1 - 20 of 20 Posts
I was getting my 60K service, that (i have to brag on this one)i paid only $200 for at a certified volvo dealer "the volvo store" because my cousin is one of the master techs there...but anyways the were changeing the spark plugs and found alot of oil around the ignighters, thinken "oh u have a oil leak" so they replace the oil cap seal, come to find out this little plactic tube piece next to the cap was cracked...an oil air valve they called it???? well....would that be coverd under the CPO warentee? heres a pic below to give you an idea.<p><IMG SRC="http://i183.photobucket.com/albums/x53/myvolvo2006/untitled-4.jpg" BORDER="0">
Man, if you get a full PCV job done under warranty... I'm gonna be so jealous! My car needs a PCV job sometime sooner-than-later.
Re: (StarmanDXE)
HELLLLLLLSSSSS YEAAAAAAAAAA the volvo store just called me and they approved it under my cpo <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> ....0, nada....zilch. They said it would be about $650+ if i didnt have my cpo warrantee. They were saying something that since i have a turbo, i could end up blowing my seals.....ill see if thell allow me to take pics when its back in the show...the tech said he has to take the manifold off and all the other stuff... 5 hr job work it said.
Re: (StarmanDXE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StarmanDXE</b> »</i></TD></TR><TR><TD CLASS="quote">Man, if you get a full PCV job done under warranty... I'm gonna be so jealous! My car needs a PCV job sometime sooner-than-later.</TD></TR></TABLE><p>oh and whats a pcv?
Positive crankcase ventilation.
Re: (Max Wells)
They just tend to clog after enough time. And I don't know how good the previous owner was about oil changes.
Re: (StarmanDXE)
yaaa. i mean i had no idea that just to change a simple plastic part would be so much trouble. but im just glad im not out of pocket... i think labor is like $112 a hour!!
Yea its kind of labor intensive job,<br>parts are around $250<p>Think it took me 4-5 Hours to do mine, but I kind of cleaned things as I pulled them off<p>
Was it a bad job? I hope to do my own (someday) as I value my time at <$100/hr... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"><p>Any idea if there are any write-ups? I've seen some for an 850 (I believe), but wasn't sure if it was similar enough (which it probably is).
Basically you take off the intake and its there under neigh it.<p>Look in Vadis for removing the Intake, I don't think I have seen any right ups for the PCV box for the S60, But maybe theres one for a S70/V70, they are almost similar. <p>The job was not bad, There is one special tool to disconnect the fuel line, It was $16 from the dealer and I've used it a few times now. <p>A few of the bolts on the intake are kind of difficult, So make sure you have a few universal joints for your sockets and various size extensions.
4 hours!? It took me and my Volvo afficionado-friend less than 90 minutes to do the whole job of changing the flame trap and cleaning the lines.
Re: (Paysts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Paysts</b> »</i></TD></TR><TR><TD CLASS="quote">4 hours!? It took me and my Volvo afficionado-friend less than 90 minutes to do the whole job of changing the flame trap and cleaning the lines.</TD></TR></TABLE><p>Well I took my time, Cleaned the intake, Throttle Body, the hallow bolt that goes into the intake (forget what thats called), Then It took me some time to find the right size hose clamps for all the lines.<p>- Hey it was my first time, I'm sure now I could go it a lot faster now that I know where everything is and things I learned the first time
Re: (Paysts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Paysts</b> »</i></TD></TR><TR><TD CLASS="quote">4 hours!? It took me and my Volvo afficionado-friend less than 90 minutes to do the whole job of changing the flame trap and cleaning the lines.</TD></TR></TABLE><p>I call bullcrap <IMG NAME="icon" SRC="http://********************/smile/emthdown.gif" BORDER="0"> <p>on a older car yes on the p2 no way . <p>I just did one Monday took me over 2hrs todo<p>frak that banjo bolt <p>maybe less if the engine wasnt so freaking hot
Re: (Chilled Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Chilled Man</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I call bullcrap <IMG NAME="icon" SRC="http://********************/smile/emthdown.gif" BORDER="0"> <p>on a older car yes on the p2 no way . <p>I just did one Monday took me over 2hrs todo<p>frak that banjo bolt <p>maybe less if the engine wasnt so freaking hot </TD></TR></TABLE><p>Well bring your car down to El Paso, TX and we'll charge you 3 hours to do it, and put you in the office to watch the Godfather, and we'll have it out before Sonny gets killed. <p>I tell you, we've done the oil change on this car without the wrench, the back endlinks without any air tools in less than 1/2 hour, put the fuel injectors back in reusing the same o-rings.
Re: (Paysts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Paysts</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Well bring your car down to El Paso, TX and we'll charge you 3 hours to do it, and put you in the office to watch the Godfather, and we'll have it out before Sonny gets killed. <p>I tell you, we've done the oil change on this car without the wrench, the back endlinks without any air tools in less than 1/2 hour, put the fuel injectors back in reusing the same o-rings.</TD></TR></TABLE><p>how do you change oil without a wrench? o0o you have one of those oil suckers that go through the dipstick?<BR><BR>
<i>Modified by Cjones16 at 9:42 AM 8-15-2009</i>
Re: (Cjones16)
I think he means without the oil filter cap wrench.
Re: (Cjones16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Cjones16</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Wait Does that mean your shop does half-Azz work? (Not trying be mean just a question) and how do you change oil without a wrench? o0o you have one of those oil suckers that go through the dipstick?</TD></TR></TABLE><p><br>ehhh big deal if you acutally have some arm muscle you dont need one of those girly wrenches <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: (Chilled Man)
I always use one of those rubber thingy's that you use to unscrew the tops of cans off with to get that oil filter cover off. It does take about 5 good minutes of good ol' elbow grease but it does the job. I think I'm just to lazy and cheap to buy one of the wrenches.
Discussion Starter · #20 ·
Re: (StarmanDXE)
well i just got my car back..left it over night and its fixed...$0 being that its under the CPO warrantee...but the valve is rubber now..not plastic like b4??? ill post pics later <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
1 - 20 of 20 Posts
