Just like topic says, I totaled my v70 R and it might be possible I will buy it back from insurance. I am no expert but engine is a streight drop to 98-00 correct?
What about suspension ( brakes ) tranny and differential?
Thanks a lot!
You can use the engine and (manual) transmission with a bit of work and some slight modifications. Read some of these threads for starters:
http://volvospeed.com/vs_forum/topic/154256-rn-motor-install/
http://volvospeed.com/vs_forum/topic/154869-rn-engine-swapcouple-last-minute-qs/
You can use the R brakes on the rear, but the front calipers are too wide. The discs will work fine up front with a set of Porsche/Brembo 4 piston calipers and CJ Yother's (sold through IPD) adapter brackets.
Brackets: http://www.ipdusa.com/products/8251/111170-big-brake-kit-caliper-brackets-850-70
Here's BBK info: http://volvospeed.com/vs_forum/topic/118814-bbk-calipers-what-will-fit/
None of the suspension or AWD/Haldex stuff will work.
Where are you located?
Sorry to hear about the R. Hope you're ok. I don't know the answer to your questin but Please try to get the subwoofer wiring harness located in the trunk. I need one for my OE subwoofer. Kindly PM me if you decide to sell parts off the car. thx.
