Good afternoon fellas,
I was hoping you guys could tell me what the size of the replacement rotors are that I should be buying for my 2007 S60 2.5T AWD.
Thank you,
Craig
Thank you. What size should I be buying as replacements for the front and back?
rears should be the same size between all non R s60s. However to confirm your front rotors, you will have to measure. 11"(286mm) or 12"(305mm).
Take a front wheel off and simply measure the diameter of the rotor.
So is that the T5 has 305mm rotors and the non-T5 (like the 2.4T) has the 286mm rotors? Volvo had to draw the line somewhere. What gives?
