1 - 14 of 14 Posts
Re: What is towing capacity for the 2007 I-6 AWD XC90? (1sttimevolvo)
"When properly equipped" will tow up to 5,000 lbs? Meaning equipped with the V8?
According to 2006 specs, the 2.5T will tow 4,000 while the V8 will tow 5,000......
Ben
Every XC90 I've ever owned/read about has the same 5,000 lb towing capacity. This is much the same for most SUVs and their variants. The reason for this is typically (not always) because it is the suspension that defines the towing limit, not the engine.
Re: (rollie)
Quote, originally posted by rollie »
Actually, the limit is typically defined by a combination of the chassis, brakes, transmission and engine.
The chassis is the same for all models of XC90.
All the gas engines available on the XC90 (2.5T, T6, V8 and the newer I6) are sufficiently powerful to pull 5000 lbs. Of course, the 0-60 times will be different and they will behave differently when facing a big steep hill. But, overloading a mechanical device (transmission and engine) for too long can cause failures.
IMHO, the biggest limiting factor in the XC90 are the brakes. You need to be able to control and stop that load when needed...
Re: (ig_mb)
Thanks all for your input.
The reason I ask, my wife and I are considering an XC90 to replace our Sequoia (see my other thread).
We've got a 2001 Coachment Catalina Lite 249QB travel trailer, sitting at 4325# in the driveway with full propane tanks. I believe tongue weight is right about 500#. Trailer has electric brakes, and I have a Reese Dual-Cam anti-sway hitch with weight distribution.
I read that the 5000# mark is intended for up to 300# of passengers and gear....if you go between 200-600lbs, max towing drops to 4500#. Past 600# in the tow vehicle, the trailer rating drops to 3700#s......I Understand.
My wife, I, the dog, and some gear (plus the weight of the Reese Dual-Cam hitch components) would put us near, but under 600# in the truck.
Loaded with some food, gear, etc, the camper would be near, but under 4500#. We wont be carrying water or sewage either direction;)
The 24' trailer is within acceptable length for the truck....based on Wheelbase, overhang, etc.
So, we're nearly maxed on all fronts, and I understand that. Near max weight, tongue weight, etc.
No, the XC90 is not the ideal tow vehicle for this trailer, BUT......we're only going to be towing this a few (2,000 miles, maybe?) per year ......not like we're traveling the country 12 months a year. I'd much rather drive an XC90 than the Sequoia.....and I cant afford a seperate tow vehicle.
I imagine the V8 would be most ideal for towing.......how about the new I6? Is towing with the turbos safe, or is it just asking to fry a turbo?
If the XC90 doesnt work, we'll probably buy a V8 Touareg, which is a bit smaller but rated for 7700# towing, so we have more "margin" though I realize many of these ##s are simply made-up in the first place.
Personally, I'd buy the Touareg for your towing. It will drive like a RWD SUV (the XC90 drives like a FWD), it has a wider track (more stable), better brakes (multi-piston Brembos with larger rotors), better turning radius (by 2 feet), wider tires (better footprint), and it weighs 500 pounds more. It's simply a better TOWING vehicle.
Re: (Emission)
Quote, originally posted by Emission »
Touareg problems at clubtouareg.com
http://www.touaregproblems.com/
Yannis
Re: (GrecianVolvo)
Yannis,
With all due respect (and I respect your knowledge quite a bit), my VW's (I've had several) have all been much more reliable than my Volvo's (I've had two). My XC90 is the least reliable car or SUV my wife and I have owned in the past five years! Yes, some Touaregs are lemons, but the same can be said about the XC90. The XC90 is a great SUV, but it is far from flawless.
You really can't argue against my point when I say the V8 Touareg is a better tow vehicle - regardless of reliability.
- Mike
Re: (Emission)
if it doesn't run - it can't tow - I owned an '85 Audi 5000 and an '85 Volvo 740 - I stayed far away from VAG products ever since. The cars were night and day difference. VAG can build good engines but the entire rest of that '85 Audi was crap. Volvo does bother me with this VADIS stuff. I think the Toyota he has would make a better towing vehicle then either the VW or Volvo (admittedly I haven't checked its towing capacity). The only reason to me replace it is to get Volvo's safety features - which is a very good reason.
Discussion Starter · #13 ·
Re: (swedishiron)
Thanks to all for the input thus far.
Regarding reliability of VW versus Volvo....
I've currently got a '96 Jetta w/ 185k on it, as well as an '05 Passat with about 12k.....love 'em both. I had an '03 Jetta VR6 that VW bought back because they couldnt fix an oil leak it had. There are good and bad apples in each bunch.
The Touareg had a ton of problems in 2004 when it was introduced......the 2005s were better, and 2006 has been very good thus far. This info courtesy of VWVortex, and confirmed by my service advisor at Betten Imports VW/Volvo in Grand Rapids, MI. He said that the '04 Touareg had a lot of problems, but that there are fixes for all the "bugs" at this point.......
In all honesty, I like the interior (size and styling) of the Volvo the best. BUT, it really is not an optimal tow vehicle for our camper......the Touareg is a nice vehicle, and may suit us just fine if I can locate a nice V8 to procure for a test drive (the only example the dealer had was a used V6 with vinyl, yuck!).
As for the Sequoia--yes it may be a better tow vehicle (as far as stability, as far as power both the XC90 V8 and Touareg V8 will pull much easier)........but Toyota reliability (on the Tundra/Sequoia) is perhaps not as incredible as everyone thinks, at least for 2001/2002 years. Lots of A/C problems, OD-planetary gears causing lots of transmissions to grenade, etc etc. Not a perfect vehicle, by any means, though ours has treated us well.
All in all, I'm a little leery of pulling a 5000 load with the XC90.....
Anyway, keep the thoughts coming!
Ben
Re: (Jettix2)
The newer Sequoias are actually very nice vehicles. They are the only Toyota model to recieve good headrest ratings too. And the V-8 appears on paper like it can't pull itself and a load around, but it does not seem to have any problems. Wheelbase and brakes are very important factors in towing that are often overlooked. Gets decent mileage for its size, and it has a lot of size.
1 - 14 of 14 Posts
