381 - 400 of 525 Posts
yeah i think i paid $650 for that darn lower radiator hose alone. i should've just had them preventatively replace it when i had it in for the belts, cam seals and engine mounts like you did. coolant resevoir i did myself to save a few $
For those keeping score, I skipped the tranny flush and fill, hoping to NOT break the bank. Put a pretty good dent in it with:
Right inner CV boot...Right and left engine mounts...coolant reservoir...and lower radiator hose...all replaced to the tune of $1200 and change.
Dang...
Wanted to say that she is screaming for spacers. Do you got lowering springs or stock?
I would recommend to put on lowering springs and after that check how much space you got there to put on spacers.
I got lowering springs on and i could put max 12mm spacers in the rear and 15mm spacers in front, and hope for no rubbing. (thats on the to do list)
I replaced my passenger axle and outer tie rods today.
The boot was pretty trashed.
When I pulled the outer tie rods, I realized the inner tie rods are super loose, so I guess I need to order those too now.
Sent from my moto x4 using Tapatalk
Dang, if it's not one thing, it's a dozen!!! I'll go for the tranny fluid swap next week and hope this is "it" for a while ;)
2007 S40 2.4i AW55-50 / 2007 C70 T5 AW55-50
So, I have this spare complete intake manifold I got for free from the guy who sold me a complete T5 cylinder head. Of that head, I took valves, some tappets and the CVVT hubs to rebuild the original head of my C70.
A few days ago, I saw the Elevate T5 polished lower intake manifold online and with nothing to lose, decided to try to improve my spare manifold using a dremel and a few 60-grit sanding drums to smooth the casting defects. I know it won’t be the same as the Elevate. But i bet it will be better than stock for sure.
This is where I’m at now:
Discussion Starter · #390 ·
Port and polish is definitely an improvement. That looks like a fun project and can’t wait to hear how it turns out.
Replaced my inner tie rods now and got an alignment.
They were supposed to replace my tires, but ordered the wrong size. Ugh.
Now I need to tackle the rear tire wear issues. I rotated the backs up front and sounded and felt like I was driving a mudding truck. Major uneven wear.
Being that my car came from a state without front plate requirements, it lacked the holes in the front bumper and the plate bracket that goes along with it.
I really wasn't looking forward to drilling holes in my bumper, but then I found these folks: https://www.cravenspeed.com/
They make the Platypus plate mount.
It connects to the car via the existing bumper port where you would connect a towing and recovery eyelet.
My annual lube job
As Dr. Ruth always said: "lubrication, lubrication, lubrication"
and some moisturizing with gummi pflege as well
I did the same thing yesterday, and also applied wd40 lithium grease to the roof hinges and locks.
And today I took the car to Firestone for a wheel alignment. And it seems like I will have to buy rear adjustable upper control arms.
I got 2 new tires up front.
now that everything is freshened up I can hear the roaring of a bad wheel bearing. I was hoping it was the uneven tire wear from the bad axle and worn out tie rods. No such luck.
i have a 2008 and am waiting to replace wheel bearings... i've done pretty much every other common P1 maintenance issue except the wheel bearings (@110k miles)
I just turned 120,000 miles.
The problem I'm having is I can't find the right bearing removal tool for the c70. Might have to pay a shop to install it for me. I can only see to find the 82mm tool, not the 78mm.
Damn press in bearings.
The correct tool is right here: https://www.amazon.co.uk/Laser-5568-GEN2-Wheel-Bearing/dp/B00FFW72C2 but it costs ~$390 USD.
If you take it to a "regular" shop to have replaced. they will most likely will do it the wrong way.
In the S40/V50 section, there's this Front bearing replacement write-up where the OP offers this tool for "rent/loan"
Yeah, the tool itself is way too expensive for a one time use (unless you plan to keep the car for a long time).
whoever is responsible of this wheel bearing design, made sure to get the worst design possible.
