1 - 17 of 17 Posts
I can not stress enough not to use them .
Simpley the largest theiving company in History.
Do not belive the LIES from Terry ****.
DONT
THIS JUST OF AS TODAY
Lord_Devlin
View Member Profile
Add as Friend
Send Message
Find Member's Topics
Find Member's Posts
Today, 07:45 PM Post #228
Newbie
Group: Members
Hey all. I have an update on my situation with Volvo Motorsports. I hired a Machine Shop to disassemble the block on write me out a report of there findings. Here's what they found:
"2000 1.9 V-40 Volvo Short Block
On March 17th 2009 Mr. Watts brought us his assembled V-40 Volvo engine to Ellsworth Machine. He asked us to disassemble and inspect the engine. Here's what we found…
A first glance, I can see the tops of all 4 pistons were polished. As I rotate the pistons up and down in the bore large deep scratches are now visible at the top of the cylinders (see pics). The deep scratches in the bore together with the wrong cylinder wall finish will not allow the piston rings to seal…(First problem). I have now disassembled the entire short block.
The pistons are New std. bore (3.266 in.) Mahle cast (not aftermarket forged). The cylinder bore is a used std. bore and has not been machined. A stone ball hone was used to finish the cylinder walls (240 grit finish). The piston rings are new with a chrome top and a cast iron second ring. In order for the rings to seal properly a 400 grit finish on the cylinder walls in necessary. The pistons have .0035 in. to .0055 in. piston to wall clearance. The new Volvo piston clearance spec is .0004 in. to .0012. So, the bore is too large and too tapered for proper piston ring seal.
The connecting rods are new but have no brand name or part number on them. The rod and main bearings are also new. The crankshaft is a used forged welded up stroker Volvo shaft. The welded rod journals are machined offset to create an increased stroke length. The engine block appears to be a stock std. bore V-40 in an unusable bore and sold as a new rebuilt Volvo stroker. It's the opinion of this machine shop, if the engine was placed in the car and started as is…large amounts of oil smoke and increased oil consumption would have been a problem.
Ellsworth Machine Shop
2415 Old Middlefield Way
Mountain View, Ca 94043
(650)968-7884"
I also have numerous photos that the machine shop has taken to back up what they wrote in the report.
So as you can see, Volvo Motorsports did not assemble the block correctly and neither did they give me the pistons I was promised. The rods appear to be forged and the machine shop tested them and they appear to be good. However, I have no idea what brand they are or where they came from.
On a more interesting note, it appears Terry **** does still in fact read this forum and others like it, although he no longer posts for obvious reasons. I received an email from him late last week concerning my short block and my various forum posting about this topic. Here's the email:
Hi Luke, The short block that i sent you has been stroked and heat treated to add strength that is what gives it the dark color. The stroke was increse from 90mm to 93.2mm and the rods are forged 4340 chromoly steel and are a longer rod. The stock rods are 139.5mm and those are 145mm. The pistons are a hyperutectic piston from a S60R. You might have notice small lines in the cylinders but these are below the actual compression line so they will not hurt a thing. This will make you one bad ALL GLORY TO THE HYPNOTOAD engine if you just use it. I noticed your post on volvospeed and when you have questions all you have to do is call. Your engine size is now 2018cc
I'll be forwarding this new information to the BBB.
-Luke
Seriouls Please Please do your reasearch when buying from Companies for your volvo parts.
Discussion Starter · #2 ·
Yeah had a buddy with a 1998 C70 coupe get a head from them several years ago they had to do it 4 times before it was done right they are just a rip off imo
That used to be a website I visited to dream, and pretend to buy stuff.
I won't be doing that anymore.
I did it with the Evolve site, but I already got everything I wanted.
Simpley if anyone here actually wants to build a motor , I would post on VS and ask there on who everyone has used there and there success.
I am going to be using alteratmosphere when I get my bottome end built for a car eventually lol
Re: (Needsdecaf)
Quote, originally posted by Needsdecaf »
To make this R related we should probably ask Boosted to weigh in on his experience...
How long has he been waiting for that engine ....................
I seriously feel bad for him .
Yeah seriously... I know a fellow s40 member who put out 20k for a new motor, buildup, etc etc... car lasted 4 months i believe. Now hes selling all of it. If im not mistaken he is getting together w another member who got robbed as well and pursuing a lawsuit....Crooks man!! Oh yeah, poor Boosted : ( ive been waiting to hear about his car, but is been like freaking 2 years!!!
Re: (Chilled Man)
Quote, originally posted by Chilled Man »
To be fair before piling on, he has been on so rarely that I do not know whether it is an engine thing, something else, or simply a $$ issue.
Re: (B.G.)
Quote, originally posted by B.G. »
$20k engine build in an S40? I wouldn't do a $20k engine build if it was an M5!
Re: (Needsdecaf)
Maybe if you're getting into M6 Dinan Country... I think its 35k for a 5.6L V10 block.
But then again, you could just get another R...
Discussion Starter · #13 ·
Re: (Needsdecaf)
LOL trust me this is not the first time anyone has gone through this with them .
and unfortuanatly it wont be the last
Re: (Needsdecaf)
my car is still in my garage at my house motor less.
Discussion Starter · #16 ·
Re: (BOOSTED S60R)
Quote, originally posted by BOOSTED S60R »
The real quesiton is how long has it been ?
seriously I feel bad for you it sucks
Re: (Chilled Man)
lets just say a very very long time.
1 - 17 of 17 Posts
