"+ Limiter XC90 274 356-5"<p> <A HREF="http://acctest.semcon.se/en-GB/XC90/styling/alu/VCC-290454.htm" TARGET="_blank">http://acctest.semcon.se/en-GB...4.htm</A><p>(2nd item on the parts list)<p>what dose this mean/do
Re: what is this? (v50xc90v70123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>v50xc90v70123</b> »</i></TD></TR><TR><TD CLASS="quote">"+ Limiter XC90 274 356-5"<p> <A HREF="http://acctest.semcon.se/en-GB/XC90/styling/alu/VCC-290454.htm" TARGET="_blank">http://acctest.semcon.se/en-GB...4.htm</A><p>(2nd item on the parts list)<p>what dose this mean/do </TD></TR></TABLE><p>This is a guess, but I would have to believe it's some kind of steering stop, or turn limiter. Since those are pretty big tires, I'd have to believe that you'd encounter some rubbing if you didn't limit the amount of steering angle you could have.<p>The R's have steering stops to limit rub due to the wide wheels and big offset needed to clear the Brembos.
Re: what is this? (needsdecaf)
I think decaf is right on the money. If you check out the standard 18" Atlantis <A HREF="http://acctest.semcon.se/en-GB/XC90/styling/alu/VCC-245888.htm" TARGET="_blank">here</A>, the same limiter is listed there as well.<p>Pay attention to note #2: "<i>2. Required if the car is supplied from the factory with 16' wheels.</i>"
Re: what is this? (ig_mb)
Yup..<p>The cars that come with base wheels don't have a limiter....<br>When upgrading, you must install one...
