1 - 11 of 11 Posts
We all know that adding lowering springs and aftermarket rims causes these problems. I know the most common solution to vibration is from rebalancing tires and inspecting rims for cracks. What other things have people tried that was successful to remove these two problems?
Re: What is the best way to remove Shimmy and Vibration? (Vash13)
Worn out driveshafts and loose engine struts are also common problem. Do you get vibration when accelerating, breaking, going straight with gear on or in neutral?<p>I experience some vibration when accelerating with 2nd gear - I have a bad feeling its the driveshaft vibrating. Those bastards cost over 2000 USD to change for both sides here in Finland.
i get a lot of vibration when revving at a stand still just over 2000 rpm
Re: What is the best way to remove Shimmy and Vibration? (mdms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mdms</b> »</i></TD></TR><TR><TD CLASS="quote">Worn out driveshafts and loose engine struts are also common problem. Do you get vibration when accelerating, breaking, going straight with gear on or in neutral?<p>I experience some vibration when accelerating with 2nd gear - I have a bad feeling its the driveshaft vibrating. Those bastards cost over 2000 USD to change for both sides here in Finland.</TD></TR></TABLE><p>going straight with gear
Re: (zerocover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zerocover</b> »</i></TD></TR><TR><TD CLASS="quote">Get better motor mounts. Or fill the ones you have. </TD></TR></TABLE><br>Or custom fab a brace.
Re: (zubilius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zubilius</b> »</i></TD></TR><TR><TD CLASS="quote">i get a lot of vibration when revving at a stand still just over 2000 rpm</TD></TR></TABLE><p>Funny you said this i have this also but Volvo said everything was fine its just an inbalance in the engine<br>
i get vibrations as soon as my gas pedal is touched... 5-10mph but soon dissapears after that ??? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
Re: (zerocover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zerocover</b> »</i></TD></TR><TR><TD CLASS="quote">Get better motor mounts. Or fill the ones you have. </TD></TR></TABLE><p><br>You can fill them with what ? do you have to lift the motor out to fill them >!?
Fill them with urethane, go to home depot and get something called window wield. Its cheap and almost pure black urethane. Fill the mounts and let dry for 2-3 days.<p>You need to remove the mounts to fill them.
1 - 11 of 11 Posts
