601 - 620 of 654 Posts
Decided to change front lower control arms with bushings. Took me about 3 hours to do both sides, including welding a bolt to new control arm for the headlight adjustment.
And guess what? The vibration which i had for 2 years is gone! During these two years i have changed both engine mounts, cv axles, struts, and some more things. Never would have thought that control arms can cause this much vibration.
Now i just need to change torque mount.
An update to this. Today had an 300 mile trip, and noticed an small vibration when accelerating. Thought that torque mount will fix this (was planning to change it during the winter). Anyways, at one point something went totaly wrong and now the vibration under acceleration feels like an washing machine when its going in full speed. When i stop and put in P, whole car shakes and rattles weirdly, after putting in N, all the noises and vibrations disappear. Looks like its time to put the c70 in winter sleep and start to remove the “good” old aisin 5 speed automatic transmission.
2007 S40 2.4i / 2007 C70 T5
That’s weird. Any typical bad transmission noises?
Only the vibration when its in P. But very unusual to be honest. Never heard or had anything like this. Gears shift with no problems.
Mine had a vibration under heavy acceleration. At that time I had new mounts with the exception of the transmission one. It stopped doing it when I replaced it.
What are the odds one of the mounts failed prematurely?. Because if there was an internal failure in the transmission that causes a severe vibration like that, by this point you should have heard something or made a new "inspection window" in the trans case.
All of the engine/trans mounts have been changed during last summer and during winter. I have driven something around 7k km (4-5k miles) since then.
Im surprised that there are no inspection windows, but something is wrong with the transmission for sure.
During next week will call guys who repair auto transmissions, will see what they can tell. Either this one is restorable or will have to look for a replacement one.
Oh and also noticed just now when im slowly driving, sounds like somekinda bearing or something at one point of rotation is making a weird noise. In the transmission ofcourse
P.S. I have been trying to find the cause of vibration since i bought the car, but it was bearable. Have changed both cv axles, mounts, control arms, struts.
Try jacking up the front of the car. Both wheels in the air, fire it up, put it in gear and you'll have a chance to find that weird noise. Plus, you'll will get a chance to film a video of how bad the engine/trans is shaking.
Yep, will try to do this monday when i have an access to a car lift.
Reactions: Facusan
New shoes! Continental Control Contact SRS mounted up on my $100 Mirzams. Also installed iPd swaybar end links up front and the Whiteline anti-lift kit on the LCAs. So far it’s an immediate improvement in handling with a little firmer ride.
Wheel Tire Car Land vehicle Vehicle
And my Snabb intake pipe arrived! Installed it during halftime. Love the sound and throttle response.
Reactions: Facusan
Did you have to trim the bracket like this to make it clear the A/C lines?
Right now it's not bolted down on the valve cover, and while it's basically up against the AC lines it's not making noise or anything...yet. I'm going to loosen the motor mounts, shove the motor as far forward as I can, and see if I can improve the fit at all. I'll trim the bracket if need be.
But overall I'm pleased, I get just a little more intake noise, and the throttle response is definitely better. I've also got the iPd air filter, GoVo ECU spacer, and a billet compressor wheel, so it all adds up.
Reactions: Facusan
Mine rubbed the A/C lines a little bit, but didn’t make any noise when it happened. I did what you said, pushed the engine forward as much I could and trimmed the bracket and got ~1/2 inch of clearance.
Update.
Drove with the c70 to gearbox specialists. They did a couple of test drives, put the car on a lift, checked everything. And they came to conclusion that the gearbox is fine, it just needs an oil change. They recomended to check the engine first. In the few upcoming weeks will remove the injectors and take them to test, got a feeling that one of them isnt working at all.
No idea why didnt i think of this in the first place.
P.s. Should i make a new topic about my c70 and adventures?
Update.
+1 about the oil change. Volvo says the trans oil is for lifetime (yeah..... of the warranty) which is simply outrageous.
Have you checked for DTC codes? any check engine light?
YES
YES
No DTC codes. Just to remind, i got a diesel engine, D5
Anyways, i havent checked the corrections of the injectors. Might check them in the weekend.
And must agree about the oil change. My plan was to change it during the winter.
Alright, will make an topic in the evening, will ad some pictures of the car aswell.
Reactions: Facusan
Scored a wind deflector with storage bag for $175 on offerup! Yeah, just in time for the rainy season.
It makes a great temporary prop to hold up the front of the headliner when it drops unexpectedly ;)
Reactions: Facusan
Intercooler and charge pipe upgrade day!
So, I finished installing the intercooler and charge pipes this afternoon. Installation took some time to get everything lined up, but overall it was simple. The charge pipe mounting points were a little bit off, didn't go all the way up against the block. But I managed to solve this by using longer bolts and extra washers as spacers. I only had to trim 1/4 inch of the lower grille tabs because they rubbed against the intercooler. Once I put all back together, the intercooler is almost unnoticeable. Only way to find out is if you either know how far back the stock IC is or if you compare it with a stock C70. So while there was still some daylight left, I washed the car and took it for a test drive during the evening.
Ambient temperature was 64F/17C. First drive was weird, it felt laggy and weak while driving through the neighborhood. Intake temps were barely a few degrees hotter than ambient. The hottest I saw it was 78F/25C, while parked idling with the A/C on for 15 minutes. But when I started driving, temps quickly dropped to almost ambient. After a few miles and a couple drive cycles, the engine responsiveness improved a lot, but not like before, kinda close, turbo lag is still more noticeable and definitely louder than before.
Then it was time to get on the "Mexican" freeway and OH BOY!, What a difference!, although the max boost pressure now only gets up to 8.5 psi (previously max recorded boost was 10 psi) butt-dyno results says it's definitely quicker than before. I reached 130mph with much less effort, either in 4th or 5th gear. This probably is because now the engine gets a denser intake air charge.
I also have a 70mm Porsche Throttle body I wanted to install today along with the intercooler and pipes. But I couldn't get the correct bolts to mount it to the plastic intake plenum.
Tire Wheel Car Vehicle Automotive tire
Furniture Outdoor bench Table Wood Outdoor furniture
Car Wheel Vehicle Vehicle registration plate Tire
I finally installed the Porsche throttle body. Turns out the stock plenum bolts are long enough.
Car Hood Motor vehicle Vehicle Automotive design
One difference I've noticed when compared to the stock TB, besides the 5mm bore diameter, is that the butterfly valve center is ~33mm away from the plenum instead of ~23mm of the stock unit.
Product Gas Household hardware Font Metal
Automotive tire Font Tire Gas Machine
So, this 10mm spacing and bore difference adds approximately 43.78 cm3 to the plenum volume. This probably helps achieving more power at high rpms.
I took the car for a test drive, And despite many posts saying this TB will make the throttle response more sensitive. To me, it feels the same when driving normally, but I've noticed a slight improvement at full throttle.
