1 - 16 of 16 Posts
Hi,<br>I am wondering what aftermarket/mod parts can be share between the V70R and S60R?<br>I know engine, brake and drive train parts are the same but what about suspension and body parts?<br>Thanks
Re: What parts can be share between V70R and S60R (j-velocity)
Almost every part can be shared, It is the same vehicle except the body.
Re: What parts can be share between V70R and S60R (s140s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>s140s</b> »</i></TD></TR><TR><TD CLASS="quote">Almost every part can be shared, It is the same vehicle except the body from the back seat rearward. </TD></TR></TABLE><p>Fixed it for ya.
Re: What parts can be share between V70R and S60R (firehawk618)
Pretty sure V70R front bumper is different from S60R front bumper - this is why they had issues with the first Bell Intercoolers produced. They designed it using a V70R as a test dummy, then had issues fitting the same kit to S (mainly because of chassis differences, but believe those chassis differences flowed into the bumper as well)
Rear anti-roll bar on V70R is 2mm thicker (25 vs 23mm I believe). It is completely compatible on the S60R, a stealth upgrade indistiguishable by a dealer and a 25mm rear bar was/is sold as the "stage 1 upgrade" by ipd. If you can find a V70R owner who has upgraded their bar, good opportunity to pick up their stock one cheap. <p>Headlights and foglights are the same. <p>Aftermarket exhausts are different, V70Rs exhausts need to have an extra 2" in length (note there is a corresponding 2" of extra leg room you get with a longer exhaust).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>j-velocity</b> »</i></TD></TR><TR><TD CLASS="quote">Hi,<br>I am wondering what aftermarket/mod parts can be share between the V70R and S60R?<br>I know engine, brake and drive train parts are the same but what about suspension and body parts?<br>Thanks</TD></TR></TABLE><p>Almost all of the suspension is the same<br>Exhaust is 2" longer on the V<br>Body is exactly the same from the B pillar forward
Agreed everythign is the same B billar forward.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Fixed it for ya.</TD></TR></TABLE><p>Well, the back seat area (rearward of the FRONT seats) is different. Not sure if that's what you were saying or not. <p>Edit, as others noted, B pillar forward.
Re: What parts can be share between V70R and S60R (jdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>jdog</b> »</i></TD></TR><TR><TD CLASS="quote">Pretty sure V70R front bumper is different from S60R front bumper - this is why they had issues with the first Bell Intercoolers produced. They designed it using a V70R as a test dummy, then had issues fitting the same kit to S (mainly because of chassis differences, but believe those chassis differences flowed into the bumper as well)</TD></TR></TABLE><p>No, they are the same.
Re: What parts can be share between V70R and S60R ("R" Kelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>"R" Kelly</b> »</i></TD></TR><TR><TD CLASS="quote">Rear anti-roll bar on V70R is 2mm thicker (25 vs 23mm I believe). It is completely compatible on the S60R, a stealth upgrade indistiguishable by a dealer and a 25mm rear bar was/is sold as the "stage 1 upgrade" by ipd. If you can find a V70R owner who has upgraded their bar, good opportunity to pick up their stock one cheap. <br></TD></TR></TABLE><p>Actually, the rear bar on the SR is 21mm and the VR's is 22mm (at least for '06 & '07) - so putting the rear VR bar on the SR is a waste. For '04 & '05, the rear bars are 20mm and 21mm, respectively.<p>You can get the 25mm bar by itself from IPD (which is the V70R "Neutral Handling" bar) and add it to the SR for a nice difference. I left the stock 23.5mm front bar on and added the 25mm rear bar only - really helps with the under-steer.
Re: What parts can be share between V70R and S60R (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Well, the back seat area (rearward of the FRONT seats) is different. Not sure if that's what you were saying or not. <p>Edit, as others noted, B pillar forward. </TD></TR></TABLE><p>Yes that was my roundabout foreign way of trying to say B pillar. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> <p>
So the S60R front, side and rear from Evolve would also fit a V70R?<br>THe part number for lowering springs for V70R and S60R are different though.
Discussion Starter · #13 ·
any one?
Re: (j-velocity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>j-velocity</b> »</i></TD></TR><TR><TD CLASS="quote">So the S60R front, side and rear from Evolve would also fit a V70R?<br>THe part number for lowering springs for V70R and S60R are different though.</TD></TR></TABLE><p>NO. READ the replies. The bodies are the same from the B pillar FORWARD. The V is TWO INCHES LONGER. The rear bumper/apron is different also. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <p>
Re: (j-velocity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>j-velocity</b> »</i></TD></TR><TR><TD CLASS="quote">So the S60R front, side and rear from Evolve would also fit a V70R?<br>THe part number for lowering springs for V70R and S60R are different though.</TD></TR></TABLE><p>Don't you think if they did, some, many would have done this?<br>Have you seen ONE single Evolve wagon?<br>As I and others have said <B>"B" pillar forward is the same, </B>the wagon chassis is 2" longer.<br>If you don't know what a "B" pillar is, it's the rear portion of the FRONT door
1 - 16 of 16 Posts
