1 - 1 of 1 Posts
Discussion Starter #1
Hi, what is the resistance supposed to be for BLIS LED in the tweeter housing? I’m getting a fairly wide resistance in the mega ohm range, between 3 and 13 mega ohms in one direction and open in the other as expected.. what’s off is i’m getting nearly similar resistance readings touching directly on LED leads and after the diode and/resistor that’s inline. Both LEDs from both sides are reading approx the same well within mega ohm range. I believe my multi meter is reading high but that’s basically open circuit to the LIN bus test if true. Unfortunately I don’t have a known good to test for about a week or so while everyone is away. but i thinking that I may have a bad set of LEDs installed in my tweeters.
1 - 1 of 1 Posts
