1 - 12 of 12 Posts
Moderator
Very curious to see what people have swapped from the Volvo family? List Factory parts only.
13-14 XC90 Gauge cluster LCD
12-14 XC90 Transmission cooler
12-14 XC90 Sport wheel
07+ XC90 Top Hats
07+ P2 Interior Vent Trim
07+ P2 Wheel & Stalk trim
06+ D5 Oil cooler
05+ P2R Euro lenses
04-05 P2R OTE pipe
04 E5 Glass
I think I have XC90 axle bolts and electrocic module cover at the rear, sorry forgot the name.
Moderator
Can you post some pics?
Sorry, should have been more clear, this thread is merely to list what you have swapped from the Volvo Family.
All of swaps listed can be found in previous posts from me or other members.
XC90 sport wheel
05+ console
OEM subwoofer
aeroblade roof crossbars
2002 Ocean Race floormats
headlight euro glass
updated PCV banjo bolt
late style AC compressor (05 or 06 got it can't recall)
160A alternator
P1 single piece exhaust manifold gasket
05+ PS reservoir.
Mudflaps
No plans to upgrade the front brakes to add the anti-rattle plate.
Do you have some links to said threads/posts?? Started searching only found 1 related to XC90 anything.
https://forums.swedespeed.com/showthread.php?229733-Information-Thread-About-OEM-Auxiliary-Transmission-Cooler-Accessory&p=2516972&viewfull=1#post2516972
04 E5 Glass
https://forums.swedespeed.com/showt...-Volvo-Glass&p=2820769&viewfull=1#post2820769
Whatever the tech short name is accurate, the questions is: have you installed the security laminated glass is the doors??
Moderator
04 E5 Glass
Which ones are you looking for? A lot of the stuff I found was site searching Swedespeed through google, I haven't documented alot of my stuff only because the amount of time I actually take to do things is far longer than most.
I have installed E5 Glass on my R, it's not hard at all you just need to make sure you buy new window regulator clips. The job takes about 3-4 hours being cautious. (Youtube videos of door trim removal helps a ton too)
XC90 Cooler + Harness revamp
https://forums.swedespeed.com/showt...in-IC-XC90-Cooler-Snabb-Spacers-amp-Tons-more
XC90 LCD swap
https://forums.swedespeed.com/showthread.php?580361-XC90-Executive-face-cluster-swap
Oh, I forgot triplex door glass from XC panels and eCode headlights. Probably because they still to be installed :D
[/url]
Do you need to buy a window rubber "gasket"? I think I've heard that because glass is thicker this part is different.
Did you do S60 or V70? I'm debating if I should do it myself or give it to the Volvo shop do it? They said rear ones are PITA.
1 - 12 of 12 Posts
