1 - 9 of 9 Posts
My sister just picked these up for her S40 for winter (like new, came with17" Hakkas and TPMS) for $375. Supposedly off a C30, but I've never seen them. Name?
Not Sure :
Is there a Freaking Way to Turn Off that - BS - TPMS / I mean really It warns someone when there is like 20 psi left in the Tire - ( Get Freakin Real ) Ddddaaaaaa - I
Think My Tire might be low . Yeah Think !
Let Me say - I'm not knocking Your - per-say TPMS , I just don't like the way it was Jammed down out throats , due to Socker Moms not checking their
Air Pressure . The they put an Expensive Item out to - don't Warranty the Item Properly and also allow it to - throw warnings a little Too Late .
Yeah, it was a deal for sure! Good thing her big brother scours craigslist all day looking for deals for her! :p And EngTech - agreed that TPMS are annoying and more of a hassle than anything. Here in VT, a shop won't pass a car for inspection if the TPMS light is on (say if one has winter wheels without TPMS - no dice). Stupid!
Those are Volvo wheels.
/thread
............................................________
..............?.....__.........................................:`.........../
............./__.(....."~-,_..............................,:`........../
.........../(_...."~,_........"~,_....................,:`........_/
..........{.._$;_......"=,_......."-,_.......,.-~-,},.~";/....}
...........((.....*~_......."=-._......";,,./`..../"............../
...,,,___.`~,......"~.,....................`.....}............../
............(....`=-,,.......`........................(......;_,,-"
.............`~.*-,.....................................|,./.....,__
,,_..........}.>-._...................................|..............`=~-,
.....`=~-,__......`,.................................
................................`:,,...........................`..............__
........................................_..........._,-%.......`
Down in Fla or TN - there is No Inspection , Not even Brakes , so I Guess they Feel the Dumber Ones will just be Eliminated for the Gene Pool ! LOL
Pull The Bulb on the Dam -TPMS- Units
What really gets Me , at the Tires shops : Oh, those need a New Seal Kit to go on those TPMS Units : Ching , Ching $10.95 - $19.95 per wheel
Found it:
Aluminum rim "Phorbas" 7 x 17". Facts and Advantages Prepared for use with SST (Self Supporting Tire) in combination with TPMS (Tire Pressure Monitoring System). Technical data Offset: 52.5 mm (2.1 in) Rec. tire size: 205/50 R17 Color code: 936 (Silver Bright) Accessory weight: 11.1 kg (24.5 lbs)
Part # 30672916
Nice find pczeilon! Thanks for the info.
1 - 9 of 9 Posts
