I did some searching but couldn't find anything similar. I do not have a VIDA DICE scanner so I haven't been able to check for codes.
The car will not blow A/C or heat from any of the vents when auto is set. I can manually change between heat or A/C and I can set the individual vents and they work fine. But if I put it in auto, it goes back to not blowing out of any vents. Any help would be greatly appreciated.
I think your interior temp sensor is shot or dirty.
Actually a pretty common problem, most likely the physical switch is either jammed, or more commonly, the AC systems needs to be reset by the dealer. Purely software...
