1 - 20 of 23 Posts
I don't recall anything like this list on SS as a technical resource. Disclaimer: I found this on a UK site: <A HREF="http://www.volvoforums.org.uk/index.php" TARGET="_blank">http://www.volvoforums.org.uk/index.php</A><br>============<p>Diagnostic Trouble Code (DTC)<p>Powertrain Codes <br>P0xxx Generic (SAE) <br>P01xx measurement of air and fuel <br>P02xx measurement of air and fuel <br>P03xx ignition system <br>P04xx additional emission control <br>P05xx speed and idle regulation <br>P06xx computer and output signals <br>P07xx transmission <br>P08xx transmission <br>P09xx control modules, input and output signals <br>P1xxx Manufacturer Specific <br>P2xxx Generic (SAE) <br>P30xx - P33xx Manufacturer Specific <br>P34xx - P39xx Generic (SAE) <p>Chassis Codes <br>C0xxx Generic (SAE) <br>C1xxx Manufacturer Specific <br>C2xxx Manufacturer Specific <br>C3xxx Generic (SAE) <p>Body Codes <br>B0xxx Generic (SAE) <br>B1xxx Manufacturer Specific <br>B2xxx Manufacturer Specific <br>B3xxx Generic (SAE) <p>Network Communication Codes <br>U0xxx Generic (SAE) <br>U1xxx Manufacturer Specific <br>U2xxx Manufacturer Specific <br>U3xxx Generic (SAE) <br><BR><BR>
<i>Modified by Short Circuit at 5:55 PM 8-5-2009</i>
Discussion Starter · #2 ·
Re: VOLVO P2 Diagnostic Fault Codes (Short Circuit)
P0001 Fuel Volume Regulator Control Circuit/Open<br>P0002 Fuel Volume Regulator Control Circuit Range/Performance<br>P0003 Fuel Volume Regulator Control Circuit Low<br>P0004 Fuel Volume Regulator Control Circuit High<br>P0005 Fuel Shutoff Valve C ontrol Circuit/Open<br>P0006 Fuel Shutoff Valve C ontrol Circuit Low<br>P0007 Fuel Shutoff Valve C ontrol Circuit H igh<br>P0008 Engine Position System Performance (Bank1)<br>P0009 Engine Position System Performance (Bank2)<br>P0010 A Camshaft Position Actuator Circuit (Bank1)<br>P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)<br>P0012 A Camshaft Position - Timing O ver-Retarded (Bank 1)<br>P0013 B Camshaft Position - Actuator Circuit (Bank1)<br>P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)<br>P0015 B Camshaft Position - Timing O ver-Retarded (Bank 1)<br>P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)<br>P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)<br>P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)<br>P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)<br>P0020 A Camshaft Position Actuator Circuit (Bank 2)<br>P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)<br>P0022 A Camshaft Position - Timing O ver-Retarded (Bank 2)<br>P0023 B Camshaft Position - Actuator Circuit (Bank 2)<br>P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)<br>P0025 B Camshaft Position - Timing O ver-Retarded (Bank 2)<br>P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)<br>P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)<br>P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)<br>P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)<br>P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)<br>P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)<br>P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)<br>P0033 Turbo Charger Bypass Valve Control Circuit<br>P0034 Turbo Charger Bypass Valve Control Circuit Low<br>P0035 Turbo Charger Bypass Valve Control Circuit High<br>P0036 HO2S Heater Control C ircuit (Bank 1 Sensor 2)<br>P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)<br>P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)<br>P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance<br>P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1<br>P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2<br>P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)<br>P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)<br>P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)<br>P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open<br>P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance<br>P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low<br>P0048 Turbo/Super Charger Boost Control Solenoid Circuit High<br>P0049 Turbo/Super Charger Turbine Overspeed<br>P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)<br>P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)<br>P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)<br>P0053 HO2S Heater Resistance (Bank 1 Sensor 1)<br>P0054 HO2S Heater Resistance (Bank 1 Sensor 2)<br>P0055 HO2S Heater Resistance (Bank 1 Sensor 3)<br>P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)<br>P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)<br>P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)<br>P0059 HO2S Heater Resistance (Bank 2 Sensor 1)<br>P0060 HO2S Heater Resistance (Bank 2 Sensor 2)<br>P0061 HO2S Heater Resistance (Bank 2 Sensor 3)<br>P0062 HO2S Heater Control C ircuit (Bank 2 Sensor 3)<br>P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)<br>P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)<br>P0065 Air Assisted Injector Control Range/Performance<br>P0066 Air Assisted Injector Control Circuit or Circuit Low<br>P0067 Air Assisted Injector Control Circuit High<br>P0068 MAP/MAF Throttle Position Correlation<br>P0069 Manifold Absolute Pressure Barometric Pressure Correlation<br>P0070 Ambient Air Temperature Sensor Circuit<br>P0071 Ambient Air Temperature Sensor Range/Performance<br>P0072 Ambient Air Temperature Sensor C ircuit Low<br>P0073 Ambient Air Temperature Sensor Circuit High<br>P0074 Ambient Air Temperature Sensor Circuit Intermittent<br>P0075 Intake Valve Control Solenoid Circuit (Bank 1)<br>P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)<br>P0077 Intake Valve Control Solenoid Circuit High (Bank 1)<br>P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)<br>P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)<br>P0080 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 1)<br>P0081 Intake Valve Control Solenoid Circuit (Bank 2)<br>P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)<br>P0083 Intake Valve Control Solenoid Circuit High (Bank 2)<br>P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)<br>P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)<br>P0086 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 2)<br>P0087 Fuel Rail/System Pressure - Too Low<br>P0088 Fuel Rail/System Pressure - Too High<br>P0089 Fuel Pressure Regulator 1 Performance<br>P0090 Fuel Pressure Regulator 1 C ontrol Circuit<br>P0091 Fuel Pressure Regulator 1 C ontrol Circuit Low<br>P0092 Fuel Pressure Regulator 1 C ontrol Circuit High<br>P0093 Fuel System Leak Detected Large Leak<br>P0094 Fuel System Leak Detected Small Leak<br>P0095 Intake Air Temperature Sensor 2 C ircuit<br>P0096 Intake Air Temperature Sensor 2 C ircuit Range/Performance<br>P0097 Intake Air Temperature Sensor 2 C ircuit Low<br>P0098 Intake Air Temperature Sensor 2 Circuit High<br>P0099 Intake Air Temperature Sensor 2 C ircuit Intermittent/Erratic<br>P0100 Mass or Volume Air Flow Circuit Malfunction<br>
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem<br>P0102 Mass or Volume Air Flow Circuit Low Input<br>P0103 Mass or Volume Air Flow Circuit High Input<br>P0104 Mass or Volume Air Flow Circuit Intermittent<br>P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction<br>P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem<br>P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input<br>P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input<br>P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent<br>P0110 Intake Air Temperature Circuit Malfunction<br>P0111 Intake Air Temperature Circuit Range/Performance Problem<br>P0112 Intake Air Temperature Circuit Low Input<br>P0113 Intake Air Temperature Circuit High Input<br>P0114 Intake Air Temperature Circuit Intermittent<br>P0115 Engine Coolant Temperature Circuit Malfunction<br>P0116 Engine Coolant Temperature Circuit Range/Performance Problem<br>P0117 Engine Coolant Temperature Circuit Low Input<br>P0118 Engine Coolant Temperature Circuit High Input<br>P0119 Engine Coolant Temperature Circuit Intermittent<br>P0120 Throttle Position Sensor/Switch A Circuit Malfunction<br>P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem<br>P0122 Throttle Position Sensor/Switch A Circuit Low Input<br>P0123 Throttle Position Sensor/Switch A Circuit High Input<br>P0124 Throttle Position Sensor/Switch A Circuit Intermittent<br>P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control<br>P0126 Insufficient Coolant Temperature for Stable Operation<br>P0128 Coolant Thermostat Malfunction<br>P0129 Barometric Pressure Too Low<br>P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)<br>P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)<br>P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)<br>P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)<br>P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)<br>P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)<br>P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)<br>P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)<br>P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)<br>P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)<br>P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)<br>P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)<br>P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)<br>P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)<br>P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)<br>P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)<br>P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)<br>P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)<br>P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)<br>P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)<br>P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)<br>P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)<br>P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)<br>P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)<br>P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)<br>P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)<br>P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)<br>P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)<br>P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)<br>P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)<br>P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)<br>P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)<br>P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)<br>P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)<br>P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)<br>P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)<br>P0170 Fuel Trim Malfunction (Bank 1)<br>P0171 Fuel Trim too Lean (Bank 1)<br>P0172 Fuel Trim too Rich (Bank 1)<br>P0173 Fuel Trim Malfunction (Bank 2)<br>P0174 Fuel Trim too Lean (Bank 2)<br>P0175 Fuel Trim too Rich (Bank 2)<br>P0176 Fuel Composition Sensor Circuit Malfunction<br>P0177 Fuel Composition Sensor Circuit Range/Performance<br>P0178 Fuel Composition Sensor Circuit Low Input<br>P0179 Fuel Composition Sensor Circuit High Input<br>P0180 Fuel Temperature Sensor A Circuit Malfunction<br>P0181 Fuel Temperature Sensor A Circuit Range/Performance<br>P0182 Fuel Temperature Sensor A Circuit Low Input<br>P0183 Fuel Temperature Sensor A Circuit High Input<br>P0184 Fuel Temperature Sensor A Circuit Intermittent<br>P0185 Fuel Temperature Sensor B Circuit Malfunction<br>P0186 Fuel Temperature Sensor B Circuit Range/Performance<br>P0187 Fuel Temperature Sensor B Circuit Low Input<br>P0188 Fuel Temperature Sensor B Circuit High Input<br>P0189 Fuel Temperature Sensor B Circuit Intermittent<br>P0190 Fuel Rail Pressure Sensor Circuit Malfunction<br>P0191 Fuel Rail Pressure Sensor Circuit Range/Performance<br>P0192 Fuel Rail Pressure Sensor Circuit Low Input<br>P0193 Fuel Rail Pressure Sensor Circuit High Input<br>P0194 Fuel Rail Pressure Sensor Circuit Intermittent<br>P0195 Engine Oil Temperature Sensor Malfunction<br>P0196 Engine Oil Temperature Sensor Range/Performance<br>P0197 Engine Oil Temperature Sensor Low<br>P0198 Engine Oil Temperature Sensor High<br>P0199 Engine Oil Temperature Sensor Intermittent<br>P0200 Injector Circuit Malfunction<br>P0201 Injector Circuit Malfunction - Cylinder 1<br>P0202 Injector Circuit Malfunction - Cylinder 2<br>P0203 Injector Circuit Malfunction - Cylinder 3<br>P0204 Injector Circuit Malfunction - Cylinder 4<br>P0205 Injector Circuit Malfunction - Cylinder 5<br>P0206 Injector Circuit Malfunction - Cylinder 6<br>P0207 Injector Circuit Malfunction - Cylinder 7<br>P0208 Injector Circuit Malfunction - Cylinder 8<br>P0209 Injector Circuit Malfunction - Cylinder 9<br>P0210 Injector Circuit Malfunction - Cylinder 10<br>P0211 Injector Circuit Malfunction - Cylinder 11<br>P0212 Injector Circuit Malfunction - Cylinder 12<br>P0213 Cold Start Injector 1 Malfunction<br>P0214 Cold Start Injector 2 Malfunction<br>P0215 Engine Shutoff Solenoid Malfunction<br>P0216 Injection Timing Control Circuit Malfunction<br>P0217 Engine Overtemp Condition<br>P0218 Transmission Over Temperature Condition<br>P0219 Engine Overspeed Condition<br>P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction<br>P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem<br>P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input<br>P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input<br>P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent<br>P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction<br>P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem<br>P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input<br>P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input<br>P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent<br>P0230 Fuel Pump Primary Circuit Malfunction<br>P0231 Fuel Pump Secondary Circuit Low<br>P0232 Fuel Pump Secondary Circuit High<br>P0233 Fuel Pump Secondary Circuit Intermittent<br>P0234 Engine Overboost Condition<br>P0235 Turbocharger Boost Sensor A Circuit Malfunction<br>P0236 Turbocharger Boost Sensor A Circuit Range/Performance<br>P0237 Turbocharger Boost Sensor A Circuit Low<br>P0238 Turbocharger Boost Sensor A Circuit High<br>P0239 Turbocharger Boost Sensor B Malfunction<br>P0240 Turbocharger Boost Sensor B Circuit Range/Performance<br>P0241 Turbocharger Boost Sensor B Circuit Low<br>P0242 Turbocharger Boost Sensor B Circuit High<br>P0243 Turbocharger Wastegate Solenoid A Malfunction<br>P0244 Turbocharger Wastegate Solenoid A Range/Performance<br>P0245 Turbocharger Wastegate Solenoid A Low<br>P0246 Turbocharger Wastegate Solenoid A High<br>P0247 Turbocharger Wastegate Solenoid B Malfunction<br>P0248 Turbocharger Wastegate Solenoid B Range/Performance<br>P0249 Turbocharger Wastegate Solenoid B Low<br>P0250 Turbocharger Wastegate Solenoid B High<br>P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)<br>P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)<br>P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)<br>P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)<br>P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)<br>P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)<br>P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)<br>P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)<br>P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)<br>P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)<br>P0261 Cylinder 1 Injector Circuit Low<br>P0262 Cylinder 1 Injector Circuit High<br>P0263 Cylinder 1 Contribution/Balance Fault<br>P0264 Cylinder 2 Injector Circuit Low<br>P0265 Cylinder 2 Injector Circuit High<br>P0266 Cylinder 2 Contribution/Balance Fault<br>P0267 Cylinder 3 Injector Circuit Low<br>P0268 Cylinder 3 Injector Circuit High<br>P0269 Cylinder 3 Contribution/Balance Fault<br>P0270 Cylinder 4 Injector Circuit Low<br>P0271 Cylinder 4 Injector Circuit High<br>P0272 Cylinder 4 Contribution/Balance Fault<br>P0273 Cylinder 5 Injector Circuit Low<br>P0274 Cylinder 5 Injector Circuit High<br>P0275 Cylinder 5 Contribution/Balance Fault<br>P0276 Cylinder 6 Injector Circuit Low<br>P0277 Cylinder 6 Injector Circuit High<br>P0278 Cylinder 6 Contribution/Balance Fault<br>P0279 Cylinder 7 Injector Circuit Low<br>P0280 Cylinder 7 Injector Circuit High<br>P0281 Cylinder 7 Contribution/Balance Fault<br>P0282 Cylinder 8 Injector Circuit Low<br>P0283 Cylinder 8 Injector Circuit High<br>P0284 Cylinder 8 Contribution/Balance Fault<br>P0285 Cylinder 9 Injector Circuit Low<br>P0286 Cylinder 9 Injector Circuit High<br>P0287 Cylinder 9 Contribution/Balance Fault<br>P0288 Cylinder 10 Injector Circuit Low<br>P0289 Cylinder 10 Injector Circuit High<br>P0290 Cylinder 10 Contribution/Balance Fault<br>P0291 Cylinder 11 Injector Circuit Low<br>P0292 Cylinder 11 Injector Circuit High<br>P0293 Cylinder 11 Contribution/Balance Fault<br>P0294 Cylinder 12 Injector Circuit Low<br>P0295 Cylinder 12 Injector Circuit High<br>P0296 Cylinder 12 Contribution/Range Fault<br>P0300 Random/Multiple Cylinder Misfire Detected<br>
P0301 Cylinder 1 Misfire Detected<br>P0302 Cylinder 2 Misfire Detected<br>P0303 Cylinder 3 Misfire Detected<br>P0304 Cylinder 4 Misfire Detected<br>P0305 Cylinder 5 Misfire Detected<br>P0306 Cylinder 6 Misfire Detected<br>P0307 Cylinder 7 Misfire Detected<br>P0308 Cylinder 8 Misfire Detected<br>P0309 Cylinder 9 Misfire Detected<br>P0310 Cylinder 10 Misfire Detected<br>P0311 Cylinder 11 Misfire Detected<br>P0312 Cylinder 12 Misfire Detected<br>P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction<br>P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance<br>P0322 Ignition/Distributor Engine Speed Input Circuit No Signal<br>P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent<br>P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)<br>P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)<br>P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)<br>P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)<br>P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)<br>P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)<br>P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)<br>P0332 Knock Sensor 2 Circuit Low Input (Bank 2)<br>P0333 Knock Sensor 2 Circuit High Input (Bank 2)<br>P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)<br>P0335 Crankshaft Position Sensor A Circuit Malfunction<br>P0336 Crankshaft Position Sensor A Circuit Range/Performance<br>P0337 Crankshaft Position Sensor A Circuit Low Input<br>P0338 Crankshaft Position Sensor A Circuit High Input<br>P0339 Crankshaft Position Sensor A Circuit Intermittent<br>P0340 Camshaft Position Sensor Circuit Malfunction<br>P0341 Camshaft Position Sensor Circuit Range/Performance<br>P0342 Camshaft Position Sensor Circuit Low Input<br>P0343 Camshaft Position Sensor Circuit High Input<br>P0344 Camshaft Position Sensor Circuit Intermittent<br>P0350 Ignition Coil Primary/Secondary Circuit Malfunction<br>P0351 Ignition Coil A Primary/Secondary Circuit Malfunction<br>P0352 Ignition Coil B Primary/Secondary Circuit Malfunction<br>P0353 Ignition Coil C Primary/Secondary Circuit Malfunction<br>P0354 Ignition Coil D Primary/Secondary Circuit Malfunction<br>P0355 Ignition Coil E Primary/Secondary Circuit Malfunction<br>P0356 Ignition Coil F Primary/Secondary Circuit Malfunction<br>P0357 Ignition Coil G Primary/Secondary Circuit Malfunction<br>P0358 Ignition Coil H Primary/Secondary Circuit Malfunction<br>P0359 Ignition Coil I Primary/Secondary Circuit Malfunction<br>P0360 Ignition Coil J Primary/Secondary Circuit Malfunction<br>P0361 Ignition Coil K Primary/Secondary Circuit Malfunction<br>P0362 Ignition Coil L Primary/Secondary Circuit Malfunction<br>P0370 Timing Reference High Resolution Signal A Malfunction<br>P0371 Timing Reference High Resolution Signal A Too Many Pulses<br>P0372 Timing Reference High Resolution Signal A Too Few Pulses<br>P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses<br>P0374 Timing Reference High Resolution Signal A No Pulses<br>P0375 Timing Reference High Resolution Signal B Malfunction<br>P0376 Timing Reference High Resolution Signal B Too Many Pulses<br>P0377 Timing Reference High Resolution Signal B Too Few Pulses<br>P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses<br>P0379 Timing Reference High Resolution Signal B No Pulses<br>P0380 Glow Plug/Heater Circuit "A" Malfunction<br>P0381 Glow Plug/Heater Indicator Circuit Malfunction<br>P0382 Exhaust Gas Recirculation Flow Malfunction<br>P0385 Crankshaft Position Sensor B Circuit Malfunction<br>P0386 Crankshaft Position Sensor B Circuit Range/Performance<br>P0387 Crankshaft Position Sensor B Circuit Low Input<br>P0388 Crankshaft Position Sensor B Circuit High Input<br>P0389 Crankshaft Position Sensor B Circuit Intermittent<br>P0400 Exhaust Gas Recirculation Flow Malfunction<br>P0401 Exhaust Gas Recirculation Flow Insufficient Detected<br>P0402 Exhaust Gas Recirculation Flow Excessive Detected<br>P0403 Exhaust Gas Recirculation Circuit Malfunction<br>P0404 Exhaust Gas Recirculation Circuit Range/Performance<br>P0405 Exhaust Gas Recirculation Sensor A Circuit Low<br>P0406 Exhaust Gas Recirculation Sensor A Circuit High<br>P0407 Exhaust Gas Recirculation Sensor B Circuit Low<br>P0408 Exhaust Gas Recirculation Sensor B Circuit High<br>P0410 Secondary Air Injection System Malfunction<br>P0411 Secondary Air Injection System Incorrect Flow Detected<br>P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction<br>P0413 Secondary Air Injection System Switching Valve A Circuit Open<br>P0414 Secondary Air Injection System Switching Valve A Circuit Shorted<br>P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction<br>P0416 Secondary Air Injection System Switching Valve B Circuit Open<br>P0417 Secondary Air Injection System Switching Valve B Circuit Shorted<br>P0418 Secondary Air Injection System Relay "A" Circuit Malfunction<br>P0419 Secondary Air Injection System Relay "B" Circuit Malfunction<br>P0420 Catalyst System Efficiency Below Threshold (Bank 1)<br>P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)<br>P0422 Main Catalyst Efficiency Below Threshold (Bank 1)<br>P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)<br>P0424 Heated Catalyst Temperature Below Threshold (Bank 1)<br>P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)<br>P0427 Catalyst Temperature Sensor Low Input (Bank 1)<br>P0428 Catalyst Temperature Sensor High Input (Bank 1)<br>P0430 Catalyst System Efficiency Below Threshold (Bank 2)<br>P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)<br>P0432 Main Catalyst Efficiency Below Threshold (Bank 2)<br>P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)<br>P0434 Heated Catalyst Temperature Below Threshold (Bank 2)<br>P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)<br>P0437 Catalyst Temperature Sensor Low Input (Bank 2)<br>P0438 Catalyst Temperature Sensor High Input (Bank 2)<br>P0440 Evaporative Emission Control System Malfunction<br>P0441 Evaporative Emission Control System Incorrect Purge Flow<br>P0442 Evaporative Emission Control System Leak Detected (small leak)<br>P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction<br>P0444 Evaporative Emission Control System Purge Control Valve Circuit Open<br>P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted<br>P0446 Evaporative Emission Control System Vent Control Circuit Malfunction<br>P0447 Evaporative Emission Control System Vent Control Circuit Open<br>P0448 Evaporative Emission Control System Vent Control Circuit Shorted<br>P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction<br>P0450 Evaporative Emission Control System Pressure Sensor Malfunction<br>P0451 Evaporative Emission Control System Pressure Sensor Range/Performance<br>P0452 Evaporative Emission Control System Pressure Sensor Low Input<br>P0453 Evaporative Emission Control System Pressure Sensor High Input<br>P0454 Evaporative Emission Control System Pressure Sensor Intermittent<br>P0455 Evaporative Emission Control System Leak Detected (gross leak)<br>P0460 Fuel Level Sensor Circuit Malfunction<br>P0461 Fuel Level Sensor Circuit Range/Performance<br>P0462 Fuel Level Sensor Circuit Low Input<br>P0463 Fuel Level Sensor Circuit High Input<br>P0464 Fuel Level Sensor Circuit Intermittent<br>P0465 Purge Flow Sensor Circuit Malfunction<br>P0466 Purge Flow Sensor Circuit Range/Performance<br>P0467 Purge Flow Sensor Circuit Low Input<br>P0468 Purge Flow Sensor Circuit High Input<br>P0469 Purge Flow Sensor Circuit Intermittent<br>P0470 Exhaust Pressure Sensor Malfunction<br>P0471 Exhaust Pressure Sensor Range/Performance<br>P0472 Exhaust Pressure Sensor Low<br>P0473 Exhaust Pressure Sensor High<br>P0474 Exhaust Pressure Sensor Intermittent<br>P0475 Exhaust Pressure Control Valve Malfunction<br>P0476 Exhaust Pressure Control Valve Range/Performance<br>P0477 Exhaust Pressure Control Valve Low<br>P0478 Exhaust Pressure Control Valve High<br>P0479 Exhaust Pressure Control Valve Intermittent<br>P0480 Cooling Fan 1 Control Circuit Malfunction<br>P0481 Cooling Fan 2 Control Circuit Malfunction<br>P0482 Cooling Fan 3 Control Circuit Malfunction<br>P0483 Cooling Fan Rationality Check Malfunction<br>P0484 Cooling Fan Circuit Over Current<br>P0485 Cooling Fan Power/Ground Circuit Malfunction<br>P0500 Vehicle Speed Sensor Malfunction<br>P0501 Vehicle Speed Sensor Range/Performance<br>P0502 Vehicle Speed Sensor Low Input<br>P0503 Vehicle Speed Sensor Intermittent/Erratic/High<br>P0505 Idle Control System Malfunction<br>P0506 Idle Control System RPM Lower Than Expected<br>P0507 Idle Control System RPM Higher Than Expected<br>P0510 Closed Throttle Position Switch Malfunction<br>P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction<br>P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance<br>P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage<br>P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage<br>P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction<br>P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance<br>P0532 A/C Refrigerant Pressure Sensor Circuit Low Input<br>P0533 A/C Refrigerant Pressure Sensor Circuit High Input<br>P0534 Air Conditioner Refrigerant Charge Loss<br>P0550 Power Steering Pressure Sensor Circuit Malfunction<br>P0551 Power Steering Pressure Sensor Circuit Range/Performance<br>P0552 Power Steering Pressure Sensor Circuit Low Input<br>P0553 Power Steering Pressure Sensor Circuit High Input<br>P0554 Power Steering Pressure Sensor Circuit Intermittent<br>P0560 System Voltage Malfunction<br>P0561 System Voltage Unstable<br>P0562 System Voltage Low<br>P0562 A/C pressure sensor low voltage(Chrysler)<br>P0563 System Voltage High<br>P0565 Cruise Control On Signal Malfunction<br>P0566 Cruise Control Off Signal Malfunction<br>P0567 Cruise Control Resume Signal Malfunction<br>P0568 Cruise Control Set Signal Malfunction<br>P0569 Cruise Control Coast Signal Malfunction<br>P0570 Cruise Control Accel Signal Malfunction<br>P0571 Cruise Control/Brake Switch A Circuit Malfunction<br>P0572 Cruise Control/Brake Switch A Circuit Low<br>P0573 Cruise Control/Brake Switch A Circuit High<br>P0574 Cruise Control Related Malfunction<br>P0575 Cruise Control Related Malfunction<br>P0576 Cruise Control Related Malfunction<br>P0576 Cruise Control Related Malfunction<br>P0578 Cruise Control Related Malfunction<br>P0579 Cruise Control Related Malfunction<br>P0580 Cruise Control Related Malfunction<br>P0600 Serial Communication Link Malfunction<br>P0601 Control Module Read Only Memory(ROM)<br>P0602 Control Module Programming Error<br>P0603 Internal Control Module Keep Alive Memory (KAM) Error<br>P0604 Internal Control Module Random Access Memory (RAM) Error<br>P0605 Internal Control Module Read Only Memory (ROM) Error<br>P0606 PCM Processor Fault<br>P0608 Control Module VSS Output "A" Malfunction<br>P0609 Control Module VSS Output "B" Malfunction<br>P0620 Generator Control Circuit Malfunction<br>P0621 Generator Lamp "L" Control Circuit Malfunction<br>P0622 Generator Field "F" Control Circuit Malfunction<br>P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction<br>P0654 Engine RPM Output Circuit Malfunction<br>P0655 Engine Hot Lamp Output Control Circuit Mal***ntion<br>P0656 Fuel Level Output Circuit Malfunction<br>P0700 Transmission Control System Malfunction<br>P0701 Transmission Control System Range/Performance<br>P0702 Transmission Control System Electrical<br>P0703 Torque Converter/Brake Switch B Circuit Malfunction<br>P0704 Clutch Switch Input Circuit Malfunction<br>P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)<br>P0706 Transmission Range Sensor Circuit Range/Performance<br>P0707 Transmission Range Sensor Circuit Low Input<br>P0708 Transmission Range Sensor Circuit High Input<br>P0709 Transmission Range Sensor Circuit Intermittent<br>P0710 Transmission Fluid Temperature Sensor Circuit Malfunction<br>P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance<br>P0712 Transmission Fluid Temperature Sensor Circuit Low Input<br>P0713 Transmission Fluid Temperature Sensor Circuit High Input<br>P0714 Transmission Fluid Temperature Sensor Circuit Intermittent<br>P0715 Input/Turbine Speed Sensor Circuit Malfunction<br>P0716 Input/Turbine Speed Sensor Circuit Range/Performance<br>P0717 Input/Turbine Speed Sensor Circuit No Signal<br>P0718 Input/Turbine Speed Sensor Circuit Intermittent<br>P0719 Torque Converter/Brake Switch B Circuit Low<br>P0720 Output Speed Sensor Circuit Malfunction<br>P0721 Output Speed Sensor Range/Performance<br>P0722 Output Speed Sensor No Signal<br>P0723 Output Speed Sensor Intermittent<br>P0724 Torque Converter/Brake Switch B Circuit High<br>P0725 Engine Speed input Circuit Malfunction<br>P0726 Engine Speed Input Circuit Range/Performance<br>P0727 Engine Speed Input Circuit No Signal<br>P0728 Engine Speed Input Circuit Intermittent<br>P0730 Incorrect Gear Ratio<br>P0731 Gear 1 Incorrect ratio<br>P0732 Gear 2 Incorrect ratio<br>P0733 Gear 3 Incorrect ratio<br>P0734 Gear 4 Incorrect ratio<br>P0735 Gear 5 Incorrect ratio<br>P0736 Reverse incorrect gear ratio<br>P0740 Torque Converter Clutch Circuit Mal***tion<br>P0741 Torque Converter Clutch Circuit Performance or Stuck Off<br>P0742 Torque Converter Clutch Circuit Stuck On<br>P0743 Torque Converter Clutch Circuit Electrical<br>P0744 Torque Converter Clutch Circuit Intermittent<br>P0745 Pressure Control Solenoid Malfunction<br>P0746 Pressure Control Solenoid Performance or Stuck Off<br>P0747 Pressure Control Solenoid Stuck On<br>P0748 Pressure Control Solenoid Electrical<br>P0749 Pressure Control Solenoid Intermittent<br>P0750 Shift Solenoid A Malfunction<br>P0751 Shift Solenoid A Performance or Stuck Off/1-2 Shift Solenoid Valve Performance<br>P0752 Shift Solenoid A Stuck On<br>P0753 Shift Solenoid A Electrical/1-2 Shift Solenoid Circuit Electrical<br>P0754 Shift Solenoid A Intermittent<br>P0755 Shift Solenoid B Malfunction<br>P0756 Shift Solenoid B Performance or Stuck Off/2-3 Shift Solenoid Valve Performance<br>P0757 Shift Solenoid B Stuck On<br>P0758 Shift Solenoid B Electrical/2-3 Shift Solenoid Circuit Electrical<br>P0759 Shift Solenoid B Intermittent<br>P0760 Shift Solenoid C Malfunction<br>P0761 Shift Solenoid C Performance or Stuck Off<br>P0762 Shift Solenoid C Stuck On<br>P0763 Shift Solenoid C Electrical<br>P0764 Shift Solenoid C Intermittent<br>P0765 Shift Solenoid D Malfunction<br>P0766 Shift Solenoid D Performance or Stuck Off<br>P0767 Shift Solenoid D Stuck On<br>P0768 Shift Solenoid D Electrical<br>P0769 Shift Solenoid D Intermittent<br>P0770 Shift Solenoid E Malfunction<br>P0771 Shift Solenoid E Performance or Stuck Off<br>P0772 Shift Solenoid E Stuck On<br>P0773 Shift Solenoid E Electrical<br>P0774 Shift Solenoid E Intermittent<br>P0775 Pressure Control Solenoid B Malfunction<br>P0776 Pressure Control Solenoid B Performance<br>P0777 Pressure Control Solenoid B Stuck On<br>P0778 Pressure Control Solenoid B Electrical<br>P0779 Pressure Control Solenoid B Intermittent<br>P0780 Shift Malfunction<br>P0781 1-2 Shift Malfunction<br>P0782 2-3 Shift Malfunction<br>P0783 3-4 Shift Malfunction<br>P0784 4-5 Shift Malfunction<br>P0785 Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical<br>P0786 Shift/Timing Solenoid Range/Performance<br>P0787 Shift/Timing Solenoid Low<br>P0788 Shift/Timing Solenoid High<br>P0789 Shift/Timing Solenoid Intermittent<br>P0790 Normal/Performance Switch Circuit Malfunction<br>P0801 Reverse Inhibit Control Circuit Malfunction<br>P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction<br>P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction<br>
P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete<br>P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted<br>P1102 MAF Sensor In Range But Lower Than Expected<br>P1103 MAF Sensor In Range But Higher Than Expected<br>P1104 MAF Ground Malfunction<br>P1105 Dual Alternator Upper Fault<br>P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage<br>P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage<br>P1108 Dual Alternator Battery Lamp Circuit Malfunction<br>P1109 IAT - B Sensor Intermittent<br>P1110 IAT Sensor (D/C) Open/Short<br>P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage<br>P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage<br>P1113 IAT Sensor Open/Short<br>P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input<br>P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input<br>P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range<br>P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent<br>P1118 Manifold Absolute Temperature Circuit Low Input<br>P1119 Manifold Absolute Temperature Circuit High Input<br>P1120 Throttle position sensor out of range<br>P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage<br>P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage<br>P1123 Throttle Position Sensor In Range But Higher Than Expected<br>P1124 Throttle Position Sensor Out Of Self Test Range<br>P1125 Throttle position sensor intermittent<br>P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction<br>P1127 Exhaust Not Warm, Downstream O2 Sensor<br>P1128 Upstream Heated O2 Sensors Swapped<br>P1129 Downstream Heated O2 Sensors Swapped<br>P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit<br>P1131 Lack Of HO2S Switch - Sensor Indicates Lean<br>P1132 Lack Of HO2S Switch - Sensor Indicates Rich<br>P1133 HO2S Insufficient Switching Sensor 1<br>P1134 HO2S Transition Time Ratio Sensor 1<br>P1135 Pedal Position Sensor A Circuit Intermittent<br>P1136 Fan Control Circuit Malfunction<br>P1137 Lack Of HO2S Switch - Sensor Indicates Lean<br>P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich<br>P1139 Water In Fuel Indicator Circuit Malfunction<br>P1140 Water In Fuel Condition<br>P1141 Fuel Restriction Indicator Circuit Malfunction<br>P1142 Fuel Restriction Condition<br>P1143 Air Assist Control Valve Range/Performance<br>P1144 Air Assist Control Valve Circuit Malfunction<br>P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit<br>P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean<br>P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich<br>P1153 Bank 2 Fuel Control Shifted Lean<br>P1154 Bank 2 Fuel Control Shifted Rich<br>P1155 Alternative Fuel Controller<br>P1156 Fuel Select Switch Malfunction<br>P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean<br>P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich<br>P1159 Fuel Stepper Motor Malfunction<br>P1167 Invalid Test,throttle not depressed<br>P1168 Fuel Rail Sensor In-Range Low Failure<br>P1169 Fuel Rail Sensor In-Range High Failure<br>P1170 ESO - Engine Shut Off Solenoid Fault<br>P1171 Rotor Sensor Fault<br>P1172 Rotor Control Fault<br>P1173 Rotor Calibration Fault<br>P1174 Cam Sensor Fault<br>P1175 Cam Control Fault<br>P1176 Cam Calibration Fault<br>P1177 Synchronization Fault<br>P1178 ( open )<br>P1180 Fuel Delivery System Malfunction - Low<br>P1181 Fuel Delivery System Malfunction - High<br>P1182 Fuel Shut Off Solenoid Malfunction<br>P1183 Engine Oil Temperature Circuit Malfunction<br>P1184 Engine Oil Temperature Out Of Self Test Range<br>P1185 FTS High - Fuel Pump Temperature Sensor High<br>P1186 FTS Low - Fuel Pump Temperature Sensor Low<br>P1187 Variant Selection<br>P1188 Calibration Memory Fault<br>P1189 Pump Speed Signal Fault<br>P1190 Calibration Resistor Out Of Range<br>P1191 Key Line Voltage<br>P1192 Voltage External<br>P1193 EGR Drive Overcurrent<br>P1194 ECU A/D Converter<br>P1195 SCP HBCC Failed To Initialize<br>P1196 Key Off Voltage High<br>P1197 Key Off Voltage Low<br>P1198 Pump Rotor Control Underfueling<br>P1199 Fuel Level Input Circuit Low<br>P1200 Injector Control Circuit<br>P1201 Injector Circuit Open / Shorted - Cylinder #1<br>P1202 Injector Circuit Open / Shorted - Cylinder #2<br>P1203 Injector Circuit Open / Shorted - Cylinder #3<br>P1204 Injector Circuit Open / Shorted - Cylinder #4<br>P1205 Injector Circuit Open / Shorted - Cylinder #5<br>P1206 Injector Circuit Open / Shorted - Cylinder #6<br>P1209 Injector Control Pressure System Fault<br>P1210 Injector Control Pressure Above Expected Level<br>P1211 Injector Control Pressure Sensor Above / Below Desired<br>P1212 Injector Control Pressure Not Detected During Crank<br>P1213 Start Injector Circuit Malfunction<br>P1214 Pedal Position Sensor B Circuit Intermittent<br>P1215 Pedal Position Sensor C Circuit Low Input<br>P1216 Pedal Position Sensor C Circuit High Input<br>P1217 Pedal Position Sensor C Circuit Intermittent<br>P1218 CID High<br>P1219 CID Low<br>P1220 Series Throttle Control System Malfunction<br>P1221 Traction Control System Malfunction<br>P1222 Traction Control Output Circuit Malfunction<br>P1223 Pedal Demand Sensor B Circuit High Input<br>P1224 Throttle Position Sensor B Out Of Self Test Range<br>P1225 Needle Lift Sensor Malfunction<br>P1226 Control Sleeve Sensor Malfunction<br>P1227 Wastegate Failed Closed (Over Pressure)<br>P1228 Wastegate Failed Open (Under Pressure)<br>P1229 Intercooler Pump Driver Fault<br>P1230 Fuel Pump Low Speed Malfunction<br>P1231 Fuel Pump Secondary Circuit Low, High Speed<br>P1232 Fuel Pump Speed Primary Circuit Malfunction<br>P1233 Fuel Pump Driver Module Off Line<br>P1234 Fuel Pump Driver Module Off Line<br>P1235 Fuel Pump Control Out Of Range<br>P1236 Fuel Pump Control Out Of Range<br>P1237 Fuel Pump Secondary Circuit Malfunction<br>P1238 Fuel Pump Secondary Circuit Malfunction<br>P1239 Speed Fuel Pump Positive Feed Fault<br>P1240 Sensor Power Supply Malfunction<br>P1241 Sensor Power Supply Low Input<br>P1242 Sensor Power Supply High Input<br>P1243 Second Fuel Pump Faulty or Ground Fault<br>P1244 Alternator Load Input Failed High<br>P1245 Alternator Load Input Failed Low<br>P1246 Alternator Load Input Failed<br>P1247 Turbo Boost Pressure Low<br>P1248 Turbo Boost Pressure Not Detected<br>P1249 Wastegate Control Valve Performance<br>P1250 PRC Solenoid Circuit Malfunction<br>P1251 Air Mixture Solenoid Circuit Malfunction<br>P1252 Pedal Correlation PDS1 and LPDS High<br>P1253 Pedal Correlation PDS1 and LPDS Low<br>P1254 Pedal Correlation PDS2 and LPDS High<br>P1255 Pedal Correlation PDS2 and LPDS Low<br>P1256 Pedal Correlation PDS1 and HPDS<br>P1257 Pedal Correlation PDS2 and HPDS<br>P1258 Pedal Correlation PDS1 and PDS2<br>P1259 Immobilizer to PCM Signal Error<br>P1260 THEFT Detected, Vehicle Immobilzed<br>P1261 Cylinder #1 High To Low Side Short<br>P1262 Cylinder #2 High To Low Side Short<br>P1263 Cylinder #3 High To Low Side Short<br>P1264 Cylinder #4 High To Low Side Short<br>P1265 Cylinder #5 High To Low Side Short<br>P1266 Cylinder #6 High To Low Side Short<br>P1267 Cylinder #7 High To Low Side Short<br>P1268 Cylinder #8 High To Low Side Short<br>P1269 Immobilizer Code Not Programmed<br>P1270 Engine RPM Or Speed Limiter Reached<br>P1271 Cylinder #1 High To Low Side Open<br>P1272 Cylinder #2 High To Low Side Open<br>P1273 Cylinder #3 High To Low Side Open<br>P1274 Cylinder #4 High To Low Side Open<br>P1275 Cylinder #5 High To Low Side Open<br>P1276 Cylinder #6 High To Low Side Open<br>P1277 Cylinder #7 High To Low Side Open<br>P1278 Cylinder #8 High To Low Side Open<br>P1280 Injection Control Pressure Out Of Range Low<br>P1281 Injection Control Pressure Out Of Range High<br>P1282 Excessive Injection Control Pressure<br>P1283 IPR Circuit Failure<br>P1284 Aborted KOER - ICP Failure<br>P1285 Cylinder head over temp sensed<br>P1286 Fuel Pulse In Range But Lower Than Expected<br>P1287 Fuel Pulse In Range But Higher Than Expected<br>P1288 Cylinder Head Temp Sensor Out Of Self Test Range<br>P1289 Cylinder Head Temp Sensor High Input<br>P1290 Cylinder Head Temp Sensor Low Input<br>P1291 Injector High Side Short To GND Or VBATT - Bank 1<br>P1292 Injector High Side Short To GND Or VBATT - Bank 2<br>P1293 Injector High Side Open - Bank 1<br>P1294 Injector High Side Open - Bank 2/Target idle not reached<br>P1295 Multi-faults - Bank 1 - With Low Side Shorts<br>P1296 Multi-faults - Bank 2 - With Low Side Shorts<br>P1297 Injector High Sides Shorted Together<br>P1298 IDM Failure<br>P1299 Cylinder Head Overtemperature Protection Active<br>P1300 Boost Calibration Fault<br>P1301 Boost Calibration High<br>P1302 Boost Calibration Low<br>P1303 EGR Calibration Fault<br>P1304 EGR Calibration High<br>P1305 EGR Calibration Low<br>P1306 Kickdown Relay Pull - In Circuit Fault<br>P1307 Kickdown Relay Hold Circuit Fault<br>P1308 A/C Clutch Circuit Fault<br>P1309 Misfire Monitor AICE Chip Fault<br>P1313 Misfire Rate Catalyst Damage Fault - Bank 1<br>P1314 Misfire Rate Catalyst Damage Fault - Bank 2<br>P1315 Persistent Misfire<br>P1316 Injector Circuit / IDM Codes Detected<br>P1317 Injector Circuit / IDM Codes Not Updated<br>P1336 Crank / Cam Sensor Range / Performance<br>P1340 Camshaft Position Sensor B Circuit Malfunction<br>P1341 Camshaft Position Sensor B Range / Performance<br>P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation<br>P1346 Fuel Level Sensor B Circuit Malfunction<br>P1347 Fuel Level Sensor B Range / Performance<br>P1348 Fuel Level Sensor B Circuit Low<br>P1349 Fuel Level Sensor B Circuit High<br>P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor<br>P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage<br>P1352 Ignition Coil A Primary Circuit Malfunction<br>P1353 Ignition Coil B Primary Circuit Malfunction<br>P1354 Ignition Coil C Primary Circuit Malfunction<br>P1355 Ignition Coil D Primary Circuit Malfunction<br>P1360 Ignition Coil A Secondary Circuit Malfunction<br>P1361 Ignition Control (IC) Circuit Low Voltage<br>P1362 Ignition Coil C Secondary Circuit Malfunction<br>P1363 Ignition Coil D Secondary Circuit Malfunction<br>P1364 Ignition Coil Primary Circuit Failure<br>P1365 Ignition Coil Secondary Circuit Failure<br>P1366 Ignition Spare<br>P1367 Ignition Spare<br>P1368 Ignition Spare<br>P1369 Engine Temperature Light Monitor Failure<br>P1370 Insufficient RMP Increase During Spark Test<br>P1371 Ignition Coil - Cylinder 1 - Early Activation Fault<br>P1372 Ignition Coil - Cylinder 2 - Early Activation Fault<br>P1373 Ignition Coil - Cylinder 3 - Early Activation Fault<br>P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault<br>P1375 Ignition Coil - Cylinder 5 - Early Activation Fault<br>P1376 Ignition Coil - Cylinder 6 - Early Activation Fault<br>P1380 Misfire Detected - Rough Road Data Not Available<br>P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM<br>P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction<br>P1383 Variable Cam Timing Overretarded (Bank #1)<br>P1384 VVT Solenoid A Malfunction<br>P1385 Variable Cam Timing Solenoid B Malfunction<br>P1386 Variable Cam Timing Overadvanced (Bank #2)<br>P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction<br>P1388 Variable Cam Timing Overretarded (Bank #2)<br>P1389 Glow Plug Circuit High Side Low Input<br>P1390 Octane Adjust Pin Out Of Self Test Range<br>P1391 Glow Plug Circuit Low Input (Bank #1)<br>P1392 Glow Plug Circuit High Input (Bank #1)<br>P1393 Glow Plug Circuit Low Input (Bank #2)<br>P1394 Glow Plug Circuit High Input (Bank #2)<br>P1395 Glow Plug Monitor Fault (Bank #1)<br>P1396 Glow Plug Monitor Fault (Bank #2)<br>P1397 System Voltage Out Of Self Test Range<br>P1398 VVT Solenoid B Circuit High Input<br>P1399 Glow Plug Circuit High Side, High Input<br>P1400 DPFE Circuit Low Input<br>P1401 DPFE Circuit High Input<br>P1402 EGR Metering Orifice Restricted<br>P1403 DPFE Sensor Hoses Reversed<br>P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance<br>P1405 DPFE Sensor Upstream Hose Off Or Plugged<br>P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance<br>P1407 EGR No Flow Detected<br>P1408 EGR Flow Out Of Self Test Range<br>P1409 EVR Control Circuit Malfunction<br>P1411 SAI System Incorrect Downstream Flow Detected<br>P1413 SAI System Monitor Circuit Low Input<br>P1414 SAI System Monitor Circuit High Input<br>P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1<br>P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2<br>P1417 Port Air Relief Circuit Malfunction<br>P1418 Split Air #1 Circuit Malfunction<br>P1419 Split Air #2 Circuit Malfunction<br>P1420 Catalyst Temperature Sensor Failure<br>P1421 Catalyst Damage<br>P1422 EGI Temperature Sensor Failure<br>P1423 EGI Functionality Test Failed<br>P1424 EGI Glow Plug Primary Failure<br>P1425 EGI Glow Plug Secondary Failure<br>P1426 EGI Mini - MAF Failed Out Of Range<br>P1427 EGI Mini - MAF Failed Short Circuit<br>P1428 EGI Mini - MAF Failed Open Circuit<br>P1429 Electric Air Pump Primary Failure<br>P1430 Electric Air Pump Secondary Failure<br>P1433 A/C Refrigerant Temperature Circuit Low<br>P1434 A/C Refrigerant Temperature Circuit High<br>P1435 A/C Refrigerant Temperature Circuit Range/Performance<br>P1436 A/C Evaporator Air Temperature Circuit Low<br>P1437 A/C Evaporator Air Temperature Circuit High<br>P1438 A/C Evaporator Air Temperature Circuit Range/Performance<br>P1439 Floor Temperature Switch Circuit Malfunction<br>P1440 Purge Valve Stuck Open<br>P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only<br>P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only<br>P1442 Evaporative Emission Control System Leak Detected<br>P1443 Evaporative Emission Control System Control Valve<br>P1444 Purge Flow Sensor Circuit Low Input<br>P1445 Purge Flow Sensor Circuit High Input<br>P1446 Evaporative Vac Solenoid Circuit Malfunction<br>P1447 ELC System Closure Valve Flow Fault<br>P1448 ELC System 2 Fault<br>P1449 Evaporative Check Solenoid Circuit Malfunction<br>P1450 Unable To Bleed Up Fuel Tank Vacuum<br>P1451 Evap Emission Control Sys Vent Control Valve Circuit<br>P1452 Unable To Bleed - Up Vacuum in Tank<br>P1453 Fuel Tank Pressure Relief Valve Malfunction<br>P1454 Evaporative System Vacuum Test Malfunction<br>P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)<br>P1456 Fuel Tank Temperature Sensor Circuit Malfunction<br>P1457 Unable To Pull Vacuum In Tank<br>P1460 Wide open throttle A/C cutoff relay circuit<br>P1461 A/C pressure sensor circuit voltage low<br>P1462 A/C pressure sensor circuit voltage high<br>P1463 A/C Pressure Sensor Insufficient Pressure Change<br>P1464 A/C Demand Out of Self Test Range<br>P1465 A/C Relay Circuit Malfunction<br>P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction<br>P1467 A/C Compressor Temperature Sensor Malfunction<br>P1468 SSPOD Open Circuit or Closed Circuit Fault<br>P1469 Low A/C Cycling Period<br>P1470 A/C Cycling Period Too Short<br>P1471 Electrodrive Fan 1 Operational Failure (Driver Side)<br>P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)<br>P1473 Fan Secondary High With Fan(s) Off<br>P1474 Low Fan Control Primary Circuit Malfunction<br>P1475 Fan Relay (Low) Circuit Malfunction<br>P1476 Fan Relay (High) Circuit Malfunction<br>P1477 Additional Fan Relay Circuit Malfunction<br>P1478 Cooling Fan Driver Fault<br>P1479 High Fan Control Primary Circuit Malfunction<br>P1480 Fan Secondary Low with Low Fan On<br>P1481 Fan Secondary Low With High Fan On<br>P1482 SCP<br>P1483 Power To Fan Circuit Overcurrent<br>P1484 Open Power To Ground VCRM<br>P1485 EGRV Circuit Malfunction<br>P1486 EGRA Circuit Malfunction<br>P1487 EGRCHK Solenoid Circuit Malfunction<br>P1490 Secondary Air Relief Solenoid Circuit Malfunction<br>P1491 Secondary Switch Solenoid Circuit Malfunction<br>P1492 APLSOL Solenoid Circuit Malfunction<br>P1493 RCNT Solenoid Circuit Malfunction<br>P1494 SPCUT Solenoid Circuit Malfunction<br>P1495 TCSPL Solenoid Circuit Malfunction<br>P1500 Vehicle Speed Sensor Intermittent<br>P1501 Vehicle Speed Sensor Out Of Self Test Range<br>P1502 Vehicle Speed Sensor Intermittent Malfunction<br>P1503 Auxillary Speed Sensor Fault<br>P1504 Idle Air Control Circuit Malfunction<br>P1505 Idle Air Control System At Adaptive Clip<br>P1506 Idle Air Control Overspeed Error<br>P1507 Idle Air Control Underspeed Error<br>P1508 Idle Control System Circuit Open<br>P1509 Idle Control System Circuit Shorted<br>P1510 Idle Signal Circuit Malfunction<br>P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction<br>P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed<br>P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed<br>P1514 High Load Neutral/Drive Fault<br>P1515 Electric Current Circuit Malfunction<br>P1516 IMRC Input Error (Bank 1)<br>P1517 IMRC Input Error (Bank 2)<br>P1518 Intake Manifold Runner Control (Stuck Open)<br>P1519 Intake Manifold Runner Control (Stuck Closed)<br>P1520 Intake Manifold Runner Control Circuit Malfunction<br>P1521 Variable Intake Solenoid #1 Circuit Malfunction<br>P1522 Variable Intake Solenoid #2 Circuit Malfunction<br>P1523 IVC Solenoid Circuit Malfunction<br>P1524 Variable Intake Solenoid System<br>P1525 Air Bypass Valve System<br>P1526 Air Bypass System<br>P1527 Accelerate Warmup Solenoid Circuit Malfunction<br>P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction<br>P1529 SCAIR Solenoid Circuit Malfunction<br>P1530 A/C Clutch Circuit Malfunction<br>P1531 Invalid Test - Accelerator Pedal Movement<br>P1532 IMCC Circuit Malfunction, Bank B<br>P1533 AAI Circuit Malfunction<br>P1534 Inertia Switch Activated<br>P1535 Blower Fan Speed Circuit Range/Performance<br>P1536 Parking Brake Switch Circuit Failure<br>P1537 Intake Manifold Runner Control (Bank 1) Stuck Open<br>P1538 Intake Manifold Runner Control (Bank 2) Stuck Open<br>P1539 Power To A/C Clutch Circuit Overcurrent<br>P1540 Air Bypass Valve Circuit Malfunction<br>P1549 IMCC Circuit Malfunction, Bank B<br>P1550 PSPS Out Of Self Test Range<br>P1565 Speed Control Command Switch Out of Range High<br>P1566 Speed Control Command Switch Out of Range Low<br>P1567 Speed Control Output Circuit Continuity<br>P1568 Speed Control Unable to Hold Speed<br>P1571 Brake Switch Malfunction<br>P1572 Brake Pedal Switch Circuit Malfunction<br>P1573 Throttle Position Not Available<br>P1574 Throttle Position Sensor Disagreement btwn Sensors<br>P1575 Pedal Position Out of Self Test Range<br>P1576 Pedal Position Not Available<br>P1577 Pedal Position Sensor Disagreement btwn Sensors<br>P1578 ETC Power Less Than Demand<br>P1579 ETC In Power Limiting Mode<br>P1580 Electronic Throttle Monitor PCM Override<br>P1581 Electronic Throttle Monitor Malfunction<br>P1582 Electronic Throttle Monitor Data Available<br>P1583 Electronic Throttle Monitor Cruise Disable<br>P1584 TCU Detected IPE Circuit Malfunction<br>P1585 Throttle Control Unit Malfunction<br>P1586 Throttle Control Unit Throttle Position Malfunction<br>P1587 Throttle Control Unit Modulated Command Malfunction<br>P1588 Throttle Control Unit Detected Loss of Return Spring<br>P1589 TCU Unable To Control Desired Throttle Angle<br>P1600 Loss of KAM Power; Open Circuit<br>
P1601 ECM/TCM Serial Communication Error<br>P1602 Immobilizer/ECM Communication Error<br>P1603 EEPROM Malfunction<br>P1604 Code Word Unregestered<br>P1605 Keep Alive Memory Test Failure<br>P1606 ECM Control Relay O/P Circuit Malfunction<br>P1607 MIL O/P Circuit Malfunction<br>P1608 Internal ECM Malfunction<br>P1609 Diagnostic Lamp Driver Fault<br>P1610 SBDS Interactive Codes<br>P1611 SBDS Interactive Codes<br>P1612 SBDS Interactive Codes<br>P1613 SBDS Interactive Codes<br>P1614 SBDS Interactive Codes<br>P1615 SBDS Interactive Codes<br>P1616 SBDS Interactive Codes<br>P1617 SBDS Interactive Codes<br>P1618 SBDS Interactive Codes<br>P1619 SBDS Interactive Codes<br>P1620 SBDS Interactive Codes<br>P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match<br>P1622 Immobilizer ID Does Not Match<br>P1623 Immobilizer Code Word/ID Number Write Failure<br>P1624 Anti Theft System<br>P1625 B+ Supply To VCRM Fan Circuit Malfunction<br>P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction<br>P1627 Module Supply Voltage Out Of Range<br>P1628 Module Ignition Supply Input Malfunction<br>P1629 Internal Voltage Regulator Malfunction<br>P1630 Internal Vref Malfunction<br>P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)<br>P1632 Smart Alternator Faults Sensor/Circuit Malfunction<br>P1633 KAM Voltage Too Low<br>P1634 Data Output Link Circuit Failure<br>P1635 Tire / Axle Ratio Out of Acceptable Range<br>P1636 Inductive Signature Chip Communication Error<br>P1637 Can Link ECM/ABSCM Circuit / Network Malfunction<br>P1638 Can Link ECM/INSTM Circuit / Network Malfunction<br>P1639 Vehicle ID Block Corrupted or Not Programmed<br>P1640 Powertrain DTCs Available in Another Module<br>P1641 Fuel Pump Primary Circuit Failure<br>P1642 Fuel Pump Monitor Circuit High Input<br>P1643 Fuel Pump Monitor Circuit Low Input<br>P1644 Fuel Pump Speed Control Circuit Malfunction<br>P1645 Fuel Pump Resistor Switch Circuit Malfunction<br>P1650 PSP Switch Out of Self Test Range<br>P1651 PSP Switch Input Malfunction<br>P1652 IAC Monitor Disabled by PSP Switch Failed On<br>P1653 Power Steering Output Circuit Malfunction<br>P1654 Recirculation Override Circuit Malfunction<br>P1655 Starter Disable Circuit Malfunction<br>P1660 Output Circuit Check Signal High<br>P1661 Output Circuit Check Signal Low<br>P1662 IDM_EN Circuit Failure<br>P1663 Fuel Demand Command Signal Circuit Malfunction<br>P1667 CI Circuit Malfunction<br>P1668 PCM - IDM Communications Error<br>P1670 Electronic Feedback Signal Not Detected<br>P1680 Metering Oil Pump Malfunction<br>P1681 Metering Oil Pump Malfunction<br>P1682 Metering Oil Pump Malfunction<br>P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction<br>P1684 Metering Oil Pump Position Sensor Circuit Malfunction<br>P1685 Metering Oil Pump Stepping Motor Circuit Malfunction<br>P1686 Metering Oil Pump Stepping Motor Circuit Malfunction<br>P1687 Metering Oil Pump Stepping Motor Circuit Malfunction<br>P1688 Metering Oil Pump Stepping Motor Circuit Malfunction<br>P1689 Oil Pressure Control Solenoid Circuit Malfunction<br>P1690 Wastegate Solenoid Circuit Malfunction<br>P1691 Turbo Pressure Control Solenoid Circuit Malfunction<br>P1692 Turbo Control Solenoid Circuit Malfunction<br>P1693 Turbo Charge Control Circuit Malfunction<br>P1694 Turbo Charge Relief Circuit Malfunction<br>P1700 Transmission Indeterminate Failure (Failed to Neutral)<br>P1701 Reverse Engagement Error<br>P1702 TRS Circuit Intermittent Malfunction<br>P1703 Brake Switch Out Of Self Test Range<br>P1704 Digital TRS Failed to Transition States in KOEO / KOER<br>P1705 Not in P or N During KOEO / KOER<br>P1706 High Vehicle Speed Observed in Park<br>P1707 Transfer Case Neutral Indicator Hard Fault Present<br>P1708 Clutch Switch Circuit Malfunction<br>P1709 PNP Switch Out Of Self Test Range<br>P1711 TFT Sensor Out Of Self Test Range<br>P1712 Trans Torque Reduction Request Signal Malfunction<br>P1713 TFT Sensor In Range Failure Low Value<br>P1714 SSA Inductive Signature Malfunction<br>P1715 SSB Inductive Signature Malfunction<br>P1716 SSC Inductive Signature Malfunction<br>P1717 SSD Inductive Signature Malfunction<br>P1718 TFT Sensor In Range Failure High<br>P1720 Vehicle Speed (Meter) Circuit Malfunction<br>P1721 Gear 1 Incorrect Ratio<br>P1722 Gear 2 Incorrect Ratio<br>P1723 Gear 3 incorrect Ratio<br>P1724 Gear 4 Incorrect Ratio<br>P1725 Insufficient Engine Speed Increase During Self Test<br>P1726 Insufficient Engine Speed Decrease During Self Test<br>P1727 Coast Clutch Solenoid Inductive Signature Malfunction<br>P1728 Transmission Slip Error<br>P1729 4x4 Low Switch Error<br>P1730 Gear Control Malfunction 2,3,5<br>P1731 1-2 Shift Malfunction<br>P1732 2-3 Shift Malfunction<br>P1733 3-4 Shift Malfunction<br>P1734 Gear Control Malfunction<br>P1735 First Gear Switch Circuit Malfunction<br>P1736 Second Gear Switch Circuit Malfunction<br>P1737 Lockup Solenoid System<br>P1738 Shift Time Error<br>P1739 Slip Solenoid System<br>P1740 Torque Converter Clutch Inductive Signature Malfunction<br>P1741 Torque Converter Clutch Control Error<br>P1742 Torque Converter Clutch Solenoid Failed On<br>P1743 Torque Converter Clutch Solenoid Failied On<br>P1744 Torque Converter Clutch System Performance<br>P1745 Line Pressure Solenoid System<br>P1746 Pressure Control Solenoid "A" Open Circuit<br>P1747 Pressure Control Solenoid "A" Short Circuit<br>P1748 EPC Malfunction<br>P1749 Pressure Control Solenoid Failed Low<br>P1751 Shift Solenoid A Performance<br>P1754 Coast Clutch Solenoid Circuit Malfunction<br>P1755 Intermediate Speed Sensor (ISS) Malfunction<br>P1756 Shift Solenoid B Performance<br>P1760 Pressure Control Solenoid "A" Short Circuit<br>P1761 Shift Solenoid C Performance<br>P1762 Overdrive Band Failed Off<br>P1765 Timing Solenoid Circuit Malfunction<br>P1767 Torque Converter Clutch Circuit Malfunction<br>P1768 Performance / Normal / Winter Mode Input Malfunction<br>P1769 AG4 Transmission Torque Modulation Fault<br>P1770 Clutch Solenoid Circuit Malfunction<br>P1775 Transmission System MIL Fault<br>P1776 Ignition Retard Request Duration Fault<br>P1777 Ignition Retard Request Circuit Fault<br>P1778 Transmission Reverse I/P Circuit Malfunction<br>P1779 TCIL Circuit Malfunction<br>P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range<br>P1781 4X4 Switch Out of Self Test Range<br>P1782 P/ES Circuit Out Of Self Test Range<br>P1783 Transmission Overtemperature Condition<br>P1784 Transmission Mechanical Failure - First And Reverse<br>P1785 Transmission Mechanical Failure - First And Second<br>P1786 3-2 Downshift Error<br>P1787 2-1 Downshift Error<br>P1788 Pressure Control Solenoid "B" Open Circuit<br>P1789 Pressure Control Solenoid "B" Short Circuit<br>P1790 TP (Mechanical) Circuit Malfunction<br>P1791 TP (Electric) Circuit Malfunction<br>P1792 Barometer Pressure Circuit Malfunction<br>P1793 Intake Air Volume Circuit Malfunction<br>P1794 Battery Voltage Circuit Malfunction<br>P1795 Idle Switch Circuit Malfunction<br>P1796 Kick Down Switch Circuit Malfunction<br>P1797 Neutral Switch Circuit Malfunction<br>P1798 Coolant Temperature Circuit Malfunction<br>P1799 Hold Switch Circuit Malfunction<br>P1800 Transmission Clutch Interlock Safety Switch Circuit Failure<br>P1801 Transmission Clutch Interlock Safety Switch Open Circuit<br>P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery<br>P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground<br>P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure<br>P1805 Transmission 4-Wheel Drive High Indicator Open Circuit<br>P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery<br>P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground<br>P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure<br>P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit<br>P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery<br>P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground<br>P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure<br>P1813 Transmission 4-Wheel Drive Mode Select Open Circuit<br>P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery<br>P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground<br>P1816 Transmission Neutral Safety Switch Circuit Failure<br>P1817 Transmission Neutral Safety Switch Open Circuit<br>P1818 Transmission Neutral Safety Switch Short Circuit To Battery<br>P1819 Transmission Neutral Safety Switch Short Circuit To Ground<br>P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure<br>P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit<br>P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery<br>P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground<br>P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure<br>P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit<br>P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery<br>P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground<br>P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure<br>P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit<br>P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery<br>P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground<br>P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure<br>P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit<br>P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery<br>P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground<br>P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure<br>P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure<br>P1838 Transmission Transfer Case Shift Motor Circuit Failure<br>P1839 Transmission Transfer Case Shift Motor Open Circuit<br>P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery<br>P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground<br>P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure<br>P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit<br>P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery<br>P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground<br>P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure<br>P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit<br>P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery<br>P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground<br>P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure<br>P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit<br>P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery<br>P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground<br>P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure<br>P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit<br>P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery<br>P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground<br>P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure<br>P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit<br>P1860 TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery<br>P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground<br>P1862 Transmission Transfer Case Contact Plate Power Circuit Failure<br>P1863 Transmission Transfer Case Contact Plate Power Open Circuit<br>P1864 Transmission Transfer Case Contact Plate Power Short To Battery<br>P1865 Transmission Transfer Case Contact Plate Power Short To Ground<br>P1866 Transmission Transfer Case System Concern - Servicing Required<br>P1867 Transmission Transfer Case Contact Plate General Circuit Failure<br>P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure<br>P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery<br>P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure<br>P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery<br>P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure<br>P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery<br>P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure<br>P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical<br>P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure<br>P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery<br>P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure<br>P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit<br>P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery<br>P1881 Engine Coolant Level Switch Circuit Failure, GEM<br>P1882 Engine Coolant Level Switch Circuit Short to Ground<br>P1883 Engine Coolant Level Switch Circuit Failure, GEM<br>P1884 Engine Coolant Level Lamp Circuit Short to Ground<br>P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground<br>P1886 4X4 Initialization Failure<br>P1890 Transmission 4WD Mode Select Return Input Circuit Failure<br>P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit<br>P1900 OSS Circuit Intermittent Malfunction<br>P1901 TSS Circuit Intermittent Malfunction<br>P1902 Pressure Control Solenoid "B" Intermittent Short<br>P1903 Pressure Control Solenoid "C" Short Circuit<br>P1904 Pressure Control Solenoid "C" Open Circuit<br>P1905 Pressure Control Solenoid "C" Intermittent Short<br>P1906 Kickdown Pull Relay Open or Short Circuit to Ground<br>P1907 Kickdown Hold Relay Open or Short Circuit to Ground<br>P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground<br>P1909 Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd<br>P1910 VFS A Pressure Output Failed Low<br>P1911 VFS B Pressure Output Failed Low<br>P1912 VFS C Pressure Output Failed Low<br>P1913 Pressure Switch A Circuit Malfunction<br>P1914 Manually Shifted Automatic (MSA) Sw Circuit Malf<br>P1915 Reverse Switch Circuit Malfunction<br>P1916 High Clutch Drum Speed Sensor Malfunction<br>P1917 High Clutch Drum Speed Sensor Intermittent<br>P1918 Transmission Range Display Circuit Malfunction<br>
Re: VOLVO P2 Diagnostic Fault Codes (Short Circuit)
C1091 Speed Wheel Sensor All Coherency Failure<br>C1095 ABS Hydraulic Pump Motor Circuit Failure<br>C1096 ABS Hydraulic Pump Motor Circuit Open<br>C1097 ABS Hydraulic Pump Motor Circuit Short To Ground<br>C1098 ABS Hydraulic Pump Motor Circuit Short To Battery<br>C1100 ABS Pump Switch Circuit Failure<br>C1101 ABS Hydraulic Valve Circuit Failure<br>C1102 ABS Acceleration Switch Circuit Failure<br>C1103 ABS Hydraulic Brake Switch Circuit Failure<br>C1104 Traction Control Active Lamp - Circuit Short to Battery<br>C1105 Traction Control Disable Lamp - Circuit Short to Battery<br>C1106 Traction Control Disable Switch Circuit Short to Battery<br>C1107 ABS Function Enabled Input Circuit Failure<br>C1109 Speed Control Actuator Assembly Cable Release Failure<br>C1110 ABS Power Relay Coil Circuit Failure<br>C1111 ABS Power Relay Coil Open Circuit<br>C1112 ABS Power Relay Coil Short Circuit To Ground<br>C1113 ABS Power Relay Coil Short Circuit To Battery<br>C1114 ABS Power Relay Output Short Circuit To Ground<br>C1115 ABS Power Relay Output Short Circuit To Battery<br>C1116 Starter Motor Circuit Failure<br>C1117 RPM Input Circuit Failure<br>C1123 Vehicle Speed Sensor Input Short to Battery<br>C1124 Input shaft speed signal missing/faulted<br>C1125 Brake Fluid Level Sensor Input Circuit Failure<br>C1126 Cruise Control Command Switch Assembly Circuit Failure<br>C1127 Cruise Control Deactivator Brake Switch Circuit Failure<br>C1132 Clutch position ckt short to ground<br>C1133 Clutch position ckt short to battery<br>C1134 Gear Shift position short to ground<br>C1135 Gear Shift position short to battery<br>C1136 Gear Select position short to ground<br>C1137 ECU is Defective<br>C1138 Gear Select position short to Battery<br>C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault<br>C1140 Hydraulic Base Brake Failure<br>C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault<br>C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault<br>C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault<br>C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault<br>C1145 Speed Wheel Sensor RF Input Circuit Failure<br>C1146 Speed Wheel Sensor RF Circuit Open<br>C1148 Speed Wheel Sensor RF Coherency Fault<br>C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure<br>C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt<br>C1155 Speed Wheel Sensor LF Input Circuit Failure<br>C1156 Speed Wheel Sensor LF Circuit Open<br>C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure<br>C1158 Speed Wheel Sensor LF Coherency Fault<br>C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd<br>C1161 Air Pressure Low Circuit Short to Gnd<br>C1162 Park Brake Switch # 2 Released Circuit Failure<br>C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd<br>C1164 Park Brake Actuator Assembly Switch Circuit Failure<br>C1165 Speed Wheel Sensor RR Input Circuit Failure<br>C1166 Speed Wheel Sensor RR Input Open Circuit<br>C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd<br>C1168 Speed Wheel Sensor RR Coherency Fault<br>C1169 ABS Fluid Dumping Exceeds Maximum Timing<br>C1170 PRNDL Switch Circuit Failure<br>C1172 Park Brake Switch # 1 Applied Circuit Failure<br>C1173 Park Brake Switch # 1 Released Circuit Short to Gnd<br>C1174 Park Brake Switch # 2 Applied Circuit Failure<br>C1175 Speed Wheel Sensor LR Input Circuit Failure<br>C1176 Speed Wheel Sensor LR Circuit Open<br>C1177 Park Brake Actuator Assembly Switch Released Circuit Failure<br>C1178 Speed Wheel Sensor LR Coherency Fault<br>C1179 Speed Control Actuator Assembly Cable Slack Failure<br>C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure<br>C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound<br>C1182 Park Lamp Flash Relay Circuit Failure<br>C1183 Park Lamp Flash Relay Circuit Short to Battery<br>C1184 ABS System Is Not Operational<br>C1185 ABS Power Relay Output Circuit Failure<br>C1186 ABS Power Relay Output Open Circuit<br>C1187 Brake Fluid Level Sensor Input Open Circuit<br>C1188 Brake Fluid Level Sensor Input Short Circuit To Battery<br>C1189 Brake Fluid Level Sensor Input Short Circuit To Ground<br>C1190 Speed Wheel Sensor LF Input Short Circuit To Battery<br>C1191 Speed Wheel Sensor LF Input Short Circuit To Ground<br>C1192 Speed Wheel Sensor RF Input Short Circuit To Battery<br>C1193 Speed Wheel Sensor RF Input Short Circuit To Ground<br>C1194 ABS Outlet Valve Coil LF Circuit Failure<br>C1195 ABS Outlet Valve Coil LF Circuit Open<br>C1196 ABS Outlet Valve Coil LF Circuit Short To Battery<br>C1197 ABS Outlet Valve Coil LF Circuit Short To Ground<br>C1198 ABS Inlet Valve Coil LF Circuit Failure<br>C1199 ABS Inlet Valve Coil LF Circuit Open<br>C1200 ABS Inlet Valve Coil LF Circuit Short To Battery<br>C1201 ABS Inlet Valve Coil LF Circuit Short To Ground<br>C1202 ABS Outlet Valve Coil Rear Circuit Failure<br>C1203 ABS Outlet Valve Coil Rear Circuit Open<br>C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery<br>C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground<br>C1206 ABS Inlet Valve Coil Rear Circuit Failure<br>C1207 ABS Inlet Valve Coil Rear Circuit Open<br>C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery<br>C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground<br>C1210 ABS Outlet Valve Coil RF Circuit Failure<br>C1211 ABS Outlet Valve Coil RF Circuit Open<br>C1212 ABS Outlet Valve Coil RF Circuit Short To Battery<br>C1213 ABS Outlet Valve Coil RF Circuit Short To Ground<br>C1214 ABS Inlet Valve Coil RF Circuit Failure<br>C1215 ABS Inlet Valve Coil RF Circuit Open<br>C1216 ABS Inlet Valve Coil RF Circuit Short To Battery<br>C1217 ABS Inlet Valve Coil RF Circuit Short To Ground<br>C1218 Lamp ABS Warning Output Circuit Failure<br>C1219 Lamp ABS Warning Output Circuit Open<br>C1220 Lamp ABS Warning Output Circuit Short To Battery<br>C1221 Lamp ABS Warning Output Circuit Short To Ground<br>C1222 Speed Wheel Mismatch<br>C1223 Lamp Brake Warning Output Circuit Failure<br>C1224 Lamp Brake Warning Output Circuit Open<br>C1225 Lamp Brake Warning Output Circuit Short To Battery<br>C1226 Lamp Brake Warning Output Circuit Short To Ground<br>C1227 Speed Wheel Sensor LR Input Short Circuit To Battery<br>C1228 Speed Wheel Sensor LR Input Short Circuit To Ground<br>C1229 Speed Wheel Sensor Rear Center Coherency Fault<br>C1230 Speed Wheel Sensor Rear Center Input Circuit Failure<br>C1231 Speed Wheel Sensor Rear Center Circuit Open<br>C1232 Speed Wheel Sensor Rear Center Input Short Circuit To Battery<br>C1233 Speed Wheel LF Input Signal Missing<br>C1234 Speed Wheel RF Input Signal Missing<br>C1235 Speed Wheel RR Input Signal Missing<br>C1236 Speed Wheel LR Input Signal Missing<br>C1237 Speed Wheel Rear Input Signal Missing<br>C1238 ABS Hydraulic Pressure Differential Switch Input Circuit Failure<br>C1239 ABS Hydraulic Pressure Differential Switch Input Open Circuit<br>C1240 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Battery<br>C1241 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Ground<br>C1242 ABS Outlet Valve Coil LR Circuit Failure<br>C1243 ABS Outlet Valve Coil LR Circuit Open<br>C1244 ABS Outlet Valve Coil LR Circuit Short To Battery<br>C1245 ABS Outlet Valve Coil LR Circuit Short To Ground<br>C1246 ABS Outlet Valve Coil RR Circuit Failure<br>C1247 ABS Outlet Valve Coil RR Circuit Open<br>C1248 ABS Outlet Valve Coil RR Circuit Short To Battery<br>C1249 ABS Outlet Valve Coil RR Circuit Short To Ground<br>C1250 ABS Inlet Valve Coil LR Circuit Failure<br>C1251 ABS Inlet Valve Coil LR Circuit Open<br>C1252 ABS Inlet Valve Coil LR Circuit Short To Battery<br>C1253 ABS Inlet Valve Coil LR Circuit Short To Ground<br>C1254 ABS Inlet Valve Coil RR Circuit Failure<br>C1255 ABS Inlet Valve Coil RR Circuit Open<br>C1256 ABS Inlet Valve Coil RR Circuit Short To Battery<br>C1257 ABS Inlet Valve Coil RR Circuit Short To Ground<br>C1258 Speed Wheel LF Comparison Failure<br>C1259 Speed Wheel RF Comparison Failure<br>C1260 Speed Wheel RR Comparison Failure<br>C1261 Speed Wheel LR Comparison Failure<br>C1262 Lamp Warning Relay Circuit Failure<br>C1263 Lamp Warning Relay Circuit Open<br>C1264 Lamp Warning Relay Circuit Short To Battery<br>C1265 Lamp Warning Relay Circuit Short To Ground<br>C1266 ABS Valve Power Relay Circuit Failure<br>C1267 ABS Functions Temporarily Disabled<br>C1268 Motor Relay # 1 Circuit Failure<br>C1269 Motor Relay # 1 Circuit Short to Battery<br>C1270 Motor # 1 Input Circuit Failure<br>C1271 Motor # 1 Input Circuit Short to Gnd<br>C1272 Motor # 2 Input Circuit Failure<br>C1273 Motor # 2 Input Circuit Short to Vbat<br>C1274 Solenoid Relay # 1 Circuit Failure<br>C1275 Solenoid Relay # 1 Circuit Short to Vbatt<br>C1276 Park Brake Actuator Assembly Switch Applied Circuit Short to Gnd<br>C1277 STEERING Wheel Angle 1and 2 Circuit Failure<br>C1278 STEERING Wheel Angle 1and 2 Signal Faulted<br>C1279 Yaw Rate Sensor circuit Failure<br>C1280 Yaw Rate Sensor Signal Fault<br>C1281 Lateral Accelerometer circuit Failure<br>C1282 Lateral Accelerometer Signal Fault<br>C1283 Switch Test Signal Failure<br>C1284 Oil Pressure Switch Failure<br>C1285 Booster Solenoid circuit Failure<br>C1286 Booster Mechanical Failure<br>C1287 Booster Pedal Force switch circuit Failure<br>C1288 Pressure Transducer Main / Primary Input Circuit Failure<br>C1289 Pressure Transducer Redundant / Secondary Input Circuit Failure<br>C1400 Traction Control Valve RF Circuit Failure<br>C1401 Traction Control Valve RF Circuit Open<br>C1402 Traction Control Valve RF Circuit Short To Ground<br>C1403 Traction Control Valve RF Circuit Short To Battery<br>C1404 Traction Control Valve Rear Circuit Failure<br>C1405 Traction Control Valve Rear Circuit Open<br>C1406 Traction Control Valve Rear Circuit Short To Ground<br>C1407 Traction Control Valve Rear Circuit Short To Battery<br>C1410 Traction Control Valve LF Circuit Failure<br>C1411 Traction Control Valve LF Circuit Open<br>C1412 Traction Control Valve LF Circuit Short To Ground<br>C1413 Traction Control Valve LF Circuit Short To Battery<br>C1414 Incorrect Module Design Level<br>C1415 Incorrect Module Configuration<br>C1416 Damper RF Circuit Short To Battery<br>C1417 Damper RF Circuit Short to Ground<br>C1418 Damper RF Circuit Failure<br>C1419 Damper RF Circuit Open<br>C1420 Hydraulic Fluid Pressure/ Flow Circuit Short to Vbatt<br>C1421 Damper LF Circuit Short To Battery<br>C1422 Damper LF Circuit Short to Ground<br>C1423 Damper LF Circuit Failure<br>C1424 Damper LF Circuit Open<br>C1425 Damper RR Circuit Short to Ground<br>C1426 Damper RR Circuit Short To Battery<br>C1427 Damper RR Circuit Open<br>C1428 Damper RR Circuit Failure<br>C1429 Input-shaft-speed input circuit failure<br>C1430 Damper LR Circuit Open<br>C1431 Damper LR Circuit Short To Battery<br>C1432 Damper LR Circuit Short to Ground<br>C1433 Damper LR Circuit Failure<br>C1435 Accelerometer Rear Circuit Failure<br>C1436 Accelerometer Rear Circuit Signal Is Not Sensed<br>C1437 Accelerometer Rear Circuit Short To Ground<br>C1438 Accelerometer Rear Circuit Short To Battery<br>C1439 Vehicle Acceleration EEC-IV Circuit Failure<br>C1440 Pressure Transducer Main / Primary signal Faulted<br>C1441 Steering Phase A Circuit Signal Is Not Sensed<br>C1442 Steering Phase B Circuit Signal Is Not Sensed<br>C1443 Steering Phase A Circuit Short To Ground<br>C1444 Steering Phase B Circuit Short To Ground<br>C1445 Speed Vehicle Signal Circuit Failure<br>C1446 Brake Switch Circuit Failure<br>C1447 Traction Control Module Request Circuit Failure<br>C1448 Lamp Adaptive Damping Warning Circuit Failure<br>C1449 Traction Control Motor Coherency Fault<br>C1450 Traction Control Motor Circuit Failure<br>C1451 Traction Control Motor Circuit Open<br>C1452 Traction Control Motor Circuit Short to Battery<br>C1453 Traction Control Motor Circuit Short to Ground<br>C1454 Front Lateral Accelerometer Circuit Failure<br>C1455 Accelerometer Front Circuit Failure<br>C1456 Accelerometer Front Circuit Is Not Sensed<br>C1457 Accelerometer Front Circuit Short To Ground<br>C1458 Accelerometer Front Circuit Short To Battery<br>C1459 Adaptive Mode Switch Circuit Failure<br>C1460 Vehicle Accelerometer Power Circuit Failure<br>C1461 Vehicle Accelerometer Power Circuit Short to Battery<br>C1462 Left Front Vertical Accelerometer Circuit Failure<br>C1463 Right Front Vertical Accelerometer Circuit Failure<br>C1464 Pressure Transducer Redundant / Secondary Signal Faulted<br>C1465 Damper High Side Front Circuit Short To Battery<br>C1466 Damper Circuit Failure<br>C1467 Damper High Side Rear Circuit Short To Battery<br>C1468 Damper Low Side Front Circuit Failure<br>C1469 Damper Low Side Rear Circuit Failure<br>C1495 Traction Control Motor Potentiometer Circuit Failure<br>C1496 Traction Control Motor Potentiometer Circuit Open<br>C1497 Traction Control Motor Potentiometer Circuit Short to Battery<br>C1498 Traction Control Motor Potentiometer Circuit Short to Ground<br>C1499 Transfer Case Contact Plate "A" Encoder Circuit Failure<br>C1500 Transfer Case Contact Plate "B" Encoder Circuit Failure<br>
C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure<br>C1502 Transfer Case Contact Plate "D" Encoder Circuit Failure<br>C1503 Dynamic Stability Control Left Front Valve Malfunction<br>C1504 Dynamic Stability Control Right Front Valve Malfunction<br>C1505 Dynamic Stability Control Left Rear Valve Malfunction<br>C1506 Dynamic Stability Control Right Rear Valve Malfunction<br>C1507 Traction Control of Brake Exceeds Time-Out<br>C1508 Traction Control of Engine Exceeds Time-Out<br>C1510 Right Front Wheel Pressure Reduction Performance Problem<br>C1511 Left Front Wheel Pressure Reduction Performance Problem<br>C1512 Right Rear Wheel Pressure Reduction Performance Problem<br>C1513 Left rear Wheel Pressure Reduction Performance Problem<br>C1699 Left Rear Sensor Circuit Short to Vbat<br>C1700 Left Rear Sensor Circuit Failure<br>C1701 Left Rear Sensor Circuit Fault<br>C1702 RightRear Sensor Circuit Short to Vbat<br>C1703 Right Rear Sensor Circuit Failure<br>C1704 Right Rear Sensor Circuit Fault<br>C1705 Left Rear Center Sensor Circuit Short to Vbat<br>C1706 Left Rear Center Sensor Circuit Failure<br>C1707 Left Rear Center Sensor Circuit Fault<br>C1708 Right Rear Center Sensor Circuit Short to Vbat<br>C1709 Right Rear Center Sensor Circuit Failure<br>C1710 Right Rear Center Sensor Circuit Fault<br>C1711 Left Front Sensor Circuit Short to Vbat<br>C1712 Left Front Sensor Circuit Failure<br>C1713 Left Front Sensor Circuit Fault<br>C1714 Right Front Sensor Circuit Short to Vbat<br>C1715 Right Front Sensor Circuit Failure<br>C1716 Right Front Sensor Circuit Fault<br>C1717 Left Front Center Sensor Circuit Short to Vbat<br>C1718 Left Front Center Sensor Circuit Failure<br>C1719 Left Front Center Sensor Circuit Fault<br>C1721 Air Suspension Height Sensor Power Circuit Open<br>C1722 Air Suspension Height Sensor Power Circuit Short To Battery<br>C1723 Air Suspension Height Sensor Power Circuit Short To Ground<br>C1724 Air Suspension Height Sensor Power Circuit Failure<br>C1725 Air Suspension Front Pneumatic Failure<br>C1726 Air Suspension Rear Pneumatic Failure<br>C1727 Air Suspension Reservoir Pneumatic Failure<br>C1728 Transfer Case unable to transition between 2H and 4H<br>C1729 Transfer Case unable to transition between 4H and 4L<br>C1730 Reference Voltage Out of Range (+5 v)<br>C1731 Air Suspension LF Corner Up Timeout<br>C1732 Air Suspension LF Corner Down Timeout<br>C1733 Air Suspension RF Corner Up Timeout<br>C1734 Air Suspension RF Corner Down Timeout<br>C1735 Air Suspension LR Corner Up Timeout<br>C1736 Air Suspension LR Corner Down Timeout<br>C1737 Air Suspension RR Corner Up Timeout<br>C1738 Air Suspension RR Corner Down Timeout<br>C1739 Right Front Center Sensor Circuit Short to Vbat<br>C1740 Right Front Center Sensor Circuit Failure<br>C1741 Right Front Center Sensor Circuit Fault<br>C1742 Rear Sounder Circuit Failure<br>C1743 Rear Sounder Circuit Short to Vbatt<br>C1744 Front Sounder Circuit Failure<br>C1745 Front Sounder Circuit Short to Vbatt<br>C1748 Switch input Circuit Short to Gnd<br>C1749 Trailer Input Circuit Failure<br>C1750 Accelerator Position Sensor Out of Range<br>C1751 Vehicle Speed Sensor # 1 Output Circuit Short to Vbatt<br>C1752 Vehicle Speed Sensor # 1 Output Circuit Short to Gnd<br>C1753 Hydraulic Clutch Actuator Valve Signal Fault<br>C1754 Hydraulic Clutch Actuator Valve Circuit Failure<br>C1755 Power Limit Shutdown Fault<br>C1756 Air Suspension Front Height Sensor High (SE) Signal Circuit Failure<br>C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open<br>C1758 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Battery<br>C1759 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Ground<br>C1760 Air Suspension Rear Height Sensor High (SE) Signal Circuit Failure<br>C1761 Air Suspension Rear Height Sensor High (SE) Signal Circuit Open<br>C1762 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Battery<br>C1763 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Ground<br>C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure<br>C1766 Air Suspension Rear Height Sensor Low Signal Circuit Open<br>C1767 Air Suspension Rear Height Sensor Low Signal Circuit Short To Battery<br>C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground<br>C1770 Air Suspension Vent Solenoid Output Circuit Failure<br>C1771 Air Suspension Vent Solenoid Output Circuit Open<br>C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery<br>C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground<br>C1774 Coolant Temp Out of Range<br>C1775 DC-DC Converter Failure<br>C1776 Heater System Failure<br>C1777 Vacuum Pressure Circuit Failure<br>C1778 Power Steering Failure<br>C1779 Blower Switch Failure<br>C1780 Temperature Select Failure<br>C1781 Engine Coolant Temperature Signal Missing/Fault<br>C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure<br>C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open<br>C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery<br>C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground<br>C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure<br>C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open<br>C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery<br>C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground<br>C1800 Air Suspension Reservoir Solenoid Circuit Failure<br>C1805 Mismatched PCM and/or ABS-TC Module<br>C1813 Air Suspension LR Vent Request Exceeded Max Timing<br>C1814 Air Suspension RR Vent Request Exceeded Max Timing<br>C1818 Air Suspension LR Air Compress Request Exceeded Max Timing<br>C1819 Air Suspension RR Air Compress Request Exceeded Max Timing<br>C1820 Air Suspension RF Air Compress Request Exceeded Max Timing<br>C1830 Air Suspension Compressor Relay Circuit Failure<br>C1831 Air Suspension Compressor Relay Circuit Open<br>C1832 Air Suspension Compressor Relay Circuit Short To Battery<br>C1833 Air Suspension Compressor Relay Circuit Short To Ground<br>C1834 Gauge Drive Current Fault<br>C1835 Current Sense Circuit Failure<br>C1836 Battery Temp out of Range<br>C1837 Battery Heater Circuit Failure<br>C1838 Charging System Fault<br>C1839 Leakage Fault<br>C1840 Air Suspension Disable Switch Circuit Failure<br>C1841 Air Suspension Disable Switch Circuit Open<br>C1842 Air Suspension Disable Switch Circuit Short To Battery<br>C1843 Air Suspension Disable Switch Circuit Short To Ground<br>C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure<br>C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure<br>C1846 Air Suspension Front Inflator Solenoid Output Circuit Open<br>C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery<br>C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground<br>C1849 Master Cylinder Pressure Out of Range<br>C1850 Air Suspension Warning Lamp Circuit Failure<br>C1851 Air Suspension Warning Lamp Circuit Open<br>C1852 Air Suspension Warning Lamp Circuit Short To Battery<br>C1853 Air Suspension Warning Lamp Circuit Short To Ground<br>C1854 Motor Temperature Out of Range<br>C1855 Acceleration Position Sensor Conflict<br>C1856 Traction Motor Encoder circuit Failure<br>C1859 PRNDL Input #2 Circuit Failure<br>C1860 PRNDL Input #3 Circuit Failure<br>C1861 PRNDL Input #4 Circuit Failure<br>C1862 Contactor Circuit Failure<br>C1863 External Charging Fault<br>C1864 Battery Module Fault<br>C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure<br>C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open<br>C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery<br>C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground<br>C1869 Air Suspension Gate Solenoid Output Circuit Failure<br>C1870 Air Suspension Gate Solenoid Output Circuit Open<br>C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery<br>C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground<br>C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure<br>C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open<br>C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery<br>C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground<br>C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure<br>C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open<br>C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery<br>C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground<br>C1881 Air Suspension RF Height Sensor Circuit Failure<br>C1882 Air Suspension RF Height Sensor Circuit Open<br>C1883 Air Suspension RF Height Sensor Circuit Short To Battery<br>C1884 Air Suspension RF Height Sensor Circuit Short To Ground<br>C1885 Air Suspension RR Height Sensor Circuit Failure<br>C1886 Air Suspension RR Height Sensor Circuit Open<br>C1887 Air Suspension RR Height Sensor Circuit Short To Battery<br>C1888 Air Suspension RR Height Sensor Circuit Short To Ground<br>C1889 Air Suspension LF Height Sensor Circuit Failure<br>C1890 Air Suspension LF Height Sensor Circuit Open<br>C1891 Air Suspension LF Height Sensor Circuit Short To Battery<br>C1892 Air Suspension LF Height Sensor Circuit Short To Ground<br>C1893 Air Suspension LR Height Sensor Circuit Failure<br>C1894 Air Suspension LR Height Sensor Circuit Open<br>C1895 Air Suspension LR Height Sensor Circuit Short To Battery<br>C1896 Air Suspension LR Height Sensor Circuit Short To Ground<br>C1897 Steering VAPS II Circuit Loop Failure<br>C1898 Steering VAPS II Circuit Loop Open<br>C1899 Steering VAPS II Circuit Loop Short To Battery<br>C1900 Steering VAPS II Circuit Loop Short To Ground<br>C1901 Ride Control RR Shock Actuator Circuit Failure<br>C1902 Ride Control RR Shock Actuator Circuit Open<br>C1903 Ride Control RR Shock Actuator Circuit Short To Battery<br>C1904 Ride Control RR Shock Actuator Circuit Short To Ground<br>C1905 Ride Control LR Shock Actuator Circuit Failure<br>C1906 Ride Control LR Shock Actuator Circuit Open<br>C1907 Ride Control LR Shock Actuator Circuit Short To Battery<br>C1908 Ride Control LR Shock Actuator Circuit Short To Ground<br>C1909 Ride Control RF Shock Actuator Circuit Failure<br>C1910 Ride Control RF Shock Actuator Circuit Open<br>C1911 Ride Control RF Shock Actuator Circuit Short To Battery<br>C1912 Ride Control RF Shock Actuator Circuit Short To Ground<br>C1913 Ride Control LF Shock Actuator Circuit Failure<br>C1914 Ride Control LF Shock Actuator Circuit Open<br>C1915 Ride Control LF Shock Actuator Circuit Short To Battery<br>C1916 Ride Control LF Shock Actuator Circuit Short To Ground<br>C1917 Steering EVO Out-of-Range Fault<br>C1918 Air Suspension Ride Height Select Switch Circuit Failure<br>C1920 Led #1 Circuit Failure<br>C1921 VAPS Solenoid Actuator Output Circuit Failure<br>C1922 VAPS Solenoid Actuator Output Circuit Open<br>C1923 VAPS Solenoid Actuator Output Circuit Short To Battery<br>C1924 VAPS Solenoid Actuator Output Circuit Short To Ground<br>C1925 VAPS Solenoid Actuator Return Circuit Failure<br>C1926 VAPS Solenoid Actuator Return Circuit Open<br>C1927 VAPS Solenoid Actuator Return Circuit Short To Battery<br>C1928 VAPS Solenoid Actuator Return Circuit Short To Ground<br>C1929 Air Suspension Front Compressor Relay Circuit Failure<br>C1930 Air Suspension Front Compressor Relay Circuit Open<br>C1931 Air Suspension Front Compressor Relay Circuit Short To Battery<br>C1932 Air Suspension Front Compressor Relay Circuit Short To Ground<br>C1933 Solenoid Current Out Of Range<br>C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure<br>C1935 Chime Circuit Failure<br>C1936 Hydraulic Pump Relay Circuit Failure<br>C1937 Steering Wheel Angle Sensor Offset Failure<br>C1938 Invalid Steering Wheel Angle Sensor ID<br>C1939 Brake Pressure Switch Input Circuit Failure<br>C1940 Brake Pressure Switch Mechanical Failure<br>C1942 Unrecognized Powertrain Configuration<br>C1943 Airbag Deployment Indication Input Fault<br>C1944 Gauge Driver Circuit Fault<br>C1945 Park Switch Indicates Park with Vehicle Moving<br>C1946 Seat Track Position Switch Circuit Open<br>C1947 Seat Track Position Switch Circuit Short to Ground<br>C1948 Seat Track Position Switch Circuit Resistance Out of Range<br>C1949 Accelerometer Sensor Circuit Open<br>C1950 Accelerometer Sensor Circuit Failure<br>C1951 Lateral Accelerometer Sensor Circuit Open<br>C1952 Yaw Rate Sensor Circuit Open<br>C1953 Master Cylinder Pressure Sensor Circuit Open<br>C1954 Master Cylinder Pressure Sensor Circuit Failure<br>C1955 Steering Angle Sensor Circuit Open<br>C1956 Steering Angle Sensor Circuit Failure<br>C1957 Dynamic Stability Control Valve RF Circuit Failure<br>C1958 Dynamic Stability Control Valve LF Circuit Failure<br>C1959 Lateral Accelerometer Sensor Circuit Failure<br>C1960 Driver Brake Apply Circuit Fault<br>C1961 Park Lamp Relay Coil Circuit Failure<br>C1962 Park Lamp Relay Coil Short to Battery<br>C1963 Stability Control Inhibit Warning<br>
B1200 Climate Control Pushbutton Circuit Failure<br>B1201 Fuel Sender Circuit Failure<br>B1202 Fuel Sender Circuit Open<br>B1203 Fuel Sender Circuit Short To Battery<br>B1204 Fuel Sender Circuit Short To Ground<br>B1205 EIC Switch-1 Assembly Circuit Failure<br>B1206 EIC Switch-1 Assembly Circuit Open<br>B1207 EIC Switch-1 Assembly Circuit Short To Battery<br>B1208 EIC Switch-1 Assembly Circuit Short To Ground<br>B1209 EIC Switch-2 Assembly Circuit Failure<br>B1210 EIC Switch-2 Assembly Circuit Open<br>B1211 EIC Switch-2 Assembly Circuit Short To Battery<br>B1212 EIC Switch-2 Assembly Circuit Short To Ground<br>B1213 Anti-Theft Number of Programmed Keys Is Below Minimum<br>B1214 Running Board Lamp Circuit Failure<br>B1215 Running Board Lamp Circuit Short to Battery<br>B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground<br>B1217 Horn Relay Coil Circuit Failure<br>B1218 Horn Relay Coil Circuit Short to Vbatt<br>B1219 Fuel Tank Pressure Sensor Circuit Failure<br>B1220 Fuel Tank Pressure Sensor Circuit Open<br>B1222 Fuel Temperature Sensor #1 Circuit Failure<br>B1223 Fuel Temperature Sensor #1 Circuit Open<br>B1224 Fuel Temperature Sensor #1 Circuit Short to Battery<br>B1225 Fuel Temperature Sensor #1 Circuit Short to Ground<br>B1226 Fuel Temperature Sensor #2 Circuit Failure<br>B1227 Fuel Temperature Sensor #2 Circuit Open<br>B1228 Fuel Temperature Sensor #2 Circuit Short to Battery<br>B1229 Fuel Temperature Sensor #2 Circuit Short to Ground<br>B1231 Longitudinal Acceleration Threshold Exceeded<br>B1232 See Manufacturer<br>B1233 Glass Break Sensor Failure<br>B1234 Mirror Switch Invalid Code<br>B1235 Window Feedback Failure<br>B1236 Window Feedback Loss of Signal<br>B1237 Window Feedback Out of Range<br>B1238 Over Temperature Fault<br>B1239 Air Flow Blend Door Driver Circuit Failure<br>B1240 Wiper Washer Rear Pump Relay Circuit Failure<br>B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery<br>B1242 Air Flow Recirculation Door Driver Circuit Failure<br>B1243 Express Window Down Switch Circuit Short to Battery<br>B1244 Wiper Rear Motor Run Relay Circuit Failure<br>B1245 Wiper Rear Motor Run Relay Circuit Short to Battery<br>B1246 Dim Panel Potentiometer Switch Circuit Failure<br>B1247 Panel Dim Switch Circuit Open<br>B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground<br>B1249 Blend Door Failure<br>B1250 Air Temperature Internal Sensor Circuit Failure<br>B1251 Air Temperature Internal Sensor Circuit Open<br>B1252 Air Temperature Internal Sensor Circuit Short To Battery<br>B1253 Air Temperature Internal Sensor Circuit Short To Ground<br>B1254 Air Temperature External Sensor Circuit Failure<br>B1255 Air Temperature External Sensor Circuit Open<br>B1256 Air Temperature External Sensor Circuit Short To Battery<br>B1257 Air Temperature External Sensor Circuit Short To Ground<br>B1258 Solar Radiation Sensor Circuit Failure<br>B1259 Solar Radiation Sensor Circuit Open<br>B1260 Solar Radiation Sensor Circuit Short To Battery<br>B1261 Solar Radiation Sensor Circuit Short To Ground<br>B1262 Servo Motor Defrost Circuit Failure<br>B1263 Servo Motor Vent Circuit Failure<br>B1264 Servo Motor Foot Circuit Failure<br>B1265 Servo Motor Coolair Bypass Circuit Failure<br>B1266 Servo Motor Airintake Left Circuit Failure<br>B1267 Servo Motor Airintake Right Circuit Failure<br>B1268 Servo Motor Potentiometer Defrost Circuit Failure<br>B1269 Servo Motor Potentiometer Defrost Circuit Open<br>B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery<br>B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground<br>B1272 Servo Motor Potentiometer Vent Circuit Failure<br>B1273 Servo Motor Potentiometer Vent Circuit Open<br>B1274 Servo Motor Potentiometer Vent Circuit Short To Battery<br>B1275 Servo Motor Potentiometer Vent Circuit Short To Ground<br>B1276 Servo Motor Potentiometer Foot Circuit Failure<br>B1277 Servo Motor Potentiometer Foot Circuit Open<br>B1278 Servo Motor Potentiometer Foot Circuit Short To Battery<br>B1279 Servo Motor Potentiometer Foot Circuit Short To Ground<br>B1280 Servo Motor Potentiometer Coolair Circuit Failure<br>B1281 Servo Motor Potentiometer Coolair Circuit Open<br>B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery<br>B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground<br>B1284 Servo Motor Potentiometer Airintake Left Circuit Failure<br>B1285 Servo Motor Potentiometer Airintake Left Circuit Open<br>B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery<br>B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground<br>B1288 Servo Motor Potentiometer Airintake Right Circuit Failure<br>B1289 Servo Motor Potentiometer Airintake Right Circuit Open<br>B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery<br>B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground<br>B1292 Battery Power Relay Circuit Failure<br>B1293 Battery Power Relay Circuit Open<br>B1294 Battery Power Relay Circuit Short To Battery<br>B1295 Battery Power Relay Circuit Short To Ground<br>B1296 Power Supply Sensor Circuit Failure<br>B1297 Power Supply Sensor Circuit Open<br>B1298 Power Supply Sensor Circuit Short To Battery<br>B1299 Power Supply Sensor Circuit Short To Ground<br>B1300 Power Door Lock Circuit Failure<br>B1301 Power Door Lock Circuit Open<br>B1302 Accessory Delay Relay Coil Circuit Failure<br>B1303 Accessory Delay Relay Coil Circuit Open<br>B1304 Accessory Delay Relay Coil Circuit Short To Battery<br>B1305 Accessory Delay Relay Coil Circuit Short To Ground<br>B1306 Oil Level Switch Circuit Open<br>B1307 Oil Level Switch Circuit Short To Battery<br>B1308 Oil Level Switch Circuit Short To Ground<br>B1309 Power Door Lock Circuit Short To Ground<br>B1310 Power Door Unlock Circuit Failure<br>B1311 Power Door Unlock Circuit Open<br>B1312 Lamp Headlamp Input Circuit Short To Battery<br>B1313 Battery Saver Relay Coil Circuit Failure<br>B1314 Battery Saver Relay Coil Circuit Open<br>B1315 Battery Saver Relay Coil Circuit Short To Battery<br>B1316 Battery Saver Relay Coil Circuit Short To Ground<br>B1317 Battery Voltage High<br>B1318 Battery Voltage Low<br>B1319 Driver Door Ajar Circuit Failure<br>B1320 Driver Door Ajar Circuit Open<br>B1321 Driver Door Ajar Circuit Short To Battery<br>B1322 Driver Door Ajar Circuit Short To Ground<br>B1323 Door Ajar Lamp Circuit Failure<br>B1324 Door Ajar Lamp Circuit Open<br>B1325 Door Ajar Lamp Circuit Short To Battery<br>B1326 Door Ajar Lamp Circuit Short To Ground<br>B1327 Passenger Door Ajar Circuit Failure<br>B1328 Passenger Door Ajar Circuit Open<br>B1329 Passenger Door Ajar Circuit Short To Battery<br>B1330 Passenger Door Ajar Circuit Short To Ground<br>B1331 Decklid Ajar Rear Door Circuit Failure<br>B1332 Decklid Ajar Rear Door Circuit Open<br>B1333 Decklid Ajar Rear Door Circuit Short To Battery<br>B1334 Decklid Ajar Rear Door Circuit Short To Ground<br>B1335 Door Ajar RR Circuit Failure<br>B1336 Door Ajar RR Circuit Open<br>B1337 Door Ajar RR Circuit Short To Battery<br>B1338 Door Ajar RR Circuit Short To Ground<br>B1339 Chime Input Request Circuit Short To Battery<br>B1340 Chime Input Request Circuit Short To Ground<br>B1341 Power Door Unlock Circuit Short To Ground<br>B1342 ECU Is Defective<br>B1343 Heated Backlite Input Circuit Failure<br>B1344 Heated Backlite Input Circuit Open<br>B1345 Heated Backlite Input Circuit Short To Ground<br>B1346 Heated Backlite Input Circuit Short To Battery<br>B1347 Heated Backlite Relay Circuit Failure<br>B1348 Heated Backlite Relay Circuit Open<br>B1349 Heated Backlite Relay Short To Battery<br>B1350 Heated Backlite Relay Short To Ground<br>B1351 Ignition Key-In Circuit Short To Battery<br>B1352 Ignition Key-In Circuit Failure<br>B1353 Ignition Key-In Circuit Open<br>B1354 Ignition Key-In Circuit Short To Ground<br>B1355 Ignition Run Circuit Failure<br>B1356 Ignition Run Circuit Open<br>B1357 Ignition Run Circuit Short To Battery<br>B1358 Ignition Run Circuit Short To Ground<br>B1359 Ignition Run/Acc Circuit Failure<br>B1360 Ignition Run/Acc Circuit Open<br>B1361 Ignition Run/Acc Circuit Short To Battery<br>B1362 Ignition Run/Acc Circuit Short To Ground<br>B1363 Ignition Start Circuit Failure<br>B1364 Ignition Start Circuit Open<br>B1365 Ignition Start Circuit Short To Battery<br>B1366 Ignition Start Circuit Short To Ground<br>B1367 Ignition Tach Circuit Failure<br>B1368 Ignition Tach Circuit Open<br>B1369 Ignition Tach Circuit Short To Battery<br>B1370 Ignition Tach Circuit Short To Ground<br>B1371 Illuminated Entry Relay Circuit Failure<br>B1372 Illuminated Entry Relay Circuit Open<br>B1373 Illuminated Entry Relay Short To Battery<br>B1374 Illuminated Entry Relay Short To Ground<br>B1375 Oil Change Lamp Circuit Open<br>B1376 Oil Change Lamp Circuit Short To Battery<br>B1377 Oil Change Lamp Circuit Failure<br>B1378 Oil Change Lamp Circuit Short To Ground<br>B1379 Oil Change Reset Button Circuit Short To Ground<br>B1380 Oil Change Reset Button Circuit Failure<br>B1381 Oil Change Reset Button Circuit Open<br>B1382 Oil Change Reset Button Circuit Short To Battery<br>B1383 Oil Level Lamp Circuit Short To Battery<br>B1384 Oil Level Lamp Circuit Failure<br>B1385 Oil Level Lamp Circuit Open<br>B1386 Oil Level Lamp Circuit Short To Ground<br>B1387 Oil Temperature Sensor Circuit Open<br>B1388 Oil Temperature Sensor Circuit Short To Battery<br>B1389 Oil Temperature Sensor Circuit Failure<br>B1390 Oil Temperature Sensor Circuit Short To Ground<br>B1391 Oil Level Switch Circuit Failure<br>B1392 Power Door Memory Lock Relay Circuit Failure<br>B1393 Power Door Memory Lock Relay Circuit Open<br>B1394 Power Door Memory Lock Relay Circuit Short To Battery<br>B1395 Power Door Memory Lock Relay Circuit Short To Ground<br>B1396 Power Door Lock Circuit Short To Battery<br>B1397 Power Door Unlock Circuit Short To Battery<br>B1398 Driver Power Window One Touch Window Relay Circuit Failure<br>B1399 Driver Power Window One Touch Window Relay Circuit Open<br>B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery<br>B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground<br>B1402 Driver Power Window Down Switch Circuit Failure<br>B1403 Driver Power Window Up Switch Circuit Failure<br>B1404 Driver Power Window Down Circuit Open<br>B1405 Driver Power Window Down Circuit Short To Battery<br>B1406 Driver Power Window Down Circuit Short To Ground<br>B1407 Driver Power Window Up Circuit Open<br>B1408 Driver Power Window Up Circuit Short To Battery<br>B1409 Driver Power Window Up Circuit Short To Ground<br>B1410 Driver Power Window Motor Circuit Failure<br>B1411 Driver Power Window Motor Circuit Open<br>B1412 Driver Power Window Motor Circuit Short To Battery<br>B1413 Driver Power Window Motor Circuit Short To Ground<br>B1414 Power Window LR Motor Circuit Failure<br>B1415 Power Window LR Motor Circuit Open<br>B1416 Power Window LR Motor Circuit Short To Battery<br>B1417 Power Window LR Motor Circuit Short To Ground<br>B1418 Passenger Power Window Motor Circuit Failure<br>B1419 Passenger Power Window Motor Circuit Open<br>B1420 Passenger Power Window Motor Circuit Short To Battery<br>B1421 Passenger Power Window Motor Circuit Short To Ground<br>B1422 Power Window RR Motor Circuit Failure<br>B1423 Power Window RR Motor Circuit Open<br>B1424 Power Window RR Motor Circuit Short To Battery<br>B1425 Power Window RR Motor Circuit Short To Ground<br>B1426 Lamp Seat Belt Circuit Short To Battery<br>B1427 Lamp Seat Belt Circuit Open<br>B1428 Lamp Seat Belt Circuit Failure<br>B1429 Lamp Seat Belt Circuit Short To Ground<br>B1430 Seat Belt Switch Circuit Short To Ground<br>B1431 Wiper Brake/Run Relay Circuit Failure<br>B1432 Wiper Brake/Run Relay Circuit Short To Battery<br>B1433 Wiper Brake/Run Relay Circuit Short To Ground<br>B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure<br>B1435 Wiper Hi/Low Speed Relay Coil Circuit Open<br>B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery<br>B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground<br>B1438 Wiper Mode Select Switch Circuit Failure<br>B1439 Wiper Mode Select Switch Circuit Open<br>B1440 Wiper Mode Select Switch Circuit Short To Battery<br>B1441 Wiper Mode Select Switch Circuit Short To Ground<br>B1442 Door Handle Switch Circuit Failure<br>B1443 Door Handle Switch Circuit Open<br>B1444 Door Handle Switch Circuit Short To Battery<br>B1445 Door Handle Switch Circuit Short To Ground<br>B1446 Wiper Park Sense Circuit Failure<br>B1447 Wiper Park Sense Circuit Open<br>B1448 Wiper Park Sense Circuit Short To Battery<br>B1449 Wiper Park Sense Circuit Short To Ground<br>B1450 Wiper Wash/Delay Switch Circuit Failure<br>B1451 Wiper Wash/Delay Switch Circuit Open<br>B1452 Wiper Wash/Delay Switch Circuit Short To Battery<br>B1453 Wiper Wash/Delay Switch Circuit Short To Ground<br>B1454 Wiper Washer Fluid Lamp Circuit Failure<br>B1455 Wiper Washer Fluid Lamp Circuit Open<br>B1456 Wiper Washer Fluid Lamp Circuit Short To Battery<br>B1457 Wiper Washer Fluid Lamp Circuit Short To Ground<br>B1458 Wiper Washer Pump Motor Relay Circuit Failure<br>B1459 Wiper Washer Pump Motor Relay Coil Circuit Open<br>B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery<br>B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground<br>B1462 Seat Belt Switch Circuit Failure<br>B1463 Seat Belt Switch Circuit Open<br>B1464 Seat Belt Switch Circuit Short To Battery<br>B1465 Wiper Brake/Run Relay Circuit Open<br>B1466 Wiper Hi/Low Speed Not Switching<br>B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery<br>B1468 Chime Input Request Circuit Failure<br>B1469 Chime Input Request Circuit Open<br>B1470 Lamp Headlamp Input Circuit Failure<br>B1471 Lamp Headlamp Input Circuit Open<br>B1472 Lamp Headlamp Input Circuit Short To Ground<br>B1473 Wiper Low Speed Circuit Motor Failure<br>B1474 Battery Saver Power Relay Circuit Short To Battery<br>B1475 Accessory Delay Relay Contact Short To Battery<br>B1476 Wiper High Speed Circuit Motor Failure<br>B1477 Wiper Hi/Low Circuit Motor Short To Ground<br>B1478 Power Window One Touch Up/Down Activated Simultaneously<br>B1479 Wiper Washer Fluid Level Sensor Circuit Failure<br>B1480 Wiper Washer Fluid Level Sensor Circuit Open<br>B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery<br>B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground<br>B1483 Brake Pedal Input Circuit Failure<br>B1484 Brake Pedal Input Open Circuit<br>B1485 Brake Pedal Input Circuit Battery Short<br>B1486 Brake Pedal Input Circuit Ground Short<br>B1487 Door Handle Right Front Circuit Failure<br>B1488 Door Handle Right Front Circuit Open<br>B1489 Door Handle Right Front Short To Battery<br>B1490 Door Handle Right Front Short To Ground<br>B1491 Ignition Cylinder Sensor Circuit Failure<br>B1492 Ignition Cylinder Sensor Open Circuit<br>B1493 Ignition Cylinder Sensor Battery Short<br>B1494 Ignition Cylinder Sensor Ground Short<br>B1495 Decklid Punch-Out Sensor Circuit Failure<br>B1496 Decklid Punch-Out Sensor Open Circuit<br>B1497 Decklid Punch-Out Sensor Battery Short<br>B1498 Decklid Punch-Out Sensor Ground Short<br>B1499 Lamp Turn Signal Left Circuit Failure<br>B1500 Lamp Turn Signal Left Circuit Open<br>
B1501 Lamp Turn Signal Left Circuit Short To Battery<br>B1502 Lamp Turn Signal Left Circuit Short To Ground<br>B1503 Lamp Turn Signal Right Circuit Failure<br>B1504 Lamp Turn Signal Right Circuit Open<br>B1505 Lamp Turn Signal Right Circuit Short To Battery<br>B1506 Lamp Turn Signal Right Circuit Short To Ground<br>B1507 Flash To Pass Switch Circuit Failure<br>B1508 Flash To Pass Switch Circuit Open<br>B1509 Flash To Pass Switch Circuit Short To Battery<br>B1510 Flash To Pass Switch Circuit Short To Ground<br>B1511 Driver Door Handle Circuit Failure<br>B1512 Driver Door Handle Circuit Open<br>B1513 Driver Door Handle Circuit Short To Battery<br>B1514 Driver Door Handle Circuit Short To Ground<br>B1515 Seat Driver Occupied Switch Circuit Failure<br>B1516 Seat Driver Occupied Switch Circuit Open<br>B1517 Seat Driver Occupied Switch Circuit Short To Battery<br>B1518 Seat Driver Occupied Switch Circuit Short To Ground<br>B1519 Hood Switch Circuit Failure<br>B1520 Hood Switch Circuit Open<br>B1521 Hood Switch Circuit Short To Battery<br>B1522 Hood Switch Circuit Short To Ground<br>B1523 Keyless Entry Circuit Failure<br>B1524 Keyless Entry Circuit Open<br>B1525 Keyless Entry Circuit Short To Battery<br>B1526 Keyless Entry Circuit Short To Ground<br>B1527 Memory Set Switch Circuit Failure<br>B1528 Memory Set Switch Circuit Open<br>B1529 Memory Set Switch Circuit Short To Battery<br>B1530 Memory Set Switch Circuit Short To Ground<br>B1531 Memory 1 Switch Circuit Failure<br>B1532 Memory 1 Switch Circuit Open<br>B1533 Memory 1 Switch Circuit Short To Battery<br>B1534 Memory 1 Switch Circuit Short To Ground<br>B1535 Memory 2 Switch Circuit Failure<br>B1536 Memory 2 Switch Circuit Open<br>B1537 Memory 2 Switch Circuit Short To Battery<br>B1538 Memory 2 Switch Circuit Short To Ground<br>B1539 Mirror Driver Switch Assembly Circuit Failure<br>B1540 Mirror Driver Switch Assembly Circuit Open<br>B1541 Mirror Driver Switch Assembly Circuit Short To Battery<br>B1542 Mirror Driver Switch Assembly Circuit Short To Ground<br>B1543 Seat Direction Switch Assembly Circuit Failure<br>B1544 Seat Direction Switch Assembly Circuit Open<br>B1545 Seat Direction Switch Assembly Circuit Short To Battery<br>B1546 Seat Direction Switch Assembly Circuit Short To Ground<br>B1547 Power Window Master Circuit Failure<br>B1548 Power Window Master Circuit Open<br>B1549 Power Window Master Circuit Short To Battery<br>B1550 Power Window Master Circuit Short To Ground<br>B1551 Decklid Release Circuit Failure<br>B1552 Decklid Release Circuit Open<br>B1553 Decklid Release Circuit Short To Battery<br>B1554 Decklid Release Circuit Short To Ground<br>B1555 Ignition Run/Start Circuit Failure<br>B1556 Ignition Run/Start Circuit Open<br>B1557 Ignition Run/Start Circuit Short To Battery<br>B1558 Ignition Run/Start Circuit Short To Ground<br>B1559 Door Lock Cylinder Circuit Failure<br>B1560 Door Lock Cylinder Circuit Open<br>B1561 Door Lock Cylinder Circuit Short To Battery<br>B1562 Door Lock Cylinder Circuit Short To Ground<br>B1563 Door Ajar Circuit Failure<br>B1564 Door Ajar Circuit Open<br>B1565 Door Ajar Circuit Short To Battery<br>B1566 Door Ajar Circuit Short To Ground<br>B1567 Lamp Headlamp High-Beam Circuit Failure<br>B1568 Lamp Headlamp High-Beam Circuit Open<br>B1569 Lamp Headlamp High-Beam Circuit Short To Battery<br>B1570 Lamp Headlamp High-Beam Circuit Short To Ground<br>B1571 Door Ajar LR Circuit Failure<br>B1572 Door Ajar LR Circuit Open<br>B1573 Door Ajar LR Circuit Short To Battery<br>B1574 Door Ajar LR Circuit Short To Ground<br>B1575 Lamp Park Input Circuit Failure<br>B1576 Lamp Park Input Circuit Open<br>B1577 Lamp Park Input Circuit Short To Battery<br>B1578 Lamp Park Input Circuit Short To Ground<br>B1579 Dim Panel Increase Input Circuit Failure<br>B1580 Dim Panel Increase Input Circuit Open<br>B1581 Dim Panel Increase Input Circuit Short To Battery<br>B1582 Dim Panel Increase Input Circuit Short To Ground<br>B1583 Dim Panel Decrease Input Circuit Failure<br>B1584 Dim Panel Decrease Input Circuit Open<br>B1585 Dim Panel Decrease Input Circuit Short To Battery<br>B1586 Dim Panel Decrease Input Circuit Short To Ground<br>B1587 Autolamp Delay Increase Circuit Failure<br>B1588 Autolamp Delay Increase Circuit Open<br>B1589 Autolamp Delay Increase Circuit Short To Battery<br>B1590 Autolamp Delay Increase Circuit Short To Ground<br>B1591 Autolamp Delay Decrease Circuit Failure<br>B1592 Autolamp Delay Decrease Circuit Open<br>B1593 Autolamp Delay Decrease Circuit Short To Battery<br>B1594 Autolamp Delay Decrease Circuit Short To Ground<br>B1595 Ignition Switch Illegal Input Code<br>B1596 Service Continuous Codes<br>B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground<br>B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground<br>B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground<br>B1600 PATS Ignition Key Transponder Signal Is Not Received<br>B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder<br>B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder<br>B1603 Lamp Anti-Theft Indicator Circuit Failure<br>B1604 Lamp Anti-Theft Indicator Circuit Open<br>B1605 Lamp Anti-Theft Indicator Circuit Short To Battery<br>B1606 Lamp Anti-Theft Indicator Circuit Short To Ground<br>B1607 Illuminated Entry Input Circuit Failure<br>B1608 Illuminated Entry Input Open Circuit<br>B1609 Illuminated Entry Input Short Circuit To Battery<br>B1610 Illuminated Entry Input Short Circuit To Ground<br>B1611 Wiper Rear Mode Select Switch Circuit Failure<br>B1612 Wiper Rear Mode Select Switch Circuit Open<br>B1613 Wiper Rear Mode Select Switch Circuit Short To Battery<br>B1614 Wiper Rear Mode Select Switch Circuit Short To Ground<br>B1615 Wiper Rear Disable Switch Circuit Failure<br>B1616 Wiper Rear Disable Switch Circuit Open<br>B1617 Wiper Rear Disable Switch Circuit Short To Battery<br>B1618 Wiper Rear Disable Switch Circuit Short To Ground<br>B1619 Wiper Rear Low Limit Input Circuit Failure<br>B1620 Wiper Rear Low Limit Input Circuit Open<br>B1621 Wiper Rear Low Limit Input Circuit Short To Battery<br>B1622 Wiper Rear Low Limit Input Circuit Short To Ground<br>B1623 Lamp Keypad Output Circuit Failure<br>B1624 Lamp Keypad Output Open Circuit<br>B1625 Lamp Keypad Output Short Circuit To Battery<br>B1626 Lamp Keypad Output Short Circuit To Ground<br>B1627 PRNDL Reverse Input Circuit Failure<br>B1628 PRNDL Reverse Input Open Circuit<br>B1629 PRNDL Reverse Input Short To Battery<br>B1630 PRNDL Reverse Input Short Circuit To Ground<br>B1631 Mirror Driver Left Circuit Failure<br>B1632 Mirror Driver Left Circuit Open<br>B1633 Mirror Driver Left Circuit Short To Battery<br>B1634 Mirror Driver Left Circuit Short To Ground<br>B1635 Mirror Driver Right Circuit Failure<br>B1636 Mirror Driver Right Circuit Open<br>B1637 Mirror Driver Right Circuit Short To Battery<br>B1638 Mirror Driver Right Short To Ground<br>B1639 Mirror Passenger Left Circuit Failure<br>B1640 Mirror Passenger Left Circuit Open<br>B1641 Mirror Passenger Left Circuit Short To Battery<br>B1642 Mirror Passenger Left Circuit Short To Ground<br>B1643 Mirror Passenger Right Circuit Failure<br>B1644 Mirror Passenger Right Circuit Open<br>B1645 Mirror Passenger Right Circuit Short To Battery<br>B1646 Mirror Passenger Right Circuit Short To Ground<br>B1647 Seat Driver Recline Forward Circuit Failure<br>B1648 Seat Driver Recline Forward Circuit Open<br>B1649 Seat Driver Recline Forward Circuit Short To Battery<br>B1650 Seat Driver Recline Forward Circuit Short To Ground<br>B1651 Seat Driver Recline Backward Circuit Failure<br>B1652 Seat Driver Recline Backward Circuit Open<br>B1653 Seat Driver Recline Backward Circuit Short To Battery<br>B1654 Seat Driver Recline Backward Circuit Short To Ground<br>B1655 Seat Driver Rear Up Circuit Failure<br>B1656 Seat Driver Rear Up Circuit Open<br>B1657 Seat Driver Rear Up Circuit Short To Battery<br>B1658 Seat Driver Rear Up Circuit Short To Ground<br>B1659 Seat Driver Front Up Circuit Failure<br>B1660 Seat Driver Front Up Circuit Open<br>B1661 Seat Driver Front Up Circuit Short To Battery<br>B1662 Seat Driver Front Up Circuit Short To Ground<br>B1663 Seat Driver Front Up/Down Motor Stalled<br>B1664 Seat Driver Rear Up/Down Motor Stalled<br>B1665 Seat Driver Forward/Backward Motor Stalled<br>B1666 Seat Driver Recline Motor Stalled<br>B1667 Mirror Driver Up/Down Motor Stalled<br>B1668 Mirror Driver Right/Left Motor Stalled<br>B1669 Mirror Passenger Up/Down Motor Stalled<br>B1670 Mirror Passenger Right/Left Motor Stalled<br>B1671 Battery Module Voltage Out Of Range<br>B1672 Seat Driver Occupied Input Circuit Failure<br>B1673 Seat Driver Occupied Input Circuit Open<br>B1674 Seat Driver Occupied Input Circuit Short To Battery<br>B1675 Seat Driver Occupied Input Circuit Short To Ground<br>B1676 Battery Pack Voltage Out Of Range<br>B1677 Alarm Panic Input Circuit Failure<br>B1678 Alarm Panic Input Circuit Open<br>B1679 Alarm Panic Input Circuit Short To Battery<br>B1680 Alarm Panic Input Circuit Short To Ground<br>B1681 PATS Transceiver Module Signal Is Not Received<br>B1682 PATS Is Disabled (Check Link Between PATS And Transponder)<br>B1683 Mirror Driver/Passenger Switch Circuit Failure<br>B1684 Mirror Driver/Passenger Switch Circuit Open<br>B1685 Lamp Dome Input Circuit Failure<br>B1686 Lamp Dome Input Circuit Open<br>B1687 Lamp Dome Input Circuit Short To Battery<br>B1688 Lamp Dome Input Circuit Short To Ground<br>B1689 Autolamp Delay Circuit Failure<br>B1690 Autolamp Delay Circuit Open<br>B1691 Autolamp Delay Circuit Short To Battery<br>B1692 Autolamp Delay Circuit Short To Ground<br>B1693 Autolamp On Circuit Failure<br>B1694 Autolamp On Circuit Open<br>B1695 Autolamp On Circuit Short To Battery<br>B1696 Autolamp On Circuit Short To Ground<br>B1697 Mirror Driver/Passenger Switch Circuit Short To Battery<br>B1698 Mirror Driver/Passenger Switch Circuit Short To Ground<br>B1699 Passenger's Seat Occupied Switch Circuit Short to Ground<br>B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
B1701 Seat Driver Recline Forward Switch Circuit Failure<br>B1702 Seat Driver Recline Forward Switch Circuit Open<br>B1703 Seat Driver Recline Forward Switch Circuit Short To Battery<br>B1704 Seat Driver Recline Forward Switch Circuit Short To Ground<br>B1705 Seat Driver Recline Rearward Switch Circuit Failure<br>B1706 Seat Driver Recline Rearward Switch Circuit Open<br>B1707 Seat Driver Recline Rearward Switch Circuit Short To Battery<br>B1708 Seat Driver Recline Rearward Switch Circuit Short To Ground<br>B1709 Seat Driver Front Up Switch Circuit Failure<br>B1710 Seat Driver Front Up Switch Circuit Open<br>B1711 Seat Driver Front Up Switch Circuit Short To Battery<br>B1712 Seat Driver Front Up Switch Circuit Short To Ground<br>B1713 Seat Driver Front Down Switch Circuit Failure<br>B1714 Seat Driver Front Down Switch Circuit Open<br>B1715 Seat Driver Front Down Switch Circuit Short To Battery<br>B1716 Seat Driver Front Down Switch Circuit Short To Ground<br>B1717 Seat Driver Forward Switch Circuit Failure<br>B1718 Seat Driver Forward Switch Circuit Open<br>B1719 Seat Driver Forward Switch Circuit Short To Battery<br>B1720 Seat Driver Forward Switch Circuit Short To Ground<br>B1721 Seat Driver Rearward Switch Circuit Failure<br>B1722 Seat Driver Rearward Switch Circuit Open<br>B1723 Seat Driver Rearward Switch Circuit Short To Battery<br>B1724 Seat Driver Rearward Switch Circuit Short To Ground<br>B1725 Seat Driver Rear Up Switch Circuit Failure<br>B1726 Seat Driver Rear Up Switch Circuit Open<br>B1727 Seat Driver Rear Up Switch Circuit Short To Battery<br>B1728 Seat Driver Rear Up Switch Circuit Short To Ground<br>B1729 Seat Driver Rear Down Switch Circuit Failure<br>B1730 Seat Driver Rear Down Switch Circuit Open<br>B1731 Seat Driver Rear Down Switch Circuit Short To Battery<br>B1732 Seat Driver Rear Down Switch Circuit Short To Ground<br>B1733 Mirror Driver Vertical Switch Circuit Failure<br>B1734 Mirror Driver Vertical Switch Circuit Open<br>B1735 Mirror Driver Vertical Switch Circuit Short To Battery<br>B1736 Mirror Driver Vertical Switch Circuit Short To Ground<br>B1737 Mirror Driver Horizontal Switch Circuit Failure<br>B1738 Mirror Driver Horizontal Switch Circuit Open<br>B1739 Mirror Driver Horizontal Switch Circuit Short To Battery<br>B1740 Mirror Driver Horizontal Switch Circuit Short To Ground<br>B1741 Mirror Passenger Vertical Switch Circuit Failure<br>B1742 Mirror Passenger Vertical Switch Circuit Open<br>B1743 Mirror Passenger Vertical Switch Circuit Short To Battery<br>B1744 Mirror Passenger Vertical Switch Circuit Short To Ground<br>B1745 Mirror Passenger Horizontal Switch Circuit Failure<br>B1746 Mirror Passenger Horizontal Switch Circuit Open<br>B1747 Mirror Passenger Horizontal Switch Circuit Short To Battery<br>B1748 Mirror Passenger Horizontal Switch Circuit Short To Ground<br>B1749 Park/Neutral Switch Circuit Failure<br>B1750 Park/Neutral Switch Circuit Open<br>B1751 Park/Neutral Switch Circuit Short To Battery<br>B1752 Park/Neutral Switch Circuit Short To Ground<br>B1753 Hazard Flash Output Circuit Failure<br>B1754 Hazard Flash Output Circuit Open<br>B1755 Hazard Flash Output Circuit Short Battery<br>B1756 Hazard Flash Output Circuit Short To Ground<br>B1757 Seat Driver Rear Down Circuit Failure<br>B1758 Seat Driver Rear Down Circuit Open<br>B1759 Seat Driver Rear Down Circuit Short To Battery<br>B1760 Seat Driver Rear Down Circuit Short To Ground<br>B1761 Seat Driver Front Down Circuit Failure<br>B1762 Seat Driver Front Down Circuit Open<br>B1763 Seat Driver Front Down Circuit Short To Battery<br>B1764 Seat Driver Front Down Circuit Short To Ground<br>B1765 Seat Driver Forward Circuit Failure<br>B1766 Seat Driver Forward Circuit Open<br>B1767 Seat Driver Forward Circuit Short To Battery<br>B1768 Seat Driver Forward Circuit Short To Ground<br>B1769 Seat Driver Backward Circuit Failure<br>B1770 Seat Driver Backward Circuit Open<br>B1771 Seat Driver Backward Circuit Short To Battery<br>B1772 Seat Driver Backward Circuit Short To Ground<br>B1773 Mirror Driver Up Circuit Failure<br>B1774 Mirror Driver Up Circuit Open<br>B1775 Mirror Driver Up Circuit Short To Battery<br>B1776 Mirror Driver Up Circuit Short To Ground<br>B1777 Driver's Seatbelt Tension Reducer Circuit Short to Ground<br>B1778 Mirror Driver Down Circuit Failure<br>B1779 Mirror Driver Down Circuit Open<br>B1780 Mirror Driver Down Circuit Short To Battery<br>B1781 Mirror Driver Down Short To Ground<br>B1782 Mirror Passenger Up Circuit Failure<br>B1783 Mirror Passenger Up Circuit Open<br>B1784 Mirror Passenger Up Circuit Short To Battery<br>B1785 Mirror Passenger Up Circuit Short To Ground<br>B1786 Mirror Passenger Down Circuit Failure<br>B1787 Mirror Passenger Down Circuit Open<br>B1788 Mirror Passenger Down Circuit Short To Battery<br>B1789 Mirror Passenger Down Circuit Short To Ground<br>B1790 Autolamp Sensor Input Circuit Failure<br>B1791 Autolamp Sensor Input Circuit Open<br>B1792 Autolamp Sensor Input Circuit Short To Battery<br>B1793 Autolamp Sensor Input Circuit Short To Ground<br>B1794 Lamp Headlamp Low-Beam Circuit Failure<br>B1795 Lamp Headlamp Low-Beam Circuit Open<br>B1796 Lamp Headlamp Low-Beam Circuit Short To Battery<br>B1797 Lamp Headlamp Low-Beam Circuit Short To Ground<br>B1798 Lamp Turn Signal Front Output Circuit Failure<br>B1799 Lamp Turn Signal Front Output Circuit Open<br>B1800 Lamp Turn Signal Front Output Circuit Short To Battery<br>B1801 Lamp Turn Signal Front Output Circuit Short To Ground<br>B1802 Lamp Turn Signal Rear Output Circuit Failure<br>B1803 Lamp Turn Signal Rear Output Circuit Open<br>B1804 Lamp Turn Signal Rear Output Circuit Short To Battery<br>B1805 Lamp Turn Signal Rear Output Circuit Short To Ground<br>B1806 Lamp Tail Output Circuit Failure<br>B1807 Lamp Tail Output Circuit Open<br>B1808 Lamp Tail Output Circuit Short To Battery<br>B1809 Lamp Tail Output Circuit Short To Ground<br>B1810 Lamp Backup Switch Input Circuit Failure<br>B1811 Lamp Backup Switch Input Circuit Open<br>B1812 Lamp Backup Switch Input Circuit Short To Battery<br>B1813 Lamp Backup Switch Input Circuit Short To Ground<br>B1814 Wiper Rear Motor Down Relay Coil Circuit Failure<br>B1815 Wiper Rear Motor Down Relay Coil Circuit Open<br>B1816 Wiper Rear Motor Down Relay Coil Circuit Short To Battery<br>B1817 Wiper Rear Motor Down Relay Coil Circuit Short To Ground<br>B1818 Wiper Rear Motor Up Relay Coil Circuit Failure<br>B1819 Wiper Rear Motor Up Relay Coil Circuit Open<br>B1820 Wiper Rear Motor Up Relay Coil Circuit Short To Battery<br>B1821 Wiper Rear Motor Up Relay Coil Circuit Short To Ground<br>B1822 Wiper Rear Park Sense Input Circuit Failure<br>B1823 Wiper Rear Park Sense Input Circuit Open<br>B1824 Wiper Rear Park Sense Input Circuit Short To Battery<br>B1825 Wiper Rear Park Sense Input Circuit Short To Ground<br>B1826 Wiper Rear High Limit Input Circuit Failure<br>B1827 Wiper Rear High Limit Input Circuit Open<br>B1828 Wiper Rear High Limit Input Circuit Short To Battery<br>B1829 Wiper Rear High Limit Input Circuit Short To Ground<br>B1830 Door Unlock Disarm Switch Circuit Failure<br>B1831 Door Unlock Disarm Switch Circuit Open<br>B1832 Door Unlock Disarm Switch Circuit Short To Battery<br>B1833 Door Unlock Disarm Switch Circuit Short To Ground<br>B1834 Door Unlock Disarm Output Circuit Failure<br>B1835 Door Unlock Disarm Output Circuit Open<br>B1836 Door Unlock Disarm Output Circuit Short To Battery<br>B1837 Door Unlock Disarm Output Circuit Short To Ground<br>B1838 Battery Saver Power Relay Circuit Failure<br>B1839 Wiper Rear Motor Circuit Failure<br>B1840 Wiper Front Power Circuit Failure<br>B1841 Wiper Front Power Circuit Open<br>B1842 Wiper Front Power Circuit Short To Battery<br>B1843 Wiper Front Power Circuit Short To Ground<br>B1844 Phone Handset Circuit Failure<br>B1845 Ignition Tamper Circuit Failure<br>B1846 Ignition Tamper Circuit Open<br>B1847 Ignition Tamper Circuit Short To Battery<br>B1848 Ignition Tamper Circuit Short To Ground<br>B1849 Climate Control Temperature Differential Circuit Failure<br>B1850 Climate Control Temperature Differential Circuit Open<br>B1851 Climate Control Temperature Differential Circuit Short To Battery<br>B1852 Climate Control Temperature Differential Circuit Short To Ground<br>B1853 Climate Control Air Temperature Internal Sensor Motor Circuit Failure<br>B1854 Climate Control Air Temperature Internal Sensor Motor Circuit Open<br>B1855 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery<br>B1856 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground<br>B1857 Climate Control On/Off Switch Circuit Failure<br>B1858 Climate Control A/C Pressure Switch Circuit Failure<br>B1859 Climate Control A/C Pressure Switch Circuit Open<br>B1860 Climate Control A/C Pressure Switch Circuit Short To Battery<br>B1861 Climate Control A/C Pressure Switch Circuit Short To Ground<br>B1862 Climate Control A/C Lock Sensor Failure<br>B1863 Ground ECU Circuit Open<br>B1864 Battery Power Supply ECU Circuit Failure<br>B1865 Battery Power Supply ECU Circuit Open<br>B1866 Battery Power Supply ECU Circuit Short To Battery<br>B1867 Battery Power Supply ECU Circuit Short To Ground<br>B1868 Lamp Air Bag Warning Indicator Circuit Failure<br>B1869 Lamp Air Bag Warning Indicator Circuit Open<br>B1870 Lamp Air Bag Warning Indicator Circuit Short To Battery<br>B1871 Passenger Air Bag Disable Module Fault<br>B1872 Turn Signal / Hazard Power Feed Circuit Short To Battery<br>B1873 Turn Signal / Hazard Power Feed Circuit Short To Ground<br>B1874 Cellular Phone Handset Not Present<br>B1875 Turn Signal / Hazard Switch Signal Circuit Failure<br>B1876 Seatbelt Driver Pretensioner Circuit Failure<br>B1877 Seatbelt Driver Pretensioner Circuit Open<br>B1878 Seatbelt Driver Pretensioner Circuit Short to Battery<br>B1879 Seatbelt Driver Pretensioner Circuit Short to Ground<br>B1880 Seatbelt Passenger Pretensioner Circuit Failure<br>B1881 Seatbelt Passenger Pretensioner Circuit Open<br>B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery<br>B1883 Seatbelt Passenger Pretensioner Circuit Short to Ground<br>B1884 PAD Warning Lamp Inoperative<br>B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib<br>B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib<br>B1887 Air Bag Driver Circuit Resistance Low or Shorted Together<br>B1888 Air Bag Passenger Circuit Resistance Low or Shorted Together<br>B1889 Passenger Airbag Disable Module Sensor Obstructed<br>B1890 PAD Warning Lamp Circuit Short to Battery<br>B1891 Air Bag Tone Warning Indicator Circuit Short to Battery<br>B1892 Air Bag Tone Warning Indicator Circuit Failure<br>B1893 GPS Antenna Open Circuit<br>B1894 Wiper Rear Motor Speed Sense Circuit Failure<br>B1895 Driver's / Passenger's Door Ajar Output Circuit Failure<br>B1896 Driver's / Passenger's Door Ajar Output Circuit Short to Battery<br>B1897 Horn Switch Circuit Failure<br>B1898 Chime Input #2 Circuit Short to Ground<br>B1899 Microphone Input Signal Circuit Open<br>B1900 Driver Side Airbag Fault<br>B1901 Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground<br>B1902 Air Bag Crash Sensor #1 Ground Circuit Failure<br>B1903 Air Bag Crash Sensor #1 Ground Circuit Short To Battery<br>B1904 Air Bag Crash Sensor #2 Feed/Return Circuit Failure<br>B1905 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery<br>B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground<br>B1907 Air Bag Crash Sensor #2 Ground Circuit Failure<br>B1908 Air Bag Crash Sensor #2 Ground Circuit Short To Battery<br>B1909 Air Bag Crash Sensor #2 Ground Circuit Short To Ground<br>B1910 Air Bag Diagnostic Monitor Ground Circuit Failure<br>B1911 Air Bag Diagnostic Monitor Ground Circuit Short To Battery<br>B1912 Air Bag Diagnostic Monitor Ground Circuit Short To Ground<br>B1913 Air Bag Driver/Passenger Circuit Short To Ground<br>B1914 Air Bag Crash Sensors #1 / #2 Circuit Short To Ground<br>B1915 Air Bag Driver Circuit Failure<br>B1916 Air Bag Driver Circuit Short To Battery<br>B1917 Air Bag Memory Clear Circuit Failure<br>B1918 Air Bag Memory Clear Circuit Open<br>B1919 Air Bag Memory Clear Circuit Short To Battery<br>B1920 Air Bag Passenger Circuit Failure<br>B1921 Air Bag Diagnostic Monitor Ground Circuit Open<br>B1922 Air Bag Safing Sensor Output Circuit Short To Battery<br>B1923 Air Bag Memory Clear Circuit Short To Ground<br>B1924 Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault<br>B1925 Air Bag Passenger Circuit Short To Battery<br>B1926 Air Bag Passenger Pressure Switch Circuit Failure<br>B1927 Passenger Side Airbag Fault<br>B1928 Air Bag Safing Sensor Output Circuit Failure<br>B1929 Air Bag Safing Sensor Output Circuit Open<br>B1930 Air Bag Safing Sensor Output Circuit Short To Ground<br>B1931 Air Bag Crash Sensor #1 Feed/Return Circuit Failure<br>B1932 Air Bag Driver Circuit Open<br>B1933 Air Bag Passenger Circuit Open<br>B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib<br>B1935 Air Bag Passenger Inflator Circuit Resistance Low on Squib<br>B1936 Air Bag Driver Circuit Short To Ground<br>B1937 Air Bag Passenger Pressure Switch Circuit Open<br>B1938 Air Bag Passenger Circuit Short To Ground<br>B1939 Air Bag Passenger Pressure Switch Circuit Short To Ground<br>B1941 Air Bag Crash Sensor #1 Feed/Return Circuit Open<br>B1942 Air Bag Crash Sensor #2 Feed/Return Circuit Open<br>B1943 Air Bag Crash Sensor #1 Ground Circuit Short To Ground<br>B1944 Air Bag Crash Sensor #1 Ground Circuit Open<br>B1945 Air Bag Crash Sensor #2 Ground Circuit Open<br>B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure<br>B1947 Climate Control A/C Post Evaporator Sensor Circuit Short To Ground<br>B1948 Climate Control Water Temperature Sensor Circuit Failure<br>B1949 Climate Control Water Temperature Sensor Circuit Short To Ground<br>B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure<br>B1951 Seat Rear Up/Down Potentiometer Feedback Circuit Open<br>B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery<br>B1953 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground<br>B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure<br>B1955 Seat Front Up/Down Potentiometer Feedback Circuit Open<br>B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery<br>B1957 Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground<br>B1958 Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure<br>B1959 Seat Recline Forward/Backward Potentiometer Feedback Circuit Open<br>B1960 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery<br>B1961 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground<br>B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure<br>B1963 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open<br>B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery<br>B1965 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground<br>B1966 A/C Post Heater Sensor Circuit Failure<br>B1967 A/C Post Heater Sensor Circuit Short To Ground<br>B1968 A/C Water Pump Detection Circuit Failure<br>B1969 A/C Clutch Magnetic Control Circuit Failure<br>B1970 Passenger Seatback Forward Switch Circuit Short to Ground<br>B1971 Passenger Seatback Rearward Switch Circuit Short to Ground<br>B1972 Passenger Rear Seat Up Switch Circuit Short to Battery<br>B1973 Passenger Rear Seat Down Switch Circuit Short to Battery<br>B1974 Passenger's Seat Recline Forward Switch Circuit Short to Battery<br>B1975 Passenger's Seat Recline Back Switch Circuit Short to Battery<br>B1976 Passenger's Seat Forward Switch Circuit Short to Battery<br>B1977 Passenger's Front Seat Up Switch Circuit Short to Battery<br>B1978 Passenger's Front Seat Down Switch Circuit Short to Battery<br>B1979 Passenger Seat Rearward Switch Circuit Short to Battery<br>B1980 Bulb - Outage Condition Detected<br>B1981 Memory Off Switch Circuit Short to Battery<br>B1982 Driver's Door Unlock Relay Circuit Failure<br>B1983 Driver's Door Unlock Relay Circuit Short to Battery<br>B1984 Seat Switch Lumbar Inflate Circuit Failure<br>B1985 Seat Switch Lumbar Deflate Circuit Failure<br>B1986 Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure<br>B1987 Pedal Forward / Rearward Motor Stalled<br>B1988 Pedal Position Forward Switch Circuit Short to Battery<br>B1989 Pedal Position Rearward Switch Circuit Short to Battery<br>B1990 Pedal Forward / Rearward Potentiometer Feedback Circuit Failure<br>B1991 Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery<br>B1992 Driver Side, Side mount Airbag Circuit Short to Vbatt<br>B1993 Driver Sid, Side mount Airbag Circuit Short to Ground<br>B1994 Driver Sid, Side mount Airbag Circuit Open<br>B1995 Driver Sid, Side mount Airbag Low resistance on Squib<br>B1996 Passenger Sid, Side mount Airbag Circuit Short to Vbatt<br>B1997 Passenger Sid, Side mount Airbag Circuit Short to Ground<br>B1998 Passenger Sid, Side mount Airbag Circuit Open<br>B1999 Passenger Sid, Side mount Airbag Low resistance on Squib<br>
Re: VOLVO P2 Diagnostic Fault Codes (Short Circuit)
B2100 Door Driver Key Cylinder Switch Failure<br>B2101 Head Rest Switch Circuit Failure<br>B2102 Antenna Circuit Short to Ground<br>B2103 Antenna Not Connected<br>B2104 Door Passenger Key Cylinder Switch Failure<br>B2105 Throttle Position Input Out of Range Low<br>B2106 Throttle Position Input Out of Range High<br>B2107 Front Wiper Motor Relay Circuit Short to Vbatt<br>B2108 Trunk Key Cylinder Switch Failure<br>B2109 Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97)<br>B2110 Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97)<br>B2111 All Door Lock Input Short to Ground<br>B2112 Door Driver Set Switch Stuck Failure<br>B2113 Heated Windshield Input Short to Ground<br>B2114 Front Washer Input Short to Ground<br>B2115 Rear Washer Input Short to Ground<br>B2116 Door Driver Reset Switch Stuck Failure<br>B2117 Driver Side, Side mount Airbag Low capacitance on Squib<br>B2118 Passenger Sid, Side mount Airbag Low capacitance on Squib<br>B2119 Compressor Failure<br>B2120 Door Passenger Set Switch Stuck Failure<br>B2122 Driver Side Satellite Communication Circuit Short to Ground<br>B2123 Passenger Side Satellite Communication Circuit Short to Ground<br>B2124 Door Passenger Reset Switch Stuck Failure<br>B2128 Central Lock Motor Failure<br>B2129 Central Lock Feedback Failure<br>B2130 Double Lock Timeout Failure<br>B2131 Double Lock Feedback Failure<br>B2132 Dimmer switch Circuit Short to Gnd<br>B2133 Brake Motor Warning lamp Circuit Failure<br>B2134 Brake Motor Warning lamp Circuit Short to Vbatt<br>B2135 Park Brake Applied Warning Lamp Circuit Failure<br>B2136 Park Brake Applied Warning Lamp Circuit Short To Battery<br>B2139 Data Mismatch (receive data does not match what was expected)<br>B2141 NVM Configuration Failure<br>B2142 NVM TIC Failure<br>B2143 NVM Memory Failure<br>B2144 NVM Alarm Data Failure<br>B2145 NVM RF HR Failure<br>B2146 Seat Recline Motor Position Out of Range<br>B2148 PWM Input Circuit Failure<br>B2149 Seat Front Vertical Motor Position Out of Range<br>B2150 Power Supply #1 Circuit Short to Ground<br>B2151 Power Supply #2 Circuit Short to Ground<br>B2152 Seat Rear Vertical Motor Position Out of Range<br>B2153 Rear Echo Sensor Circuit Failure<br>B2154 Front Echo Sensor Circuit Failure<br>B2155 Seat Horizontal Motor Position Out of Range<br>B2156 Rear Doppler Sensor Circuit Failure<br>B2157 Front Doppler Sensor Circuit Failure<br>B2158 Seat Recline Motor Memory Position Out of Range<br>B2159 Memory #1 output Short to Ground<br>B2160 Memory #1 output Short to VBatt<br>B2161 Seat Front Vertical Motor Memory Position Out of Range<br>B2162 Data Mismatch #2 (receive data does not match what was expected)<br>B2163 Clutch Position Fault<br>B2164 Seat Rear Vertical Motor Memory Position Out of Range<br>B2165 Gear shift position Fault<br>B2166 Gear select position Fault<br>B2167 Seat Horizontal Motor Memory Position Out of Range<br>B2168 Unable to confirm Unlock Condition<br>B2169 Unable to confirm lock Condition<br>B2170 Steering Column Lock Switch Circuit Failure<br>B2172 Inertia Switch input Circuit Open<br>B2174 Window Driver Rear Remote Up Switch Short to Battery<br>B2175 A/C Request Signal Circuit Short to Ground<br>B2176 Overdrive switch circuit short to Vbatt<br>B2177 Interior Scanning Sensor Circuit Failure<br>B2178 Window Driver Rear Remote Down Switch Short to Battery<br>B2179 Front Wiper Select Switch "A" Short to Ground<br>B2180 Front Wiper Select Switch "B" Short to Ground<br>B2181 Front Wiper Select Switch "C" Short to Ground<br>B2182 Window Passenger Front Remote Up Switch Short to Battery<br>B2183 Front Wiper Select Switch "H" Short to Ground<br>B2184 Front Wiper Select Switch "W" Short to Ground<br>B2185 Rear Wiper Select Switch "D" Short to Ground<br>B2186 Window Passenger Front Remote Down Switch Short to Battery<br>B2187 Rear Wiper Select Switch "B" Short to Ground<br>B2188 Rear Wiper Select Switch "E" Short to Ground<br>B2190 Window Passenger Rear Remote Up Switch Short to Battery<br>B2194 Window Passenger Rear Remote Down Switch Short to Battery<br>B2195 Driver Window Up / Down Power Circuit Short to Ground<br>B2196 Passenger Window Up / Down Power Circuit Short to Ground<br>B2197 TV Module Error<br>B2198 TrafficMaster Module Error<br>B2199 VICS Module Error<br>B2200 No Communication to TV Module (No Fitting of TV)<br>B2201 No Communication With Traffic MasterModule<br>B2202 No Communication to VICS Module (No Fitting of VICS)<br>B2203 CD-ROM Error<br>B2204 GPS Antenna Connection Open or Short<br>B2205 GPS Receiver Error<br>B2206 Gyroscope Error<br>B2207 ECU ROM Checksum Error<br>B2208 Communication Link to Display and Switch Module Error<br>B2209 Interior Lamp Override Switch Open Circuit<br>B2210 Interior Lamp Override Switch Short to Ground<br>B2211 Low Coolant Lamp Output Circuit Short to Battery<br>B2214 Window Passenger Front Up Switch Short to Battery<br>B2215 Window Passenger Front Down Switch Short to Battery<br>B2219 Window Driver Front Current Feedback Exceeded<br>B2220 Window Driver Rear Current Feedback Exceeded<br>B2221 Window Passenger Front Current Feedback Exceeded<br>B2222 Window Passenger Rear Current Feedback Exceeded<br>B2223 Mirror Driver Drive Circuit Failure<br>B2224 Mirror Passenger Drive Circuit Failure<br>B2225 Front Crash Sensor Mount Fault<br>B2226 Front Crash Sensor Internal Fault<br>B2227 Front Crash Sensor Driver Communications Fault<br>B2228 Air Bag Driver Circuit Short to Ground - Loop #2<br>B2229 Air Bag Passenger Circuit Short to Ground - Loop #2<br>B2230 Air Bag Driver Circuit Short to Battery - Loop #2<br>B2231 Air Bag Passenger Circuit Short to Battery - Loop #2<br>B2232 Air Bag Driver Circuit Open - Loop #2<br>B2233 Air Bag passenger Circuit Open - Loop #2<br>B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2<br>B2235 Air Bag Passenger Inflator Circuit<br>B2236 Weak or Defected Electric Vehicle Battery Module Fault<br>B2237 Vehicle Signal indicating Park While VSS Present<br>B2238 Power Cable For Power Sliding Door Broken<br>B2239 Rear Cargo Door Set Switch Stuck (Short to Ground)<br>B2240 Rear Cargo Door Reset Switch Stuck (Short to Ground)<br>B2241 Rear Cargo Door Lock Circuit Short to Ground<br>B2242 Rear Cargo Door Unlock Circuit Open<br>B2243 Driver Rear Door Ajar Circuit Open<br>B2244 Driver Sliding Door Ajar Circuit Short to GND<br>B2245 Passenger Rear Door Ajar Circuit Open<br>B2246 Passenger Sliding Door Ajar Circuit Short to GND<br>B2247 EV Battery Pack Temperature Fault<br>B2248 Heated Windshield Relay Coil Circuit Failure<br>B2249 Head Lamp Relay Coil Short to Battery<br>B2250 All Doors Unlock Relay Circuit Failure<br>B2251 Parklamp Output Relay Driver Circuit Failure<br>B2252 Parklamp Output Relay Dirver Short to Battery<br>B2300 Seat Driver Memory Position Error<br>B2301 Seat Passenger Memory Position Error<br>B2302 Seat Headrest Feedback Potentiometer Circuit Failure<br>B2303 Seat Headrest Feedback Potentiometer Circuit Open<br>B2304 Seat Headrest Feedback Potentiometer Circuit Short to Battery<br>B2305 Seat Headrest Feedback Potentiometer Circuit Short to Ground<br>B2306 Seat Headrest Motor Stalled<br>B2310 Mirror Driver Memory Position Error<br>B2311 Mirror Passenger Memory Position Error<br>B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure<br>B2313 Mirror Passenger Horizontal Feedback Potentiometer Circuit Open<br>B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery<br>B2315 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground<br>B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure<br>B2317 Mirror Passenger Vertical Feedback Potentiometer Circuit Open<br>B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery<br>B2319 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground<br>B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure<br>B2321 Mirror Driver Horizontal Feedback Potentiometer Circuit Open<br>B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery<br>B2323 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground<br>B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure<br>B2325 Mirror Driver Vertical Feedback Potentiometer Circuit Open<br>B2326 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery<br>B2327 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground<br>B2328 Column Reach Feedback Potentiometer Circuit Failure<br>B2329 Column Reach Feedback Potentiometer Circuit Open<br>B2330 Column Reach Feedback Potentiometer Circuit Short to Battery<br>B2331 Column Reach Feedback Potentiometer Circuit Short to Ground<br>B2332 Column Tilt Feedback Potentiometer Circuit Failure<br>B2333 Column Tilt Feedback Potentiometer Circuit Open<br>B2334 Column Tilt Feedback Potentiometer Circuit Short to Battery<br>B2335 Column Tilt Feedback Potentiometer Circuit Short to Ground<br>B2336 Mirror Switch Assembly Circuit Failure<br>B2337 Mirror Switch Assembly Circuit Open<br>B2338 Mirror Switch Assembly Circuit Short to Battery<br>B2339 Mirror Switch Assembly Circuit Short to Ground<br>B2340 Column Reach Motor Stalled<br>B2341 Column Tilt Motor Stalled<br>B2342 Seat Switch Reference Voltage Positive Common Open Circuit<br>B2343 Seat Switch Reference Voltage Positive Common Supply Low Voltage<br>B2344 Seat Switch Reference Voltage Positive Common Supply Voltage Fault<br>B2345 Seat Switch Reference Voltage Negative Common Open Circuit<br>B2346 Mirror Switch Reference Voltage Positive Common Open Circuit<br>B2347 Mirror Switch Reference Voltage Positive Common Supply Low Voltage<br>B2348 Mirror Switch Reference Voltage Positive Common Supply Voltage Fault<br>B2349 Mirror Switch Reference Voltage Negative Common Open Circuit<br>B2350 Steering Column Switch Circuit Short to Battery<br>B2351 Steering Column Switch Circuit Failure<br>B2352 Driver Memory Power Switch Indicator Circuit Short to Battery<br>B2353 Driver Mirror Power Driver Circuit Short Ground<br>B2354 Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open<br>B2355 Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open<br>B2357 Driver Window Down Current Sense Low Circuit Failure<br>B2362 Remote Open/Close signal Circuit Short to Ground<br>B2363 Optical Sensor System Failure<br>B2364 Fuel Filler Door Circuit Open<br>B2365 B-pillar Power Sliding Door Open/Close Switch Input Ckt Short to Gnd<br>B2366 IP Power Sliding Door Open/Close switch Ckt Short to Gnd<br>B2367 Power Sliding Door Override Switch Input Ckt Short to Gnd<br>B2368 Steering Column Switch Circuit Out of Range<br>B2369 Chime OUTPUT Request Ckt Short to Ground<br>B2373 LED #1 Circuit Short to Battery<br>B2374 Power Sliding Detent (Latch) Circuit Failure<br>B2380 Heater Coolant Temp sensor circuit Short to GND<br>B2381 Heater Coolant Temp sensor circuit Open<br>B2384 Audio Reverse Aid Mute Input Ckt Failure<br>B2385 Audio Navigation Mute Input Ckt Failure<br>B2401 Audio Tape Deck Mechanism Fault<br>B2402 Audio CD/DJ Thermal Shutdown Fault<br>B2403 Audio CD/DJ Internal Fault<br>B2404 Audio Steering Wheel Switch Circuit Fault<br>B2405 Audio Single-Disc CD Player Thermal Shutdown Fault<br>B2406 Audio Single-Disc CD Player Internal Fault<br>B2416 Climate Control Recirculation Actuator Out of Limits<br>B2425 Remote Keyless Entry Out of Synchronization<br>B2426 Passenger Solar Radiation Sensor Circuit Open<br>B2427 Passenger Solar Radiation Sensor Circuit Short to Ground<br>B2428 A/C Post Heater Sensor #2 Circuit Failure<br>B2429 A/C Post Heater Sensor #2 Circuit Short to Ground<br>B2431 Transponder Programming Failed<br>B2432 Drivers Seat Belt Buckle Switch Circuit Open<br>B2433 Drivers Seat Belt Buckle Switch Circuit Short to Battery<br>B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground<br>B2435 Drivers Seat Belt Buckle Switch Resistance out of Range<br>B2436 Passengers Seat Belt Buckle Switch Circuit Open<br>B2437 Passengers Seat Belt Buckle Switch Circuit Short to Battery<br>B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground<br>B2439 Passengers Seat Belt Buckle Switch Resistance out of Range<br>B2440 Passenger Sid, Side crash sensor mount fault<br>B2441 Driver Sid, Side crash sensor mount fault<br>B2442 Intrusion Sensor Fault<br>B2443 Powertrain Performance Mode Switch Circuit failure<br>B2444 Driver Side Crash Sensor Internal Fault<br>B2445 Passenger Side Crash Sensor Internal Fault<br>B2446 RESCU/VEMS Input Circuit Open<br>B2447 RESCU/VEMS Input Circuit Short to Battery<br>B2448 RESCU/VEMS Input Circuit Short to Ground<br>B2449 Aux Heater Glow Plug Circuit Short to Ground<br>B2450 Aux Heater Glow Plug Circuit Open<br>B2451 Aux Heater Fuel Pump Circuit Short to Ground<br>B2452 Aux Heater Fuel Pump Circuit Open<br>B2453 Aux Heater Blower Fan Circuit Short to Ground<br>B2454 Aux Heater Blower Fan Circuit Open<br>B2455 Aux Heater Blower Faulted<br>B2456 Aux Heater Coolant Sensor Circuit Short to Ground<br>B2457 Aux Heater Coolant Sensor Circuit Open<br>B2458 Aux Heater Overheat Sensor Circuit Short to Ground<br>B2459 Aux Heater Overheat Sensor Circuit Open<br>B2460 Aux Heater Flame Sensor Circuit Short to Ground<br>B2461 Aux Heater Flame Sensor Circuit Open<br>B2462 Aux Heater Flame Out Fault<br>B2463 Aux Heater Overheat Fault<br>B2464 Aux Heater Start Time Exceeded<br>B2465 Aux Heater Start Counter Overrun/System Locked (same as below ?)<br>B2466 Aux Heater Overheat Counter Overrun/System Locked<br>B2467 Aux Heater Cool Down Time Exceeded (may be con to a453-5 )<br>B2468 Aux Heater Coolant Pump Circuit Short to Ground<br>B2469 Aux Heater Coolant Pump Circuit Open<br>B2470 Interior Fan Control Circuit Short to Ground<br>B2471 Interior Fan Control Circuit Open<br>B2472 Fog Lamp Switch Failure<br>B2473 Passenger Door Disarm Switch ckt Short to Ground<br>B2474 Passenger Door Lock Switch Circuit Shorted to Ground<br>B2475 Passenger Door Unlock Switch Circuit Shorted to Ground<br>B2476 RADIO PRESENT SWITCH Ckt Failure<br>B2477 Module Configuration Failure<br>B2478 ANTI THEFT INPUT SIGNAL SHORT TO GROUND<br>B2479 BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND<br>B2480 LF CORNER LAMP OUTPUT Ckt Short to Battery<br>B2481 Convertible Top Up/Down switch Fault<br>B2482 RF CORNER LAMP OUTPUT Ckt Short to Battery<br>B2483 Enable Signal Open Circuit<br>B2484 Disable Signal Short to Ground<br>B2485 LF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery<br>B2487 RF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery<br>B2489 UNDERHOOD LAMP OUTPUT CIRCUIT Failure<br>B2490 UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery<br>B2491 RF PARK LAMP OUTPUT CIRCUIT Short to Battery<br>B2492 Already Programmed (Test Mode DTC Only !!!)<br>B2493 LF PARK LAMP OUTPUT CIRCUIT Short to Battery<br>B2494 ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt<br>B2495 ANTI THEFT HORN OUTPUT CIRCUIT Failure<br>B2496 ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd<br>B2499 COURTESY LAMP OUTPUT Failure<br>B2500 COURTESY LAMP OUTPUT Ckt Short to Battery<br>
Discussion Starter · #13 ·
B2501 LF LAMP LOW BEAM CIRCUIT Failure<br>B2502 LF LAMP LOW BEAM CIRCUIT Short to Battery<br>B2503 RF LAMP LOW BEAM CIRCUIT Failure<br>B2504 RF LAMP LOW BEAM CIRCUIT Short to Battery<br>B2505 LF LAMP HIGH BEAM CIRCUIT Failure<br>B2506 LF LAMP HIGH BEAM CIRCUIT Short to Battery<br>B2507 RF LAMP HIGH BEAM CIRCUIT Failure<br>B2508 RF LAMP HIGH BEAM CIRCUIT Short to Battery<br>B2509 Rear Fog Lamp Switch Circuit Failure<br>B2510 Main Blower Motor Relay Circuit Short to Battery<br>B2511 Horn Output Relay Circuit Short to Battery<br>B2512 Front Fog Lamp Relay Ckt Short to Battery<br>B2513 Blower (Fan) Circuit Failure<br>B2514 Blower (Fan) Circuit Short to Vbatt<br>B2515 Heater Blower Relay Circuit Failure<br>B2516 Blower Control Circuit Failure<br>B2517 Emergency Power Off System Faulted<br>B2518 Compressor Overtemp Fault<br>B2519 High Mount Stop Lamp Circuit Failure<br>B2520 High Mount Stop Lamp Circuit Short to Battery<br>B2523 License Lamp Circuit Failure<br>B2524 License Lamp Circuit Short to Battery<br>B2525 Left Rear Backup Lamp Circuit Failure<br>B2526 Left Rear Backup Lamp Circuit Short to Battery<br>B2527 Left Rear Stop lamp Circuit Failure<br>B2528 Left Rear Stop lamp Circuit Short to Battery<br>B2529 Left Rear Turn Lamp Circuit Failure<br>B2530 Left Rear Turn Lamp Circuit Short to Battery<br>B2531 Right Rear Backup Lamp Circuit Failure<br>B2532 Right Rear Backup Lamp Circuit Short to Battery<br>B2533 Right Rear Stop lamp Circuit Failure<br>B2534 Right Rear Stop lamp Circuit Short to Battery<br>B2535 Right Rear Turn Lamp Circuit Failure<br>B2536 Right Rear Turn Lamp Circuit Short to Battery<br>B2539 Aux A/C Mode Position Reference Circuit Short to Ground<br>B2540 Aux A/C Mode Position Reference Circuit Short to Battery<br>B2543 Aux A/C Control Switch Reference Circuit Short to Ground<br>B2544 Aux A/C Control Switch Reference Circuit Short to Battery<br>B2545 System Power Relay Circuit Short to Battery<br>B2546 System Power Relay Circuit Failure<br>B2550 LAMP DOME OUTPUT Circuit Short to Ground<br>B2553 Disable Signal Output Circuit Short to Battery<br>B2554 LAMP DOME OUTPUT Circuit Failure<br>B2555 LAMP DOME OUTPUT Circuit Short to Battery<br>B2556 Enable Signal Circuit Short to Battery<br>B2557 Left Power Sliding Door Open/Close Output Circuit Short to Battery<br>B2558 Right Power Sliding Door Open/Close Output Circuit Short to Battery<br>B2559 Aux A/C Blower Motor Relay Circuit Short to Battery<br>B2560 Aux A/C Blower Motor Relay Circuit Short to Ground<br>B2561 Aux A/C Blower Speed 1 Circuit Failure<br>B2562 Aux A/C Blower Speed 1 Circuit Short to Ground<br>B2563 Aux A/C Blower Speed 2 Circuit Failure<br>B2564 Aux A/C Blower Speed 2 Circuit Short to Ground<br>B2565 Right Tail Lamp Circuit Failure<br>B2566 Right Tail Lamp Circuit Short to Ground<br>B2567 Reverse Mirror Output Circuit Failure<br>B2568 Reverse Mirror Output Circuit Short to Ground<br>B2569 Liftgate Disarm Switch Circuit Short to Ground<br>B2570 Right Lamp Outage Signal Circuit Short to Ground<br>B2571 Left Lamp Outage Signal Circuit Short to Ground<br>B2580 Aux Blower Sense Switch Circuit Failure<br>B2581 Passenger Seat Occupant Detection Circuit Short To Ground<br>B2582 Passenger Seat Occupant Detection Circuit Open<br>B2583 Child Seat Detection Circuit Short to Ground<br>B2584 Child Seat Detection Circuit Open<br>B2585 Anti Theft Input Signal Circuit Short To Battery<br>B2586 Headlamp Mode Select Circuit Failure<br>B2587 Passenger Seat Occupant Detection Circuit Short To Battery<br>B2588 Child Seat Detection Circuit Short To Battery<br>B2589 Unexpected Door Reversal During Close<br>B2590 Vehicle Park/Speed Signal Circuit Failure<br>B2591 Detent Signal Missing During Unlatch<br>B2592 PSD Not Fully Closed (Module Commanded Successfully)<br>B2593 Power Sliding Door Opened During Module Close Command<br>B2594 No Movement Detected After an Unlatch During Power Open<br>B2595 Anti Theft Input Signal Circuit Failure<br>B2596 Headlamp Aim Output Relay Circuit Short To Battery<br>B2597 Headlamp Aim Output Relay Circuit Failure<br>B2598 Headlamp Relay Circuit Failure<br>B2599 Tailgate Release Open Circuit<br>B2600 Double Locking Door Motor Frozen<br>B2601 No Latch Signal Sensed on Closing and Door Reversed<br>B2602 Missing Latch Signal During Power Sliding Door Unlatch<br>B2603 PSD Not Fully Closed During Self-Test<br>B2604 Power Sliding Door On/Off Switch Open Circuit<br>B2605 Disable Signal Open Circuit<br>B2606 A/C Temperature Sensor Out of Range<br>
Discussion Starter · #14 ·
U1000 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1001 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1002 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1003 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1004 SCP (J1850) Invalid or Missing Data for EEC Programming<br>U1005 SCP (J1850) Invalid or Missing Data for EEC Programming<br>U1006 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1007 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1008 SCP (J1850) Invalid or Missing Data for Engine Torque<br>U1009 SCP (J1850) Invalid or Missing Data for Engine Torque<br>U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake<br>U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake<br>U1012 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1013 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1014 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1015 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1016 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1017 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1018 SCP (J1850) Invalid or Missing Data for Throttle<br>U1019 SCP (J1850) Invalid or Missing Data for Throttle<br>U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch<br>U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch<br>U1022 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1023 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1024 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1025 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1026 SCP (J1850) Invalid or Missing Data for Engine RPM<br>U1027 SCP (J1850) Invalid or Missing Data for Engine RPM<br>U1028 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1029 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1030 SCP (J1850) Invalid or Missing Data for Experimental #1<br>U1031 SCP (J1850) Invalid or Missing Data for Experimental #1<br>U1032 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1033 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1034 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1035 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1036 SCP (J1850) Invalid or Missing Data for Wheels<br>U1037 SCP (J1850) Invalid or Missing Data for Wheels<br>U1038 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed<br>U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed<br>U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed<br>U1042 SCP (J1850) Invalid or Missing Data for Traction Control<br>U1043 SCP (J1850) Invalid or Missing Data for Traction Control<br>U1044 SCP (J1850) Invalid or Missing Data for Traction Motor<br>U1045 SCP (J1850) Invalid or Missing Data for Traction Motor<br>U1046 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1047 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1048 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1049 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1050 SCP (J1850) Invalid or Missing Data for Brakes<br>U1051 SCP (J1850) Invalid or Missing Data for Brakes<br>U1052 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel<br>U1053 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel<br>U1054 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1055 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1056 SCP (J1850) Invalid or Missing Data for Vehicle Configuration<br>U1057 SCP (J1850) Invalid or Missing Data for Vehicle Configuration<br>U1058 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL<br>U1059 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL<br>U1060 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1061 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1062 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1063 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1064 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1065 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1066 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1067 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1068 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1069 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1070 SCP (J1850) Invalid or Missing Data for Engine Sensors<br>U1071 SCP (J1850) Invalid or Missing Data for Engine Sensors<br>U1072 SCP (J1850) Invalid or Missing Data for Engine Coolant<br>U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant<br>U1074 SCP (J1850) Invalid or Missing Data for Engine Oil<br>U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temp<br>U1076 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1077 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1078 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1079 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1080 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1081 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1082 SCP (J1850) Invalid or Missing Data for Engine Systems Other<br>U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other<br>U1084 SCP (J1850) Invalid or Missing Data for Powertrain Status Request<br>U1085 SCP (J1850) Invalid or Missing Data for Powertrain Status Request<br>U1086 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1087 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1088 SCP (J1850) Invalid or Missing Data for Suspension<br>U1089 SCP (J1850) Invalid or Missing Data for Suspension<br>U1090 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics<br>U1091 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics<br>U1092 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1093 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1094 SCP (J1850) Invalid or Missing Data for Experimental #2<br>U1095 SCP (J1850) Invalid or Missing Data for Experimental #2<br>U1096 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1097 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control<br>U1099 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control<br>U1100 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1101 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1102 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1103 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1104 SCP (J1850) Invalid or Missing Data for Chassis Status Request<br>U1105 SCP (J1850) Invalid or Missing Data for Chassis Status Request<br>U1106 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics<br>U1107 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics<br>U1108 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)<br>U1109 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)<br>U1110 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1111 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1112 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1113 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1114 SCP (J1850) Invalid or Missing Data for Charging System<br>U1115 SCP (J1850) Invalid or Missing Data for Charging System<br>U1116 SCP (J1850) Invalid or Missing Data for Electrical Energy Management<br>U1117 SCP (J1850) Invalid or Missing Data for Electrical Energy Management<br>U1118 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1119 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1120 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1121 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1122 SCP (J1850) Invalid or Missing Data for Odometer<br>U1123 SCP (J1850) Invalid or Missing Data for Odometer<br>U1124 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1125 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1126 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1127 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1128 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1129 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1130 SCP (J1850) Invalid or Missing Data for Fuel System<br>U1131 SCP (J1850) Invalid or Missing Data for Fuel System<br>U1132 SCP (J1850) Invalid or Missing Data for Vehicle Motion<br>U1133 SCP (J1850) Invalid or Missing Data for Vehicle Motion<br>U1134 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter<br>U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter<br>U1136 SCP (J1850) Invalid or Missing Data for Telltales<br>U1137 SCP (J1850) Invalid or Missing Data for Telltales<br>U1138 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1139 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1140 SCP (J1850) Invalid or Missing Data for Gateway<br>U1141 SCP (J1850) Invalid or Missing Data for Gateway<br>U1142 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1143 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1144 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1145 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1146 SCP (J1850) Invalid or Missing Data for Vehicle Security<br>U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security<br>U1148 SCP (J1850) Invalid or Missing Data for Audio Control<br>U1149 SCP (J1850) Invalid or Missing Data for Audio Control<br>U1150 SCP (J1850) Invalid or Missing Data for Audible Warnings<br>U1151 SCP (J1850) Invalid or Missing Data for Audible Warnings<br>U1152 SCP (J1850) Invalid or Missing Data for Experimental #3<br>U1153 SCP (J1850) Invalid or Missing Data for Experimental #3<br>U1154 SCP (J1850) Invalid or Missing Data for Compact Disc<br>U1155 SCP (J1850) Invalid or Missing Data for Compact Disc<br>U1156 SCP (J1850) Invalid or Missing Data for Digital Signal Processing<br>U1157 SCP (J1850) Invalid or Missing Data for Digital Signal Processing<br>U1158 SCP (J1850) Invalid or Missing Data for Antenna<br>U1159 SCP (J1850) Invalid or Missing Data for Antenna<br>U1160 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1161 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1162 SCP (J1850) Invalid or Missing Data for Digital Audio Tape<br>U1163 SCP (J1850) Invalid or Missing Data for Digital Audio Tape<br>U1164 SCP (J1850) Invalid or Missing Data for Tuner / Receiver<br>U1165 SCP (J1850) Invalid or Missing Data for Tuner / Receiver<br>U1166 SCP (J1850) Invalid or Missing Data for Cassette Tape<br>U1167 SCP (J1850) Invalid or Missing Data for Cassette Tape<br>U1168 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1169 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1170 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System<br>U1171 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System<br>U1172 SCP (J1850) Invalid or Missing Data for Remote Button Control<br>U1173 SCP (J1850) Invalid or Missing Data for Remote Button Control<br>U1174 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1175 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1176 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1177 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1178 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)<br>U1179 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)<br>U1180 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features<br>U1181 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features<br>U1182 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1183 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1184 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer<br>U1185 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer<br>U1186 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1187 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1188 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1189 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1190 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1191 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1192 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1193 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1194 SCP (J1850) Invalid or Missing Data for Mirrors<br>U1195 SCP (J1850) Invalid or Missing Data for Mirrors<br>U1196 SCP (J1850) Invalid or Missing Data for Door Locks<br>U1197 SCP (J1850) Invalid or Missing Data for Door Locks<br>U1198 SCP (J1850) Invalid or Missing Data for External Access (Doors)<br>U1199 SCP (J1850) Invalid or Missing Data for External Access (Doors)<br>U1200 SCP (J1850) Invalid or Missing Data for Seat Motion / Control<br>U1201 SCP (J1850) Invalid or Missing Data for Seat Motion / Control<br>U1202 SCP (J1850) Invalid or Missing Data for Windows<br>U1203 SCP (J1850) Invalid or Missing Data for Windows<br>U1204 SCP (J1850) Invalid or Missing Data for Steering Column<br>U1205 SCP (J1850) Invalid or Missing Data for Steering Column<br>U1206 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1207 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1208 SCP (J1850) Invalid or Missing Data for Seat Switches<br>U1209 SCP (J1850) Invalid or Missing Data for Seat Switches<br>U1210 SCP (J1850) Invalid or Missing Data for Restraints<br>U1211 SCP (J1850) Invalid or Missing Data for Restraints<br>U1212 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1213 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1214 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1215 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1216 SCP (J1850) Invalid or Missing Data for External Lamp Outage<br>U1217 SCP (J1850) Invalid or Missing Data for External Lamp Outage<br>U1218 SCP (J1850) Invalid or Missing Data for External Lamps<br>U1219 SCP (J1850) Invalid or Missing Data for External Lamps<br>U1220 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage<br>U1221 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage<br>U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps<br>U1223 SCP (J1850) Invalid or Missing Data for Interior Lamps<br>U1224 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1225 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1226 SCP (J1850) Invalid or Missing Data for Body Status Request<br>U1227 SCP (J1850) Invalid or Missing Data for Body Status Request<br>U1228 SCP (J1850) Invalid or Missing Data for Tires<br>U1229 SCP (J1850) Invalid or Missing Data for Tires<br>U1230 SCP (J1850) Invalid or Missing Data for Electric Defrost<br>U1231 SCP (J1850) Invalid or Missing Data for Electric Defrost<br>U1232 SCP (J1850) Invalid or Missing Data for Navigation<br>U1233 SCP (J1850) Invalid or Missing Data for Navigation<br>U1234 SCP (J1850) Invalid or Missing Data for Displays<br>U1235 SCP (J1850) Invalid or Missing Data for Displays<br>U1236 SCP (J1850) Invalid or Missing Data for Memory Storage<br>U1237 SCP (J1850) Invalid or Missing Data for Memory Storage<br>U1238 SCP (J1850) Invalid or Missing Data for Experimental #4<br>U1239 SCP (J1850) Invalid or Missing Data for Experimental #4<br>U1240 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1241 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1242 SCP (J1850) Invalid or Missing Data for Exterior Environment<br>U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment<br>U1244 SCP (J1850) Invalid or Missing Data for Interior Environment<br>U1245 SCP (J1850) Invalid or Missing Data for Interior Environment<br>U1246 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1247 SCP (J1850) Invalid or Missing Data for Primary Id<br>U1248 SCP (J1850) Invalid or Missing Data for Time / Date<br>U1249 SCP (J1850) Invalid or Missing Data for Time / Date<br>U1250 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)<br>U1251 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)<br>U1252 SCP (J1850) Invalid or Missing Data for Class A Functions<br>U1253 SCP (J1850) Invalid or Missing Data for Class A Functions<br>U1254 SCP (J1850) Invalid or Missing Data for Network Control<br>U1255 SCP (J1850) Invalid or Missing Data for Network Control<br>U1260 SCP (J1850) Single Ended (+) Circuit Failure<br>U1261 SCP (J1850) Single Ended (-) Circuit Failure<br>U1262 SCP (J1850) Communication Bus Fault<br>U1308 SCP (J1850) Invalid or Missing Data for Function Read Engine Torque<br>U1341 SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed<br>U1430 SCP (J1850) Invalid or Missing Data for Function Read Fuel System<br>U1451 SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings / Anti-Theft Module, Vehicle Immobilized<br>U1612 SCP (J1850) Lack of Acknowledgment for Primary Id<br>U1736 SCP (J1850) Lack of Acknowledgment for Telltales<br>U1750 SCP (J1850) Lack of Acknowledgment for Audible Warnings<br>U1794 SCP (J1850) Lack of Acknowledgment for Mirrors<br>U1797 SCP (J1850) Lack of Acknowledgment for Door Locks<br>U1798 SCP (J1850) Lack of Acknowledgment for External Access (Doors)<br>U1806 SCP (J1850) Lack of Acknowledgment for Primary Id<br>U1900 CAN Communication Bus Fault<br>U1950 UPB Communication Bus Fault<br>U2000 Audio Rear Control Unit is Not Responding<br>U2001 Audio Tape Deck Unit is Not Responding<br>U2002 Audio Bezel is Not Responding<br>U2003 Audio Compact Disk / Disk Jockey Unit is Not Responding<br>U2004 Audio Steering Wheel Control Unit is Not Responding<br>U2005 Audio Rear Integrated Control Panel Unit is Not Responding<br>U2006 Audio Remote Climate Control Unit is Not Responding<br>U2007 Audio Navigation Unit is Not Responding<br>U2008 Audio Phone is Not Responding<br>U2009 Audio Front Control Module (ACM) is Not Responding<br>U2010 Module is Not Responding (Non SCP)<br>U2011 Module Transmitted Invalid Data (Non SCP)<br>U2012 Communication Bus Error (Non SCP)<br>U2013 Compass Module is not Responding<br>U2014 Audio Subwoofer Unit is Not Responding<br>U2015 Signal Link Fault (Non SCP)<br>U2016 Signal Link Short to Ground (Non SCP) / From NGV Module<br>U2017 Driver Side Crash Sensor Communication Fault (Non SCP)<br>U2018 Passenger Side Crash Sensor Communication Fault (Non SCP)<br>U2019 Audio Voice Module Not Responding<br>U2020 Audio Center Amp is not responding<br>U2021 Invalid /fault data received (Non SCP)<br>U2150 SCP (J1850) Invalid Data from REM<br>U2152 SCP (J1850) Invalid Data from GEM<br>U2160 SCP (J1850) Invalid Data from IC<br>U2195 SCP (J1850) Invalid Data from SCLM<br>U2500 (CAN) Lack of Acknowledgement From Engine Management<br>
RANDY WTF!!!! you trying to give me a headeach i dont think FEO will be too happy if i have a headach right now that im doing his tranny rt now!!! LOLOLOL <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Discussion Starter · #16 ·
Re: VOLVO P2 Diagnostic Fault Codes (VolvokidS60R)
HA!!! You need a McDonalds Iced Coffee - thats what you need!!!
If this is not already on SS somewhere, it should be stickied and/or linked to the caffieneless man's Master thread.<p>Thanks for the info <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Short Circuit</b> »</i></TD></TR><TR><TD CLASS="quote">HA!!! You need a McDonalds Iced Coffee - thats what you need!!!</TD></TR></TABLE><p>let the man work his magic <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"><p>no but seriously, thanks for posting this list<p>now we need to figure out how to cross correlate them with the DIM number and presto!
Discussion Starter · #19 ·
Re: VOLVO P2 Diagnostic Fault Codes (FEO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote"><p>let the man work his magic <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"><p>no but seriously, thanks for posting this list<p>now we need to figure out how to cross correlate them with the DIM number and presto!</TD></TR></TABLE><p>My pleasure. I knew this would be of value to the SS community.
Brilliant!
1 - 20 of 23 Posts
