1 - 11 of 11 Posts
Re: (tayk47)
If you do decide to fix it yourself, it's not too hard! <p>Simplified DIY: Just heat it up to loosen the glue, pry gently and then re seal.
Re: (tayk47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tayk47</b> »</i></TD></TR><TR><TD CLASS="quote">I'll have to remove the bumper to get at the assembly correct?</TD></TR></TABLE><br>Nope.<p> <A HREF="http://apps.volvocars.us/ownersdocs/2005/2005_S40/05s40_10b.htm#pg156" TARGET="_blank">http://apps.volvocars.us/owner...pg156</A>
Re: (biotek)
Did it mess up the headlight? I get condensation in mine because of the holes I drilled to run the ballast wires but the condensation goes away after a little while...no big deal...
Re: (tayk47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tayk47</b> »</i></TD></TR><TR><TD CLASS="quote">Mine has been there for a week and won't go away</TD></TR></TABLE><p>I have that in a fog but not the actual headlight. The headlight is super easy to disconnect from the car, but I've never taken one apart. Good luck!
1 - 11 of 11 Posts
