1 - 18 of 18 Posts
I can vouch for this being a very clean example. This car is tight and drives extremely well. The seller is a great, honest guy.
174k
Any takers at $3800 with Columbia wheels and good Michelins. $400 more takes the 5 factory Volans w/tires
Volans only available to car buyer.
Thanks
Looks super clean! Jealous whoever it goes to
VIN - YV1LS5829T2328661
Clear title
In New Hampshire
Dealer records of:
7/2000 38000 ac evaporator; oil change
10/2000 43600 oil change
11/2000 45000 fuel door lock rpl
5/2000 46000 ac blower motor rpl; dash bulb on info window rpl
1/2001 48000 oil change; front brake pads
5/2001 54000 oil change
8/2001 58000 oil change
10/2001 60700 60k service/oil change
11/2001 63000 oil change
2/2002 67000 rear main seal
3/2002 68000 70k service/timing belt - upper motor mount/oil change
4/2002 69000 knock sensor
5/2002 70000 abs control unit
7/2002 73000 oil change, front pads&rotors, coolant flush
8/2002 75000 oil change
1/2003 81000 oil change
4/2003 84000 oil change, shift lock solenoid
8/2003 88000 oil change, service campaign 112
11/2003 90k service - oil/coolant/atf flush, rear brake pads, front motor mount, 2 stab links
2/04 95000 oil change
5/04 97000 fuel pump
7/04 99000 oil, front pads/discs
11/04 102000 oil
3/05 105000 o2 sensor,oil, gear shifter bulb, fuel tank flange/shield recall
7/05 108000 antenna, oil
9/05 109000 windshield washer pump
10/05 110000 oil
3/06 113000 oil
4/06 114000 rear pads/discs, new sunroof glass(small leak)
8/06 117000 oil change
11/06 120000 oil
4/07 123000 oil, upper strut mounts, axle boots
5/07 123500 cat conv replaced
11/07 125000 125k service oil front pads/rotors, seat htr relay
1/08 126000 seat heater rpl
2/08 126600 seat heater grid
4/08 12700 oil, turbo return line seal
7/08 128000 ac recharge
11/08 129000 oil
3/09 132000 oil trap replaced
5/09 134000 ac accumulator
8/09 136000 140k interval service - timing belt,idler,tensioner, aux belt, oil, rear pads/rotors
12/09 139000 oil
1/10 140000 rear shocks
4/10 142000 oil
6/10 144000 r f ball joint
7/10 144000 ac evap/dryer/compressor, oil
7/10 144200 radiator (small leak)
10/10 146000 odometer replaced
11/10 147000 oil
4/11 150000 oil, rf control arm
7/11 152000 ac compressor, oil
11/11 153000 windshield (rock)
11/11 153000 lf control arm
7/12 155000 oil
11/12 156700 oil
4/13 157750 oil
8/13 158500 front brake pads, r sway bar link
9/14 159900 Head gasket replaced due to oil leak out of head. New valve seals while open, new timing belt, tensioner pulley and water pump preventatively done.
9/15 164900 new oil cooler lines
Obviously a loved example, look at that interior!
Also curious if it's still for sale
Discussion Starter · #13 · (Edited)
$2900 with volans
$200 extra and you can take full set of columbias with almost full tread michelins
Update:Small scuff and vertical split in front bumper where it meets wheel well.
I'm really surprised this has not sold. I looked at it, drove it about two years back. Amazing car, great honest seller. Wish I had my funds in better order at the time. Might have to reconsider now though. Good luck with your sale!
Discussion Starter · #18 ·
Thanks, It did go to a good buyer, but i regret not handing her over to you for the later price njjenks. Sorry
1 - 18 of 18 Posts
