me if i am wrong but all 98-00 XCs had the 4-speed auto using good old Dex III. Provided that the transmission fluid has been changed regularly, an '00 XC tranny is no worse than a '98-'99 XC tranny(conversely, it's no better either heh).<p>although the 2 links that you cited doesn't specifically say so, they are most likely referring to the 5-speed automatic that came on the normally aspirated 2000 70 series cars as well as the 2000 v70r.
Re: (yuri1419)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>yuri1419</b> »</i></TD></TR><TR><TD CLASS="quote">These were part of my transmission concern: <A HREF="http://volvoforums.com/forum/archive/index.php/t-23117.html" TARGET="_blank">http://volvoforums.com/forum/a....html</A><br>and <A HREF="http://forums.swedespeed.com/zerothread?id=121575" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=121575</A><br>I have a good independent Volvo specialist to look at it, but is there something he can specifically do to know if the AWD is heading towards a big repair?</TD></TR></TABLE><p>You believe everything you read?<br>As for the AWD, if it's not leaking and not making any noises, no, just change the bevel gear fluid and drive it. Not much more you can do
Out of all the cars I've driven, I think the transmission in my 00 V70XC is by far the best. The Saab 9-3 we have seems a little sluggish and kinky, and the Subaru is downright weird when shifting.<p>I'm pretty convinced the gen 1 trannies will last a really long time if maintained properly.
Re: (db130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>db130</b> »</i></TD></TR><TR><TD CLASS="quote"><br>although the 2 links that you cited doesn't specifically say so, they are most likely referring to the 5-speed automatic that came on the normally aspirated 2000 70 series cars as well as the 2000 v70r.</TD></TR></TABLE><p>The volvoforums thread topic is about the 2000xc.<p>
....and the The volvoforums thread was started by a dude from australia - they probably got the stateside '01 models a year early down there.<p>Gen 1('98-'00) XCs in the US domestic market had the 4-speed automatic! i cannot make this any clearer.<p>
1 - 9 of 9 Posts
