My brother claims after going over a road "bump" the radio has stopped working <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> We pulled the radio out and all the connections are in; the fuse under the hood is good. But no power is goin to the radio; it wont turn on <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> Anyone has any ideas or suggestions before I have to pull the dash apart and check out the amp??? TIA, D
Re: Weird SC901 issues (GT854T5)
Did you check both ends of the wiring harness? Be aware that the typical SC-901 configuration includes the vehicle wiring harness, plus an adapter harness to put the external amplifier into the chain, and then the connection into the back of the '901. If you only checked the connections into the '901 without checking the other end of that wiring harness where it plugs into the vehicle wiring harness, then you might have missed a loose connection.<p>
Re: Weird SC901 issues (rothe)
Yeah, I will check all the other connection points; I dont see the car that often so wasnt able to do a full & through check out. It's my w/end project, so hopefully all goes well.
