1 - 18 of 18 Posts
Maybe it's a plug for auto trans?
Where is it exactly? Can't really tell by the pictures.
Add an arrow to your last pic from below.
In the second photo, you see the driveshaft in the top left corner, so it looks like this is far right side of the engine bay, looking from behind, underneath. So no, it can't be for An auto trans. Hmmmmmmm. This is peculiar.
I dont remember seeing that thing in mine when i changed my tcv out. and i was all over that whole area.
That is a very odd location to see a harness. The TCV and a couple of a/c pressure sensors are around there, but they are all 2-pin.
The only 6-pin connector behind the engine that I can think of is the front O2 sensor, which is plugged into another harness at the very back of the head, just above the transmission. We can safely say it's not that, because the CEL would be on if it were. The rear O2 sensor, same thing (and I'm not sure that's a 6-pin).
Where does the wiring go? Up to the firewall? Which way, if so? How much wire is there, a few inches, or a lot?
Is it connected to anything else? You can look at a wiring diagram if you know something that is on series with it.
You could have the O2 sensor connector for a Cali approved exhaust. They have another O2 sensor than the other states.
No, but it weird to just have an electrical connection dangling.
I checked the wiring diagram and the rear O2 sensor is a 4-pin connection. Is the Cali one that different, and if so, why isn't it on this car?
BTW, you can see the rear O2 sensor and its heat-protected harness at the top edge of the picture.
Its a giveaway connector.
Instead of coming up with variety of wiring harnesses to meet each and every variant of the car, sometimes these are left in place and a second pig tail is added to that connection in the factory in order to link to say, the different engines under the hood.
Nothing to worry about. You will find a number of these in a very base car unused.
1 - 18 of 18 Posts
