I read through several threads on installing a new wastegate actuator but I didn't see this specifically addressed. Does the lower turbo cooling line banjo bolt have to be removed to get the lower bolt out of the actuator bracket? I don't want to drain the cooling system if it isn't necessary but it seems I can't get that last fraction of an inch to get the bolt out.
No it does not have to be removed but it can be to make things easier.
Thanks! I got it out today without removing the cooling line banjo bolt. After loosening it with a wrench I was able to back it out most of the way with my fingers but had to use the wrench the last little bit once it hit the cooling line.
