1 - 8 of 8 Posts
hi ! i've got a radiator behind my front bumper but i don't know what is it , because it's a the place of Fmic is it an oil cooler ?
and is it possible to remove it for replace by a fmic ?
thanks
Modified by frenchs60r at 9:32 PM 4-18-2009
2005 V70R, Midnight Blue, M66
Re: what is this part behind my bumper ? nwb question! (frenchs60r)
It is an FMIC. Volvo R's have two intercoolers, the main one and the smaller one you see. Made for more marketing hype than actual performance and many install a single, larger intercooler.
Re: (frenchs60r)
BOTH get removed, one large FMIC is installed in place of them
Re: (frenchs60r)
Quote, originally posted by frenchs60r »
oh ok !!
is it better to upgrade to a only one aftermarket Fmic and to remove the stock fmic and disconnect the main intercooller ?
I think there will be a unanimous response to the affirmative. Of course, that all depends on how big of an aftermarked FMIC you get. 800 CFM seems to be the choice size.
Re: (frenchs60r)
oh ok !!
Modified by frenchs60r at 11:09 PM 4-18-2009
Yes. IMO the single most important mod you can do for consistent, reliable performance improvement.
Re: (Johnr352)
is it better to upgrade to a only one aftermarket Fmic and to remove the stock fmic and disconnect the main intercooller?
Yes, if changing the intercooler is necessary; because your climate is rather cool, I'm not sure you will experience the consistent improvement in performance that you would in a hotter climate.
Quote, originally posted by BeerEngineer »
Quote, originally posted by Johnr352 »
It may also depend upon how large of an increase in intercooling he really needs given the temps he is likely to see. Caen, Normandy sees average high temps in June, July, August, and September of 67, 70, 72 & 67 degrees Fahrenheit (19, 21, 22 & 19 Celsius). Source: http://www.wunderground.com/NO...glish
If you were the OP in Caen and you didn't take your car to the race track, would you still place an upgraded intercooler up front in your list of mods; for example, ahead of the TME catback that he's already planning on installing?
1 - 8 of 8 Posts
