Hi,
the return pipe through the tank cap is done and installed. It takes a while to validate because the tank was full.
I am struggling with another problem and have no ideas anymore. My motor speed start to oscillate between 1000 – 2200 rpm.
It happens with Map pressure below 70 kpa. The lower the speed the worse it is. The frequency of the wave (one sinus) has around 2-2,5Hz.
At the beginning I thought, it is because of the ignition advance or because of jumping between two VE blocks. I tried many things:
Ignition:
- Fix ignition timing at 15° - little improvement
- Different values in the ignition table - no improvement
- Different dWell timings for the coil - no improvement
- Other ignition coil - no improvement
- Different positions (rotation) of the ignition distributor - no improvement
- I installed my old 123-Ignition distributor so ignition was separated to the MS2 – no improvement
- I checked the ignition timing with the strobe light over the complete speed range – Ok
Injection:
- Different timing of the injection (0-360 and -360 back to -0 „Start of point“ and End of point“ ) - no improvement
- Set combustion to very rich (AFR 13) in the problem range - no improvement
- Change VE table to very low steps +/-1 in the problem range – no improvement
- EGO on/off – no improvement
- Change mode to untimed injection – worse
- Change to semi sequential (disconnected the cam signal) – worse but not so worse than untimed injection
- Change to Alpha/n mode instead of speed density – no improvement
- Different pressure of the fuel up to 43psi – no improvement
- AE (Acceleration enrichment) on/off – no improvement
- Installed a vacuum referenced FPR (30 psi without vacuum) – no improvement
- Checked my AFR sensor with a second sensor and controller – both show the same values
- All spark plug has the same color
Sensors:
- Change the sensor Lag value between 10-100% to filter the Map and Speed signal – maybe a very little improvement when I set Map to 10%
A big different I can see is with the „over run fuel cut“. When the fuel cut is off, my engine has the speed oscillating during coast mode.
This speed oscillating is gone when I turn on the fuel cut function without activation delay. I guess the problem would be there in both situations
(fuel cut on/off) when something would be wrong with the rest of the car (clutch, power train or gearbox).
The problem started with the fuel injection. The old installation with the carburetors didn’t have the problem. Even with ignition only over the MS2 was okay.
The oscillating frequency is always around 2-2,5 Hz. I am not sure if the frequency change with the motor speed but it looks like it is always the same.
My two next steps will be:
- Checking the injector supply voltage with a scope during oscillating
- Replace the injectors with the same 036 type
Do you ever faced a problem like this or have any ideas?
Thomas
