Volvo was historically known for safe and practical vehicles. However, now that they are focusing on luxury cars, I feel like there has been a serious decline in quality and reliability.
My 2013 S60 has had a lot of reliability problems, but luckily I was able to fix mahy of them myself.
At 20k miles, the fuel injectors failed. The spark plugs also had to be replaced due to fouling.
At 30-40k miles, the battery would drain and there would be constant "low battery" indicators.
At 50k miles, the transmission started having issues with slipping and hard shifting.
At 60k miles, it started burning engine oil excessively.
I fixed the low battery issue by removing the Siruis module and bypassing it with a MOST loop. The AM/FM radio doesn't work either after doing this, but I never used it anyways.
The oil consumption issue I repaired using additives, which isn't really the best solution. The dealership recommended an engine rebuild for $4000.
The transmission issue is also quite annoying to deal with. The dealership could not diagnose any problem. An independent shop could not figure it out either, and I will be taking it into the shop tomorrow.
