<br>I believe stock bolt has a shank length of <B>33mm</B> (14x1.5). Can anyone please confirm this or tell me the right shank length? TIA!
Re: (twowheelin)
Yes - alloy wheel lug bolts. <p>I did a search, and only came across my very own post a while back <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> , but I don't know where the h*ll I got that length from - so I am seeking independent verification that our stock alloy wheel bolts have a shank of 33mm.
Re: (Short Circuit)
Take one out and measure it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: What is our Bolt Length? (Short Circuit)
I can measure my lug bolts this evening. They are sitting in a box in my basement. In the meantime, do you think my wheels will fall off? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> Seriously, I have aftermarket wheels on right now.
Re: What is our Bolt Length? (MAC1LSR)
If you can verify the length, I would appreciate it. <p>If you aftermarket wheels are a different ET than the stock wheels, then the difference needs to be made up in a longer bolt. Similarly, if you're running spacers, then the difference needs to be made up in a longer bolt. If aftermarket wheel + spacers, then the difference needs to be made up in a longer bolt. So it all originates to the stock ET of our wheels and work it from there. The "work it from there" begins with the 33mm shank length bolt I believe our stock bolts are...
Just measured 2 of the OEM lug bolts from my V70R. Using a metric caliper, I measured exactly 32 mm from the bottom of the large beveled washer to the end of the bolt.
