1 - 9 of 9 Posts
Hey guys,
I was wondering what included into IAQS (internal air quality system)? Is it possible to add this feature to the car that doesn't have it from factory. And more important - does it make sense? The XC I'm parting out has IAQS and I was thinking .. if the only difference is control unit and filter I would like to try it..
Any thoughts?
Thx in advance
Iirc, its just a different filter and a different setting on the ccm. We had 1 r with and 1 without and noticed no difference.
Banned
The IAQS system has also an air-quality sensor that closes the fresh-air intake when outside air is poorer quality than inside (if the auto mode of recycler is enabled).
If you only use the filter, it will remove smelly odors from the air but it will not check the airquality.
Is this sensor located in the control unit or it's remote somewhere? Could someone post a drawing from VIDA?
That makes sense. In the end, we never noticed any advantage from the iaqs though. I had honestly hoped for more when we bought the car with it.
Some REALLY notice the difference, some do not. (I don't but I smoke)
I suppose it depends on how sensitive your eyes and nose are and if you have allergies
Banned
N° 37 is the sensor, you need motor (3), inlet housing (1) and the cable (40)
http://www.volvopartswebstore.com/s...=7876&ukey_driveLine=483&ukey_trimLevel=11150
Still don't know if you can let the airquality sensor do it's work then because you need the button I think with it's 3setting (off (always open), manual close, auto) v. 2 (close, open) on the climatepanel and SW for it to work. When you go from standard filter to iaqs filter you also need to alter this with vadis/vida.
1 - 9 of 9 Posts
