Is there a specific year/part number I should be searching for? How about the flywheel? Any ideas on sourcing?
I'm building up a B20 with an M41 O/D.
Thanks!
Re: What bell housing need to convert from auto to manual? (gdill2)
I looked there - great resource that you guys turned me on to - but didn't see anything about the bellhousing required. Sorry if I'm not caffeinated yet and am missing it.
Re: What bell housing need to convert from auto to manual? (tdskip)
There are two basic bell housings: B18 type for hydraulic clutch, and B20 type for cable clutch. There's an early and late version of the B18 type, the later one ('66 on ???) accommodates the additional brace that bolts to the bottom of a B20 block. Your choice...
Flywheel depends on the year of your B20. '69-'73 uses a flywheel held on by six bolts, '74-'75 used eight bolts. B18 and six bolt B20 flywheels are the same, except that early B18 ones didn't have dowels to help center the clutch properly.
I'd check with Mike Dudek and see what he might have lying around...
http://www.irollmotors.com/
Re: What bell housing need to convert from auto to manual? (Phil Singher)
Thanks Phil - I have some digging to do to make sure I have the right bits identified.
