1 - 6 of 6 Posts
Hello,
I'd like to replace both my lower control arms on the front of my R. Have 70k miles now, and the left, lower bushing is shot.
Has anyone attempted this repair? If so, did it require a spring compressor or any other fancy tools other than the sockets required to remove the arm from the subframe/steering knuckle? I'm not sure what will happen once I remove the lower control arms (will they be under pressure from the strut/spring, for example).
TIA,
Joe
Re: Want to replace control arms and ball-joints, any tips? (JoeLvo)
While I have not done it yet on the R, those would be some nice instructions to have around if you can find them.
I've done it twice on my 98 V70 GLT. I don't see how much more different it can be.
Without an R manual in front of me, with the weight off the wheels, the coil spring should be fully extended and no tension on the arms. You only need a spring compressor if you are replacing your struts.
When you install the new control arms. There will probably be some position tightening required on the hardware after you tighten it to the required torque value. You definitely need those specs.
On the GLT, after torquing the hardware, you turn it another it 120 degrees.
Then I'd say get a four wheel alignment.
Re: Want to replace control arms and ball-joints, any tips? (redalrt)
Perfect. Thanks! http://********************/smile/emthup.gif
Do you think the final turn (position) should be made with the suspension loaded, or is that not necessary?
I did it both times weight off the wheels.
1 - 6 of 6 Posts
